Results 1 to 20 of 20
    Dec 2022
    NY
    Default What The Heck Is Going On With My Belt???
    Just noticed this today. Every. Single. Tooth. Has an abrasion. The picture makes it look like gouges, but it’s more like abrasion. But how is it EVERY tooth???
    Last edited by Peter Aawen; 06-01-2023 at 08:36 PM. Reason: Fixed attach display ;-)
    ~~2010 RS SE5 My first Spidey, but not my first ride~~
    The trigger’s been pulled. We have to
    get there before the hammer falls.
    Dec 2022
    NY
    Last edited by Peter Aawen; 06-01-2023 at 08:36 PM. Reason: Fixed attach display after merged duplicate threads ;-)
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Are the gouges on the inside or outside of the belt ??
    If it is on the inside, maybe the belt is partially riding on the flange.
    Can you take a pic of the sprocket too ??
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Sep 2019
    Reno, NV
    As the famous Yogi Berra once said,
    "This is like deja vu all over again".
    (See other duplicate post for my reply).
    2002 BMW 325i - his
    Dec 2020
    Hartwell, Ga
    Also check both sprockets all the way around for damage or debris lodged between the teeth.
    Jul 2015
    Dorr, michigan
    I had that on the belt on my 2015 and found a stone caught in the grove of the rear sprocket. I removed it and never had a problem with the belt for next 40,000 miles I owned it. That belt is still on the bike and working today with the new owner.
    2020 RT Limited , Petrol Blue
    Dec 2022
    NY
    It’s on the outside edge. Guess it’s time to pull the Tupperware . . .
    Clinton, MS
    Small rock caught in one of the sprockets. Probably not even there any more. At some point every belt tooth passes over every sprocket tooth and that is why it is all the way around.
    2019 RTL Phoenix Orange
    Dec 2022
    NY
    UPDATE . . . Found a hard blob of road tar stuck in the rear sprocket exactly in line with the marks on the belt. Knocked it out with a couple smacks with my hand on the end of a screwdriver.
    Feb 2022
    New Zealand
    Excellent. I will put that in the bank.
    Belt showing signs of getting munched.
    Check both sprockets all the way around for damage or debris lodged between the teeth.
    2017 F3 Ltd
    Mar 2023
    Sycamore, Ga. 31790
    Check both sprockets. You may have picked up a small pebble or some other type of debris that has stuck on the teeth of one of the sprockets.
    May 2017
    Mesa, Arid-Zone-A
    Glad you found the problem. And, don't worry about your belt. The damage is very minimal.... more cosmetic than anything else. Those belts are VERY tough.
    Semper Fi
    Sebring, FL
    How much play should there be in the belt when just pushing down on it? Should it be very tight, 1/4" or looser? Trying to get a general idea here.
    2020 RTL
    Durham,Maine
    2020 RTL
    Get yourself a Krikit II, and test it that way! 160-180 seems to be a good area to start at, with tire on the ground. Good luck
    2012 RTL , Pearl
    Feb 2022
    New Zealand
    2017 F3 Ltd
    Clinton, MS
    I liked the older versions that had a slit in the top of the rubber so it would hold on your finger and you could press straight in. On some applications that was the only way to use it without removing panels.
    Harrington, Australia
    2020 RTL
    BikerBill, not sure about play when you push on it, but a twist of 45-90 degrees seems a common measure.
    HeliBars Handlebars
    Kenda Kanine rear.
    But only if you do it in the middle of the longest free length of belt between the pulleys Pete.
    I've seen some complaining about still needing to loosen their belts cos they couldn't twist it much at all just ahead of the rear pulley, only even with my damaged hands I could twist it almost 180° further along in the middle of the chord!!
    Pushing it up or down often won't move it enough to give you an accurate indicator of tension, while twisting it up to 90° will; but you've really gotta try that twist thing in the right place, or it might not be a good indicator either!
    Ahhhhhh yes….good catch, Peter……thanks
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member mikthebik's Avatar
    May 2010
    Ramona, CA
    Just purchased a “new” 2018 RTL from a cousin who lives on a dirt drive. I’ve got the rear wheel off for tier replacement and noticed an almost identical mark on the belt. I have about 1/8 mile of gravel on my access road and always keep speed low on my “old” 2015 F3. As part of my upgrades to the RTL, I’m adding La Monster’s Missing Belt Guard. With my driveway and likely future Canada/AK trip(s) I’m betting that’s a wise addition.
    Spyder daily driver - 2015 F3S magnesium - grocery getter
    BajaRon swaybar, Shad sidecases and Givi top case with Admore kits, adjustable brake rod, LaMonster LED headlights, Stebel Nautilus, Zumo 396, FOBO TPMS, F4 Customs windscreen and bump skid
    Front Tires - 175/55R-15 Yokohama AVID S34FA SL
    Rear - General Altima RT45
    Spyder touring buddy (White-Whale) - 2018 RTL pearlescent white - set up for touring and local dates with SWMBO.
    LaMonster LED headlights, Stebel Nautilus, Zumo 396, Spyder cuff, FOBO TPMS, driver adjustable backrest, rear view mirror LED turn signals, and Eastern Beaver PC-8R fuse box. Baja Ron Ultra Sway Bar on the way.
    Front Tires - Stock Kendas
    Other motorcycle transport - 2010 Honda NT700VA Deauville and assorted vintage Japanese bikes
