Any Hints to make New Battery Installation easier? 2016 RT
So, I'm putting in a new battery on my 2016 RT-L. Any hints to make it easier? I don't like to sweat.
Thanks in advance.
~Sandee~
2016 RT-L (Purchased used in February 2018)
RT Dash Mount (from JT's Spyder Store)
Kuryakin Trident Highway Pegs
Hopnel Pouch
Magic Mirrors
Spyderpops Foam Handgrips
Iron Butt #35273
Girls on Spyders #2779
Ozzie Ozzie Ozzie
Test fit the terminals and the top 'hold down' bracket onto the top of the new battery with both outside the trunk, and do any necessary cleaning of terminals, mods etc, especially any necessary to make the bracket hold the battery securely, BEFORE you start putting anything back into the frunk!
Then fit that bracket into its slots in the frame above & behind the battery and use some duct tape/100mph tape to tape it AND the battery leads up out of the way before you try to fit the new battery into the hole. Once the new battery is in, it'll be easy enough to pull the tape off & drop the bracket into place on the top of the battery, then secure it, and fit the battery leads/terminals. ![thumbup](images/smilies/thumbup.gif)
If you haven't already, don't forget to add star washers to the terminal nuts so that once tightened properly, they won't ever work loose again; and once it's all connected up again, just stick a socket on a long extension in behind the LH Wheel and make sure that the other end of the Earth Lead is firmly attached onto the end of the cable and tightened down onto a clean, rust-free section of the frame. That lead & the Earth it makes is essential to the proper operation of the DPS (electric Dynamic Power Steering) and the movement of the lead that invariably happens whenever you're removing/replacing the battery can loosen it/pull the cable out of its earth terminal fitting, resulting in either the DPS not working at all (Limp Mode results) or before Limp Mode kicks in, some really hairy moments as the DPS cuts in and out while you're riding along &/or half-way thru a really tight corner with oncoming traffic!! Do you really need to ask me how I know about that little heart stopper??
Oh, and DO make sure that YOU fully charge your new battery before installing it! Unless you REALLY TRUST the battery retailer, it's best to believe that it HASN'T been fully charged by them, and if you install it before giving it a good 8 hours or so on a proper multi-stage battery charger (& NOT just sticking it on a battery tender or cheap trickle charger! ) then make sure you practice and record everything you do while re-installing the 'new' battery this time around, cos without that good pre-installation charge, the chances are that you'll be replacing the battery again a whole lot sooner than should be necessary! So YOU should charge it properly FIRST! ![Lecturef Smilie](images/smilies/lecturef_smilie.gif)
Enjoy!
![Quote](images/misc/quote_icon.png) Originally Posted by sandeejs
find a MALE!!!!
![](https://www.spyderlovers.com/forums/maps/map.png?states=NC.CO.ID.MT.WY.SD.KS.UT.MO.NE.IA.IL.TN.SC.KY.VA.WV.PA.NY.ME.NH.VT.MA.CT.NJ.MD.DE)
A small bright LED flashlight is useful to see where the holdown bracket tangs fit into the frame slots.
that....
is a brand new gem for me. Thanks Peter.
If I remember right it in the frunk, that gets as easy as it gets, if you don't think so come take mine out and put it back in!! Just went through that deal last week! P.S Star washers!!!
Put the new battery on a tender for a day or so before installing. Check YouTube for videos.
Only 4 , easy to access, bolts to remove the trunk LID. A folded towel over the front, and you've got easier access to the battery opening. BRP couldn't have made the battery opening 1/2" bigger----------
Lew L
2014 RTS in Circuit Yellow, farkle-ing addiction down to once every few months. ECU FLASH IS GREAT. ![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.CA.ID.MT.NV.OR.SD.UT.WY)
![Quote](images/misc/quote_icon.png) Originally Posted by Lew L
Only 4 , easy to access, bolts to remove the trunk LID. A folded towel over the front, and you've got easier access to the battery opening. BRP couldn't have made the battery opening 1/2" bigger----------��
Lew L
After the first time I had to Remove a battery, now before I put the new one in, I wrap some nylon cord around it to use as a PULL strap ...... It makes this chore lots easier .... good luck .....Mike
Reason: mkes thios ;-)
If you've ever replaced a headlight bulb then you know replacing the battery is a cakewalk.
![Quote](images/misc/quote_icon.png) Originally Posted by Woodaddict
find a MALE!!!!
I know it's sexist as can be, but that advice certainly makes repairs easier for MY wife!
Chip
2020 RTL
"Stella by Starlight"
WoodAddict and ChipVeres, my wife, the USAF Galaxy C-5 and Globemaster III C-17 crewchief and all her peers would just tsk, tsk, tsk you old misogynistic geezers Apparently you haven't been paying attention to the advancements in the world lately. Though I've wrenched on vehicles since the early 70's, I still ask Sharon to fix somethings that my big meaty paws can't easily fit in.
Have you guys never heard of Ryker Rydes ( rykerrydes.com ) or others like Ryker Chick (who does most of her own maintenance though does ask her hubby to be an extra set of hands) Both have thousands of subscribers on their Youtube channels. I've had plenty of "males" ask me to work on their spyders, just because they didn't have the tools, inclination, or desire to wrench themselves, SandeeJS sounds like she does.
FYI, SandeeJS's IronButt # tells me she's likely more than capable, even though she's just asking for suggestions to do it herself.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.MN.ND.SD.IA.NE.WI.MI.MO.IL.IN.OH.KY.AR.TN.MS.AL.FL.GA.NC.KS) |
![Quote](images/misc/quote_icon.png) Originally Posted by DGoebel
Couldn't agree more. Some Blokes need dragging into the 80's. ![Big Grin](images/smilies/biggrin.png)
One of the best bike Mechanics or Techs these days I guess I know is a Chick and would leave most Blokes in her dust, riding or wrenching.
Me included, and I have been wrenching since the late 70's. Mentored by a Mechanical Engineer and into bikes.
Not surprisingly, I'm into torques as I was encouraged not to take shortcuts where possible.
My favorite tools are an inch pound wrench, 6-point sockets, and a digital micrometer.
Reason: im ... ;-)
![Quote](images/misc/quote_icon.png) Originally Posted by Isopedella
Couldn't agree more. ![clap](images/smilies/clap2.gif) Some Blokes need dragging into the 80's.
I stand by my original statement. No matter how skillful, experienced or licensed the lady is, it's still easier to point at the problem and say "Fix this, Charles". Not necessarily better, just easier.
Chip
2020 RTL
Thanks in advance.
So how ya going with this?
This is my F3 battery in situ if it helps.
Under the frunk liner, totally guessing but suspect yours is similar with the a 2016 RT-L.
Had to hold my mouth right and wriggle the retaining bracket into position from memory.
So, I looked at old records and saw the current battery was only about a year old. Spyder started right up and demanded battery fluid. I will wait on the battery replacement.
For those that don't stalk me, I suffered an injury to my left leg - peroneol nerve - causing "drop foot". This in turn resulted in a minor car accident and left me scared to drive my truck.
On the Spyder, it's difficult to confuse the brake with the throttle. So, with the addition of nice highway pegs from Lamont, I will be mobile again!
Thank all of you who offered hints. I will save them for next time.
Reason: for.next ... ;-)
~Sandee~
Hopnel Pouch
Magic Mirrors
Iron Butt #35273
