Results 1 to 11 of 11
    Active Member JamesLaz's Avatar
    May 2023
    Arizona
    Default My Custom Carry Along Wheel Chocks.
    I wanted some small wheel chocks for my Can AM Spyder F3 limited but was not happy with what I was finding so I made my own.
    I wanted something compact that I could easily carry along with me so I ordered a 2 pack of rubber door stops, drilled holes in the end and attached wit a piece of cord. They work great and take up little space.
    Thanks,
    James
    Oct 2015
    Lynden, WA
    Default Wheel Chocks
    Very inventive. Good use of available materials.
    Nice job.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Don't trust your parking brake?
    Aug 2020
    Il
    I will assume that it is for a semi level garage and like me doesn't use the parking brake to save the motor.
    21 Spyder base F3
    ................I Loooooooooooooooooooooooooooove another DIY'er ........ Mike
    Feb 2020
    illinois
    Don't get the need??
    Clinton, MS
    Quote Originally Posted by baxter View Post
    If you ever have your parking brake not release and you have to do it manually, you will wish you had a set unless you can locate some big rocks. ;-)
    Last edited by Peter Aawen; 10-20-2023 at 11:51 AM. Reason: Fixed quote display ;-)
    2019 RTL Phoenix Orange
    Feb 2020
    illinois
    Two Spyders and have not had P/Brk issue.
    Jun 2015
    Ritzville, Wa
    Way to think outside the box.
    Greg Kamer
    "It's better to be not riding and wishing you were; than to be riding and wishing you weren't!"
    USAF, 20 years, retired
    Sadly passed away in December '23. Still helping the SpyderLovers Community, but no longer posting. Greatly Missed.
    https://www.spyderlovers.com/forums/...er-Member-here
    2018 Can Am Spyder RT-Limited
    May 2023
    Arizona
    I have had the parking brake issues a few times and these are perfect for that situation. I can keep my Spyder still as I disconnect the parking brake to reset it. If you have had the parking brake issues you will know why these are needed.
    Aug 2013
    SF Bay Area
    2021 F3 Ltd , Magna Red
