Results 1 to 13 of 13
    Member Podhouse's Avatar
    May 2021
    Pennsylvania
    Default Double vision display on 2020+ Spyder - anyone else seen/had this?
    I had a display problem on my 2021 F3 limited today. After a short ride for lunch, I returned to the bike and turned the key on. Both displays had blurry double images a half inch beside each other on them. I repeated turning the bike off and on a few times with no change. Being about 5 miles away from the dealer I drove there. The display stayed that way all the way there. The technician came out to check it out. AND as we all know the display worked perfectly. He checked for error codes and there was none. He said, just keep an eye on it. Luckily no diagnostic fee. Has anyone else had this issue? Thanks in advance.
    2021 Limited , Brake pedal widened Glacial Blue Metallic
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    I have read about a few others having the same issue on some Facebook groups. No real ideas or solutions as of yet.
    Joe
    2023 F3
    Jan 2022
    North Dakota
    My 21 RTL did that twice a year ago. turning off and waiting about 5 minutes cleared it up. I took a picture, but it has not occurred again.
    2021 RTL , Asphalt Gray
    May 2021
    Pennsylvania
    Thanks, yeah the couple minutes waiting for the technician with it off must have reset it and it didn't dawn on my to take a picture. I was mostly in shock and it stayed on after cycling the key off and on prior. Fortunately I haven't had any issuses with the bike prior.
    Vermont
    Quote Originally Posted by Podhouse View Post
    Podhouse,
    I had this happen to me today, I have 2023 F3 LTD Special Series. I started a thread.
    Here is the thread:https://www.spyderlovers.com/forums/...37#post1682137
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Oct 2015
    Laurel, Mississippi
    Double Vision Dash - I had this happen once on our 2022 F3 Limited a little over a month ago. It occurred when we first started the bike for a ride and stayed that way until we stopped for gas. After the gas stop it cleared as soon as the Spyder started and has not happened again. I did get some photos of the dash and hope I have them uploaded correctly.
    Lee
    Last edited by Peter Aawen; 08-14-2023 at 03:34 PM. Reason: Removed post title - many only see main thread title, & post titles mess with searching!
    Lee & Karen
    2022 F3 Limited - Matte Black
    F4 Customs Windshield, Lamonster Driver Backrest,
    Lamonster Fog Lights, Wrap My SPYDER Tank Protector,
    Lumina Trailer
    Aug 2018
    Piperton, TN
    I had it happen just once on my 21 RT Limited. Turned off and then back on, gone.
    May 2013
    Gladys, VA
    Looks to be a screen software load up issue. Maybe a futrue software update from BRP will solve it.
    Joe
    2023 F3
    May 2021
    Pennsylvania
    Yeah, that is what my dash looked like to, it also self corrected. Hopefully just an occasional gremlin. Thanks for the for the info on the other thread also. I will check it out.
    Vermont
    Podhouse,
    It just happened to me this past weekend.
    I have a 2023 F3 LTD Special Series.
    I started a thread about the problem. Take a look at my thread. it has all of the details about what happened.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Mar 2021
    Maryland
    It looks like heat issues with the inverter for the display, which would explain the "reset" after it is turned off and it gets a chance to cool down.
    2020 F3 SE6
    2020 F3 , Black
    How hot was it where your Spyder was? 2017 and earlier displays would blank out when they got hot. Best use of the safety card was to shade the display from the sun. Maybe the 2018+ get double vision when they get hot.
    Mar 2021
    Maryland
    Usually heat is the culprit when it comes to lcd's but a loose connector or ribbon on the display can be an issue as well when it comes to "double vision".
    2020 F3 SE6
    2020 F3 , Black
Tags for this Thread
