Results 1 to 20 of 20
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Default Anyone interested in the spyderstore.com Domain?
    My spyderstore.com domain registration will expire in a few months if someone is interested in it let me know.
    JT
    Faribault, MN
    JT, are you getting out of the business, or just gonna produce for someone else to sell?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2013
    Poplar Bluff, MO
    I sent all the information to produce the 998 air filter kit to Baja Ron with my blessings to start producing them.
    I'm retiring and no longer produce Spyder products so if anyone wants to produce the other things I used to make I can help you out.
    JT
    Faribault, MN
    Just got off the phone with a fellow spyder rider who saw me use my original Dual Fill and he's trying to source the components at Amazon to make his own (for personal use) variant. I suggested we make a list of readily available part numbers to share if you don't mind. Would Baja Ron consider any of your other inventions? I always wanted one of your NHR - No Hitch Required Carriers for my KW, FL to PB, AK Iron Butt Ryde (don't think anyone's done that on a Spyder yet). I still use my Dash Mount over the dash mount to this day on my '18 RTL.
    Thank-you, thank-you, thank-you for your contributions and support of the Spyder community. Blessing on your future endeavors.
    Safe Rides,
    IBA 70020
    Feb 2013
    Poplar Bluff, MO
    Thank you for the kind words. I actually "think" I have one Dual Fill left in stock. I doubt you can find the quick release on Amazon but I can look for the part numbers. I just checked my web site and it shows none in stock so I have to look on the shelf and update the web site.
    Baja Ron did mention he was going to start producing some of my other inventions but didn't say which one. I'm happy to share any cad drawings or BOM's of the things I invented.
    JT
    Feb 2013
    Poplar Bluff, MO
    @ DGoebel I looked and I sold the DF-3 but I have enough parts to make a DF-1 if your friend want one of those. I also have two extra quick disconnects...
    JT
    Here's how I made mine: https://www.spyderlovers.com/forums/...ight=dual+fill
    Feb 2013
    Poplar Bluff, MO
    Pretty cool, the link to the air chuck is broken for me
    JT
    Quote Originally Posted by jthornton View Post
    JT
    Hmmm, wonder why. Go to www.napaonline.com and search for part # NTH 90455.
    Feb 2013
    Poplar Bluff, MO
    Wow napaonline.com seems to be down, maybe that's the issue with the link.
    JT
    Must be a firewall issue, or something of the sort. Both links work for me.
    Feb 2022
    New Zealand
    Just tried the link after I swapped to a US server. Loaded right away.
    Feb 2013
    Poplar Bluff, MO
    Must have been a momentary glitch at NAPA it loads fine for me now. I have no firewalls just a shotgun. Wow NAPA is proud of them, IIRC I paid $12 at Fastenal but that was a while ago.
    JT
    The reason I like using them is you just push it on. To remove you push & hold the hose toward the valve and then just grasp the sleeve and pull. No locking levers to mess with!
    Feb 2013
    Poplar Bluff, MO
    It's the only schrader chuck that can be dismounted without losing air and I tried them all. The clip on chucks were the worst and not repeatable at all.
    JT
    Feb 2013
    Poplar Bluff, MO
    The transfer to Baja Ron is in progress. I really enjoyed the ride here and I'm glad someone will take over spyderstore.com
    JT
    JT
    You will be missed, JT. I hope I can fill you shoes!
    Feb 2012
    Spring City,Utah
    sorry to see you go. Your insight on Spyder repairs has been valuable
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2013
    Poplar Bluff, MO
    I'm sure you'll do fine.
    JT
    Feb 2013
    Poplar Bluff, MO
    The transfer has gone through but I don't see a web page... at least put up an index.html saying work in progress.
    JT
