Has anyone done their own Rear Tire change? How difficult?
has anyone changed their own rear tire? how difficult is it
Reason: Expanded title to briefly ask the question/s... ;-)
Changed a tire on what year?
I have changed all the tires on F3-S 2019, changed tires many times on Harley Sportsters. Changed them on Honda and Yamaha sport bikes.
None of it is really difficult if you can use tools. Helps to have the service manual for whatever you are working on.
If you want good information, you have to provide year and model of whatever you are working on.
Its an almost impossible task without the gear to remove and refit a new tyre.
If you have the gear, well not so hard at all. Hint - something called Tyre Paste and pop them in the sun for a time before fitting.
I have removed my rear wheel and tire assembly and taken it to the local Tire shop to change the tire on the wheel. I did use a maintenance manual (not the Operators manual) and several Youtube videos to prepare for the job. I had to get a special open end wrench big enough but it is doable in your own garage, (tape on the swing arm end caps before loosening the rear axle).
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
Do you mean removing the rear wheel or the actual busting down of the tire from off the rim? Rear wheel removal is not hard just time consuming. Busting the tire free of the rim is real hard without the tools especially if you haven't done it before. It can be done depending on your tenacity, ingenuity, and a bit of muscle. After you get the wheel off take it to a regular tire shop and they should be able to mount your new tire for you.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
65 yr. old female, about an hour and a half to Remove/Replace. Bought tire at Discount tire, they mounted it and balanced. Much easier than working on a Harley....
Reason: then... ;-)
Thanks for the feed-back. I have had Harleys most of my life and stripped them down to the frame. Now at 73 years old I am ready to go to a Spyder. Thanks
Reason: striped ;-)
Biggest problem I had was getting the Spyder high enough in the air to wiggle the tire out from under the extended fender/mud flap on my 21 RTL.
2021 Spyder RTL chalk/black/chrome bought in March 21. Previous rides: 2019 Spyder RTL, Orange/chrome. 2015 Harley Heritage, 2002 Harley Heritage, 77 Harley Electra Glide, 75 Harley Electra Glide, 72 Harley Sportster (first bike bought new)
My Spyder Mods
Rider backrest, F&R cup holders; F3 handlebars; BRP LED driving light; LaMonster front fender and mirror turn signals, LaMonster Saddlebag lights, Auxito LED rear turn signal blubs w/ built in load resistor; Brake lite modulator/flasher; LaMonster flags on trunk; Garmin Zumo XT. LaMonster Bluetooth adapter for Phone & GPS through Spyder speakers. LaMonster floorboard risers; FOBO tire pressure monitors, Vredestein front and rear tires; BajaRon sway bar.
Good work.
I too will remove the wheel assembly and take it down for the rubber to be swapped out.
Good opportunity to have a squiz at the wheel bearings, brake caliper and stuff while im there I guess.
My GL1800 was easy for the rear tyre replacement as I had a spare rim.
Laid down on the bars. 5 nuts removed, swap out the rim and refit. Stand her up again.
Bout 15 minutes all up.
If you remove the rear shock bolt and the linkage arm for the ALS the swing arm will drop low enough for you to pull the wheel out.
Happy TRAils/NSD
Paul
2012 RT L
TRA
PGR
Venturers #78
TOI
Yup.
bit like this.
https://www.youtube.com/watch?v=juVK1ogc1BA
I have found that doing that is really not that important, the dog bone yes, unhook that so it don't break. Putting your floor jack as far back on the frame, back where it hooks on to exhaust and jacking it to the moon you have plenty of room to get it out.
tire swap technique with older 1-piece wheel hub style (ref 2015 RS)
I have a 2015 RS with one piece wheel hub. The local tire shop swapped out my old tire for my new Kuhmo Ecsta just fine, but could not balance the wheel assembly due to the hub depth. So, I was able to do a simple balance in my shop. Bought the stick-on 1/4 oz weights at local auto parts store for about $11 USD. Set up between 2 leveled chairs with electrical conduit shaft (see pic below).
Reason: Moved Post title into text - many won't see post titles, and they mess with Searching! ;-)
So.
It seems without the op identifying what bike they have as the rims seem to differ this thread is a waste of time.
opting out.
I removed both bolts, the issue was with getting the tire out from under the fender and mud flap.
My Spyder Mods
Ozzie Ozzie Ozzie
Originally Posted by Isopedella
So. It seems without the op identifying what bike they have as the rims seem to differ this thread is a waste of time.opting out.
Yes, it’s the age old issue of an OP not specifying the make and year, Iso……..and also the issue of responders not checking what the OP is riding before throwing any old model/year answer out there. This requirement has been mentioned so many times that members could not have missed it, and yet can’t be bothered. It is unbelievably frustrating, as it results in incorrect advice being given constantly, greatly lengthening threads and generally confusing the crap out of people. YES. IT FRUSTRATES THE CRAP OUT OF ME.
I’ll get back in my box now
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
Beads. That’s all I’m saying
~~2010 RS SE5 My first Spidey, but not my first ride~~
The trigger’s been pulled. We have to
get there before the hammer falls.
So.
opting out.
If you noticed in his information that it's a 2013 RT Limited.
SpyderLovers Sponsor
Old thread. And really, the year or model makes little difference when removing the rear tire. An RT with a trailer hitch and or large rear mud flap is a bigger hassle. But still not all that bad. In almost every case. If you can get the rear wheel off (not all that difficult if done correctly). Most tire shops will mount the tire for you. They will not be able to balance it. But most are fine with no balance at all (using a quality car tire and removing the existing weights). If you want balance there are 2 good (in my opinion) alternatives. Ride-On and Balancing Beads. You'll find supporters and nay-saysers for both. That's just life!
