Results 1 to 8 of 8
    Active Member FINFAN3DP's Avatar
    Jun 2018
    HAYMARKET,VA
    Default Anyone use a snowmobile trailer to haul their 2020 RT Limited?
    2020 Can Am Spyder RT Limited "The Comet #2"
    Baja Ron Sway Bar
    Passenger Armrests From Can Am
    Wolo Big Bad Max Airhorn
    Lamonster Top Cuff W/Ram Ball
    Lamonster Power Plate
    Tackform Phone Mount
    Key Cover from Ebay
    Lamonster Mirror Locks
    Ultragard Cover from Lamonster
    Top Grills from Spyderpops
    Garage Door Opener from Spyderpops
    3.5mm Extension from Amazon
    Lamonster USB Cable Holder & Cable
    Foam Grips from Spyderpops
    Tricled Strobe Brake Light module
    Tricled Bag Lights (replace reflectors)
    Tricled Turn/Brake/Run Signals Rear
    Tricled Floorboard Lights
    Tricled Sequential Run/Turn Fender Lights
    Tricled A-Frame Run/Turn Lights
    Tricled LED American Flag Mount & Flag
    Showchrome American Flag
    2020 RT Limited , Says Chalk White, but in person it is much more gray
    Northern Kalifornia
    No, but we used a motorcycle trailer recently to move a snowmobile.
    Feb 2012
    Spring City,Utah
    Ha ha ha ha.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Feb 2012
    Spring City,Utah
    I actually do have an old snowmobile trailer I use sometimes to haul my Spyder. I also use it to haul my S X S. The bed tilts so I can just drive them up it until it drops back down. It has never hauled a snowmobile since I have owned it.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Aug 2022
    EASTPOINTE, MICHIGAN
    yes tow my 2022 RT everywhere ...tie it down with the Erickson etrack and stops ... I used 12x8ft x 2" plank boards for ramps. and a 12" HIGH box made so trailer doesn't tilt to the ground gives a good angle to load. I store my straps etc.. in the box
    I had an aluminum oversize (8' 6" wide 10 ft. long) one left over from my snow-mobiling days. that I narrowed down to 6 ft. ...... did the same to the torsion axle ...... the entire frame tilts but it still needs boards. ..... Mike
    Jun 2018
    HAYMARKET,VA
    Paul,
    Did you have any problem with the front scraping when the bed is tilted?
    Baja Ron Sway Bar
    Key Cover from Ebay
    Feb 2012
    Spring City,Utah
    Not on this, but your mileage may be diffrent. I do prop the tongue up a little to get gentler slope.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
