Results 1 to 15 of 15
    Nov 2016
    Madison, NC
    Default 2022 Aluma EX7712H BT
    2022 Executive Series 12' Aluma with Bi-fold tail gate. It has been stored out of the weather since new. The only time used was hauling the Spyder to the dealer for service a couple of times. The Executive Series has some nice features including interior lights and fender steps. The added front rock guard, wheel chocks set up for Spyder help protect it. Tie down points front and rear make securing it easy. The bifold tailgate is a foot longer than the regular tailgate and it reduces wind drag. Free and clear title. $3900.00.
    2020 RTL , Asphalt Gray
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Hey quick question re loading this trailer....do you have to tilt it up using the front jack wheel to avoid high point issues loading RTL ?
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    Nov 2016
    Madison, NC
    I have not had to raise the front when loading. Also I just changed the price.
    Very Active Member al0vely's Avatar
    Apr 2016
    Indiana
    What is the weight of the trailer?
    Does it have brakes?
    Love my Spyders
    2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
    2014 RTS Circuit Yellow purchased 3/2/2018
    2020 RTL Petrol Blue purchased 1/27/2023
    Girls on Spyders #3195
    No more 2 wheels
    2020 RTL , Lamonster floor board riser Petrol Blue
    Nov 2016
    Madison, NC
    It is approximately 650-700#. I can give you exact when I get back home in a little while. It does not have brakes.
    Nov 2016
    Madison, NC
    Shipping weight is 715#.
    Nov 2016
    Madison, NC
    bump.
    INDIANA, USA
    If you have a real truck and it's able to pull 3000 lbs ....you should not need trailer brakes. .
    But brakes can be installed for about $1500 to $2000. That's what my trailer man quoted me.
    The Spyder and trailer are less than 3000 lbs.
    Stay Safe and Enjoy your Day. ....
    ENJOY YOUR LIFE WITH A SPYDER
    Apr 2016
    Indiana
    Quote Originally Posted by Little Blue View Post
    Little blue - Everyone doesn’t tow with a truck!
    We have a heavy steel landscape trailer that is towed with a Ford F150 4x4 with a Spyder.
    However I am planning to tow with an SUV that has different towing capabilities with and without brakes. Obviously my questions are asked specific to my situation.
    Love my Spyders
    No more 2 wheels
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    Brakes can be installed on that trailer for less that $300 if you can wrench some. The brake drums and actuators were $240 last year on Ebay. Wiring was @$25.
    I installed them on my 7712 that I just repossessed.
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    FOBO 2, Trunk rack, Afterburnerz taillights
    Drinks2go cup holder, replaced the seat strut
    Garmin Drive Smart 71 GPS, Large brake pedal
    White pulley, Pedal Commander, Trunk Strut
    Laminar Lip wind deflector, side windshield wind deflectors
    Home made belt guard, Shorty antenna
    Show chrome wide windshield, Belt dampener
    Top cuffs and Mirrors
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    Please read and follow the directions in the '**** READ FIRST! How to use.... ' Sticky at the top of the For Sale by Owner sub-forum and linked below:
    https://www.spyderlovers.com/forums/...sub-forum-****
    There's info in there not only for those who START these Ads/threads, but also for people who might want to reply in them.
    Jul 2023
    Georgia
    Default Connector
    Quote Originally Posted by Westryder View Post
    Is the trailer connecting harness a flat 4 pin or round 7 pin connector.
    Nov 2016
    Madison, NC
    It came with a flat 4 but I changed it to 7 pin round to keep from using an adapter.
    Apr 2016
    Indiana
    Quote Originally Posted by Deana View Post
    That was a good and relevant question I hadn’t thought of since 4 flat is standard.
    Love my Spyders
    No more 2 wheels
    Nov 2022
    Georgia USA
    Quote Originally Posted by al0vely View Post
    Yep many SUVs would need swapping to an onboard 7 pin to use this. My 2020 Toyota Highlander is 4 pin only for example.
    Curt sells a 4 pin to 7 pin trailer adapter available thru e-trailer for ~$38...Dont know how difficult the install would be as the pic does show the 4 pin flat plus a few other wires on the SUV side. Trailer side is 7 pin so all good there. I guess if you did not need brakes then the 4 flat to 7 pin would work IF the wiring is correct.
