Results 1 to 12 of 12
    Jun 2015
    Ritzville, Wa
    Default Air Hawk seat didn't do it for me.
    Having found the stock seat on my 2018 RTL to be less then comfy I thought I'd take a run at the Air Hawk Cruiser Large seat. Well after following the instructions to a tee, I found the seat to really be no better then the stock one I have. At least for me that is. So I'll be sending it back. I might give the Ultimate seat a closer examination to see if perhaps it doesn't fit my needs. But that is a pretty big cash lay out if it's doesn't work either.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Just a FYI...you should be inflating the Airhawk so that you sit IN it and not ON it. Partially inflated is the "sweet spot." Yours may vary. Keep letting a little air out until you find the "sweet spot." Way less expensive than a $500 plus aftermarket seat.
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Agree.. it only takes a puff to cush the tush.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    Harrington, Australia
    The Airhawk works by squeezing air out to the edges to provide under thigh support, Greg. Your backside should basically be touching the seat in the centre……and please accept my apologies if you have already tried this….it just an fyi.
    P.s. the Airhawk didn’t do it for me, either.
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    When I first got my air hawk I had it way overinflated. Took most of the air out by trail and error. Works pretty good now. Just got to fiddle with it.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
    Mar 2015
    forrest above Reno, Nv
    Both my wife and I have air hawk seat pads. They work just fine, so well that I take mine off to put on the poor, old, slow V-Max with a Corbin saddle. No monkey butt, but we are both ready to stretch our legs after 100 to 150 miles or so which is when I gas up anyways.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member USAF's Avatar
    Aug 2022
    NY
    I have to mirror the comments about on having to much air is not good. This was the same for me, I had to let almost all the air out and then I found it to be very comfortable ! It seems like its flat when I put it on, but it is where it works best !
    2022 Spyder RTL
    Oct 2011
    Kalamazoo, Mi
    I hope you can stick with the Air Hawk, if you can't give serious consideration to either a Seth LLam seat or a russell daylong. Both are good seats, Seth's will be about half price of a Russell seat.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Active Member Two2Three's Avatar
    Mar 2023
    Missouri
    FWIW, if you want to try something else, I really like the ButtBuffer cushion.
    https://buttbuffer.com/
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Quote Originally Posted by Two2Three View Post
    I'm going to try a buttbuffer.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
    Faribault, MN
    What size did you get for what bike, did you get one for a passenger seat as well?
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2023
    Tennessee
    I just got mine today. Haven't tried it out yet.
    I got the large with the USCG Emblem for my 22 F3s. I did not purchase a pillion pad.
    Last edited by Peter Aawen; 08-24-2023 at 09:18 PM. Reason: Fixed attach display ;-)
