Anyone know Manufacturer & Part No. for Vinyl Wrap to match 2014 Matte Silver?
I am seeking information about vinyl wrap material that closely matches the 2014 matte silver color. If anyone knows of a manufacturer and part number it would be very much appreciated.
Brian
Reason: Expanded title to briefly ask the question... ;-)
Ozzie Ozzie Ozzie
Have you thought of looking at Wrap My Spyder in our Supporting Vendors Forum:
https://www.spyderlovers.com/forums/...Wrap-My-Spyder
or checking out what Spyder Wraps Pete can do for you?? :dontlnow:
https://www.spyderlovers.com/forums/...der-Wraps-Pete
Or maybe posting in one of his threads in that forum area.... altho none of them really look all that specific to your question.
Or you could even look at his website:
http://www.wrapmyspyder.com/
Good Luck!
I did look at the vendor sites. I did not find the color I need. I want to wrap an enclosed trailer that I use to haul the trike now and then, to match the CanAm. My local "guy" has a very limited selection. His choices would be a big compromise. I will probably leave it white if I cannot find something closer.
Reason: ' 's ;-)
You're better off calling Pete at Wrap My Spyder. He might have a suggestion that you're not seeing on his website. FYI: Most Vendors on here are very receptive to phone calls.
I did look at the vendor sites. I did not find the color I need. I want to wrap an enclosed trailer that i use to haul the trike now and then, to match the CanAm. My local "guy" has a very limited selection. His choices would be a big compromise. I will probably leave it white if I cannot find some thing closer.
I have not found an exact match, but some of the silvers and aluminum come close
Look thru these. https://www.amazon.com/s?k=Vinyl+wra...f=nb_sb_noss_1
2014 RTL Platinum
Forum
RT Shop Talk
