Results 1 to 5 of 5
    Sebring, FL
    Default Any video's on 2020 RTL Front Seat Shock Install?
    Any video's on this install?
    Mar 2021
    Haven, Ks
    I didn't video the installation but it is no big deal. Just remove the back seat, open the front seat, release the bottom of the existing shock with a long slender straight bladed screwdriver, remove the screw holding the top of the shock and remove the oem shock. Reverse the process and you are done. I think it took at most 10 minutes for me to do the switch. To remove the back seat, just remove any backrest that you have installed and take hold of the front wings of the back seat and pull straight up. It will just pop up and out. No problem.
    Bartender
    2022 Spyder Sea to Sky
    Sebring, FL
    OK, got it thanks. Doesn't look complicated at all. Where did you order yours?
    Mar 2021
    Haven, Ks
    Ordered from:
    McMaster-Carr
    Gas Spring
    30 lbs. Force, 5.51" Extended Length
    9416K14
    $17.60
    Very quick service and shipping.
    Bartender
    Sebring, FL
    Found it Bartender, beats the other prices by half. Did you have any problem with the install.
