Results 1 to 8 of 8
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    Default Any videos showing 2020+ RT front trunk removal?
    I'll just say it - I'm an idiot. I took a 3000 mile trip on my 2022 RT-L from Phoenix to Cody, WY and the radiators are full of deceased insect life and vegetation. I have purchased protective grills for the future, but would like to clean the radiators and grill areas really well before I install them. I haven't been able to find a video showing the process of removing the front trunk. Does anyone know if such a video exists? I can find videos for older models, but nothing for the current (2020+) model.
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
    Aug 2023
    PA
    Here is a link to MartinTheVlogger
    He is adding lights to the frunk and explains how to remove the area in question.
    https://www.youtube.com/watch?v=UoomRqn2n6U
    Nov 2022
    Gilbert, AZ
    Wow, that's exactly what I was looking for. Couldn't find it on Youtube, didn't think to check Martin's site. Thanks a lot!
    Scott (slhanks004)
    Gilbert, AZ USA
    • Pedal commander
    • Baja Ron sway bar
    • Corbin seat
    • Garmin Zumo XT
    • IPS highway pegs
    Danbury Connecticut
    Quote Originally Posted by slhanks004 View Post
    I used a combination of wet vac and hose to clean the radiators before I put on the radiator guards.
    If you turn the handlebars to full stop, first one way and then the other, you can access the back of the radiator from the wheel well and reverse flush with a hose.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Nov 2022
    Gilbert, AZ
    Hi,
    I have a need to remove the front trunk ("frunk") on my 2022 RTL. I thought I had seen a how-to video a few months back, but I can't find it now. Does anyone have a link to a video that shows how to remove the frunk on a 2020+ RT?
    Thanks and Happy Thanksgiving!
    Last edited by Peter Aawen; 11-22-2023 at 06:37 PM. Reason: Moved Post title into text after merging new thread into old thread that had the answer already! ;-)
    Scott (slhanks004)
    Gilbert, AZ USA
    • Pedal commander
    • Baja Ron sway bar
    • Corbin seat
    • Garmin Zumo XT
    • IPS highway pegs
    Nov 2015
    Chardon, OH
    The link is in this thread from when you started asking this, back in August. You haven’t got the bugs out yet?
    Last edited by Peter Aawen; 11-22-2023 at 06:39 PM. Reason: merged threads, so it's THIS thread now. ;-)
    Doug
    ”Freedom is not a loophole”
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    There is a video out there, I used a video on how to install the signature lights. There are 2 bolts to remove on the bottom and a few on the top, you will have to remove the cable that opens the Frunk - the whole front comes off. It was not hard; you just have to remember what screws go where. (There are quite a lot of screws!)
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
    Sep 2012
    Stetson, Maine
    In Martins video he removes the frunk lid and latch assembly. I did not remove lid or latch assembly. You still have to remove cable. My 2021 is alittle easier than my 2011 was. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
