Results 1 to 12 of 12
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    Default Are there any Better Floor boards for 2019 RT's?
    Having bought a new 2023 Sea to Sky 2 weeks ago, we are realizing the floor boards are much bigger and the riding position is just so much better. You def have more room forward on the floor boards...
    Is there any thing that can be bolted on , swapped out etc to help the 2019 RTL? There is very little room forward, but was hoping someone has been there done that ....
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    Quote Originally Posted by WRCLVR View Post
    You have the same set-up as my 14 RT, I made some from 3/16 alumin. diamond plate. bolted them to the stock pegs and the bolt that is just forward of the passenger boards ..... Mike
    Nov 2022
    Georgia USA
    Did you do a writeup on it Mike? If so could you post back a link, please
    Appreciate it sir !!
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    I have a 17RTL which is just like yours. I have the floating foot pegs from Canamspyderacessories.com
    They allow me to stretch out my legs more and are easy to install. I m 5ft 9” tall with a 32 in inseam
    I hope this helps you out.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Nov 2022
    Georgia USA
    Thanks !! I found the link and already watched the video :-)
    Kinda pricey though ....
    Sorry but I can't remember exactly when I posted on this ..... it was 2014 or 15 ...... Mike
    Nov 2022
    Georgia USA
    So on my 2019 RTL, there are 2 small black plastic parts sitting just on front of the drivers floorboards, one on either side of the bike. I think they are part of the lower bike cover. You can see them in my pic in my sig. Resting your feet on those lightly gives you about 3 inches more room.
    Just wondering if i can make some aluminium floor boards that then extend sideways 4-6 inches and then angle up and forward 6 inches to allow even more room. I think 1/8 " diamond aluminium plate would work and be stiff enough if they match the OEM floor board.
    Any ideas on this ... Watcha think?
    PS our 2023 S2S has waaay more room and allows enough room to stretch out the legs...which is what im after. Really dont like the 2019 RTL driving position with the "jockey" type position.
    Oct 2020
    Arizona
    Older thread, but still - remember that the righthand floorboard has a break-away/drop down feature for heavy braking, which should not be impeded. I have two sets (different styles) of highway pegs, it anyone needs a set. Here is a picture showing the best highway pegs.
    Jan 2024
    Texas
    Quote Originally Posted by Snoking1127 View Post
    Which ones are those -- where to buy?
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO T1 Front/Rear Dash Cam system
    Oct 2020
    Arizona
    Quote Originally Posted by Allen42 View Post
    I do not know the brand, as they were on the Spyder when I purchased it. Make me an offer and pay the shipping.
    These attach to the body of the Spyder not the running boards. Which is very good in my mind.
    I have a set of ones that mount to the running boards, and I modified the right one to fold back if the running board had to do it's breakaway thing. They are available also.
    Oct 2020
    Arizona
    OK I found the kit and the installation instructions are on the site also. Hundred bucks plus shipping. https://www.lamonstergarage.com/can-...brackets-pegs/
    Jan 2024
    Texas
    I PMed you.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
