Results 1 to 17 of 17
    Sep 2019
    illinois
    Default Are you a Sea-Foam User?
    I'm wondering if any of you Ryker Riders add Sea-Foam, or the like, to you fuel tank on a once in a while occasion, as a preventative maintenance/performance booster. If you do how often?
    Very Active Member Tslepebull's Avatar
    Dec 2018
    East Texas
    Not Sea Foam but Berrymans B-12; its cheaper. I run a batch through on the last tank before an oil change.
    2019 Ryler Rally , Shock Yellow
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    My in-laws have a Ryker and I suggested they run 1oz per gallon in the Spring. (or anytime you get a tank of bad gas) I do this to all my small engines and auto engines during Spring tune-up time.
    Joe
    2023 F3
    Nov 2019
    Central Oregon
    I use it in all the carbon-based fuel vehicles and tools I own.
    I know it's snake oil, but it has cleaned up more than one engine, mine and friends' who became believers after trying it.
    I add, I dunno, 4 fluid ounces (118 cc) roughly every third fill. I fill the tank when it's no lower than 1/4 left on the gauge.
    Lawnmower get some with every fill.
    2015 ST Limited; Givi E52 Top Case; Baja Ron anti-sway bar; Cal Sci wind screen; Vredestein Quatracs (Front).
    Jun 2023
    Ontario
    I use it in my oil just before a change and find great results but I found it harsh in the fuel (only my opinion)
    May 2017
    Mesa, Arid-Zone-A
    I add it to the fuel just before filling up and putting the trike away for the season. It seems to help preserve the fuel when the trike sits for 3 or 4 months. One thing to note.... It is not the best product for cleaning injectors if you encounter that problem. Sea Foam does not contain P.E.A. which is considered a superior injector cleaner.....
    Semper Fi
    There are several good fuel additives out there, and some that are not so good. SeaFoam is one of the ones we use. We also use Berriman B-12 and a few others, depending on what we are trying to accomplish.
    Bossier LoUiSiAna
    Ethanol free primarily & occasionally maybe (maybe colder weather)something else depending what’s on hand -Star Tron, Berryman. Stabil marine for mower & small engines hibernation. & only before filling whatever tank (so gets mixed in proper) FFF7D1EE-F70D-4339-8C1E-190538A56431.jpg
    Sep 2018
    Australia
    Methylated spirits if I suspect water in the fuel.
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    wouldn't use anything else. With the crappy gas out there these days and including the non-ethanol gas I always put in my 22 RTL here at home, I put Sea Foam in the tank every 3-4 tank full, and I always try to run my bike until it is on fumes unless I am on a trip.
    2022 RT Limited , Silver w/ Black and Purple accents
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    Stabil only on the last fill before putting away for the winter. Never have a need for additives any other time.
    The Journey IS the Destination
    2016 F3-T , Intense Red Pearl
    Aug 2019
    Stoughton, WI
    I use Seafoam 2x a year. At winter storage, and again before a mid season long distance trip.
    2022 RT Sea To Sky
    Dec 2019
    Land of Lincoln
    SeaFoam MSDS is a mystery.
    Less than 95% blend of hydrocarbons with no CAS number.
    Less than 25% isopropanol.
    Rumor always was it was pale oil with alcohol mixed in.
    Hard pass for me, nothing in there of any benefit for the 7.00 can.
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    This YouTuber (Project Farm) has tried some interesting experiments with Seafoam. This one is from a few years back and he has a series of different videos specifically on the Seafoam product. He does all kinds of product comparison videos and certainly appears to be completely unbiased when doing his testing scenarios.
    https://www.youtube.com/watch?v=agAWXnT4-EQ
    2020 RT Limited - Chalk Metallic Dark
    May 2017
    Mesa, Arid-Zone-A
    Quote Originally Posted by kroache View Post
    Interesting video. Reminded me that back in the 60s there was a product named Carb-Out. It was dumped down the carburetor while the engine was running at a fast idle. Then left to sit for a period of time with the engine off. After restarting and driving around the neighborhood it produced a BIG cloud of white smoke for a few miles.
    Semper Fi
    Very Active Member Markubis's Avatar
    Jan 2018
    NH
    Great, now you me bringing back memories of using Marvel Mystery Oil. I remember using it on older engines to clean out sludge but it has a bunch of other supposed uses.
    https://marvelmysteryoil.com/
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    A guy I knew poured automatic transmission fluid down the carb, almost to the point of choking the engine. Significant smoke!
    I fill up the bike with non-ethanol fuel at end of season and add Seafoam to the tank.
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
