F3 Foot Peg Bracket - are the holes threaded, or just the brass plate?
Are the two holes also threaded, or is it just the brass plate? Unfortunately, I didn't know these bolts needed to be heated before removal and they stripped. So, I drilled out one and tried to use an extractor on it, and it broke off inside of it.
Reason: Expanded title to briefly ask the question/s... ;-)
I figured it out. They are not threaded.
Look at a parts diagram on the web, help you figure it out. Dealer can get replacement parts not super expensive.
Vince F in Niagara Falls
2022 Spyder F3 Special Edition
2020 Ryker Rally, sold
![](https://www.spyderlovers.com/forums/maps/map.png?states=NY)
2022 F3S , Stock Lamonster black diamond Monolith Black Satin
Even with plenty of heat they are stupid easy to strip. Don't ask me how I know
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
![](https://www.spyderlovers.com/forums/maps/map.png?states=NJ.NY.CT.MA.VT.PA.MD.DE.VA.WV.NC.TN.KY.OH.IN.IL.MO.AR,NH)
Mine had half bucket of yellow Locktite on them.
I was able to drill them. Which allowed me to move the pegs to position 5 and install my new floorboards.
