04-23-2023, 10:16 AM
#376
Ordered the Can Am Comfort Seat, I'm not expecting a miracle but hoping for some improvement at least. It doesn't take long for butt burn to set in with that too soft stock seat.
My Ryker seems stable as can be on a smooth road at interstate speeds. With the cruise set at 80 I can turn loose of the bars with no drama other than a slow drift to the right. It's a little different story on our worn and patched rural roads, but I'm hardly noticing now that I've gotten in a few more miles. Taking tight fast curves with bumps and dips in the road can be a little unnerving though, it that where an upgraded sway bar and end links might be a benefit?
Sarah
04-24-2023, 08:20 AM
#377
Received the steering damper the other day so going to install that on this week. Also have some stickers to add.
2021 RT Base - Petrol Blue
04-24-2023, 11:16 PM
#378
04-28-2023, 02:22 PM
#379
2023 Ryker Rally - Heritage White III
Sport Windshield
GPS Holder
04-29-2023, 05:46 AM
#380
^^Congratulations StalkyTracker!
I ordered the saddlebag bracket from RykerLyft on FB. I've got some SKB cases I'm hoping to use, so we'll see. That plastic spoiler on the maxmount was a bear to remove, it pretty much had me so Doug just started wrestling with it and it finally popped out no worse for wear. Sort of like the nose piece did when I installed my radiator guard, I thought sure I'd break something pulling that thing off. The ins and outs of this plastic bodywork takes some getting used to.
Sarah
05-03-2023, 07:55 AM
#381
I got the wife what is referred to as tank trim for her rally with the name of her bike imprinted in it. I had to paint it the color of her accent trim (hot pink). I installed it yesteray. Looks really nice. I'll try and get a pic of it when the rain stops.
05-10-2023, 01:12 AM
#382
reached today 30.000 miles ..on roads like this !!
https://www.youtube.com/watch?v=p-tve0dK8QM
05-14-2023, 06:21 AM
#383
I installed the BajaRon sway bar and end links kit. Used a Dremel to cut the factory sway bar, worked well and wasn't too scary
Sarah
05-14-2023, 06:59 AM
#384
I installed the BRP Adventure windshield. Easy 20 minute job.
2021 Spyder RT Limited (Sea-To-Sky)
2022 Ryker Rally
05-15-2023, 06:19 AM
#385
Added a little more color match to the wife's Rally. Added 3D printed covers and some more color match to the top case and saddle bags. Also removed the can-am stickers on the air filter cover and replaced with the name of her bike in color match.
05-16-2023, 11:35 AM
#386
Called up BajaRon and talked to Paige, ordered the K&N air filter for the CVT side. Friendliest service ever, and much better price than the local parts places. It's amazing how much dirt you see on the CVT filter compared to the engine air filter.
Sarah
05-16-2023, 03:35 PM
#387
Haven't even got it home yet and just bought the Comfort seat, Comfort passenger seat and the folding backrest.
05-17-2023, 04:52 AM
#388
That's my set up too. I'm trying to find a bag that mounts on the back of the backrest and doubles as a solo rider backrest when folded down. Found a few but I'm not sure they would work.
05-19-2023, 06:14 PM
#389
I double checked the torque on the Rally wheels today. I had rotated the front wheels about three rides ago, and I changed the rear drive oil one ride ago of 70 miles. I put a scissor jack up level with the 8" extension resting on it while torquing the rear. That helps a lot. Then went for a 55 mile ride through three different County parks.
05-20-2023, 04:43 AM
#390
SKB cases on the RykerLyft bracket:
Bolted an aluminum plate on the back of the case, then bolted the case to the bracket. The rack behind the seat is one we happened to have on the shelf. Three bolts go through the rack, maxmount, and RykerLyft bracket.
Sarah
06-06-2023, 09:37 PM
#391
Put on carbon fiber upper and lower panels.
07-02-2023, 02:59 PM
#392
Installed M2 Shocks, yesterday
Have a plain old 2019 900 Ace, and upgraded the shocks to M2s from RPS. Took the dive and ordered a full set of shocks. Did the install on the fronts and took it for a spin... Wow, it's light years better than it was. Installed the rear a few hours later, but it jarred pretty bad over bumps. Marcus had reached out to me asking how the install went, so I answered. He immediately told me what adjustments to make to the rear shock and was spot on. Now the ride and handling are spectacular. I couldn't be any happier with both the product and the customer service.
Reason: Moved Post title into text - many only see Thread titles, and post titles mess with Searching! ;-)
07-09-2023, 06:17 AM
#393
Had a local hole-in-the-wall tire shop mount up a Hankook Ventus V2 on the rear rim. He charged $15, I gave him $20.
Sarah
07-12-2023, 12:33 PM
#394
Changed the oil and filter. Big, big thanks to Pantera for the toilet paper roll tip, worked perfectly.
Sarah
07-13-2023, 09:30 AM
#395
Brought it home on Tuesday.
After waiting over three months for road construction to get done I finally was able to pick up the Ryker.
A friend drove me down to get it.
Took some back paved roads with low traffic just to get used to three wheels.
Only went for a front brake a few times, had to laugh when I went to put a foot down at a stop.
Had to go back to the dealer on Wednesday, one key wasn't working, and the bars were off to the left. (Nice morning for a ride tho)
They (Lockhart's in Courtland Ontario) took it right in and had me out in twenty minutes.
They have been super to deal with.
Went and put close to a 100 miles on it on some main and back roads.
Got a big headlight flash and waves from a couple an a Spyder going the other way. (my first)
After not riding for almost two years, I feel a little beat up, in a good way.
Loving it, But the wife says I have to stop doing my Aerosmith impression.
"BACK IN THE SADDLE AGAIN"
Now if it will stop raining, I can go out some more.
Sorry for the long post.
Bruce
Reason: 100s mile...
07-13-2023, 08:55 PM
#396
Hi Bruce
I've also been off a bike for a couple of years. Picked up my new Rally a couple of weeks ago and was grinning like a loon under my helmet riding it home.
To keep on topic: I just got a Cardo Spirit HD comms for riding on the Rally, I'll be able to hear my GPS now, so no excuses for getting lost... again
Reason: Caps; ' 's; & ridding... ;-)
07-23-2023, 11:19 AM
#397
I didn't actually do it today but over the last few weeks and finally got a couple of pics:
Installed the Can-Am glove box organizer; helps a little, really like the piece that attaches to the glove box lid.
Installed the Hopnel tank bra.
Installed the Show Chrome handlebar end weights. I had some minor vibrations on the grips and these have eliminated it.
Installed the Providence Spyder Accessories water bottle holder. Works as advertised and comes with an adjustable bottle holder for my coffee thermos.
Installed the Can-Am knee pads.
Installed the Can-Am tank bag. It's small and not a lot of room for storing items but functions as advertised and doesn't interfere with gassing up.
Installed an Ultimate seat with backrest. Not completely broken in yet but way more comfortable than the Rally Comfort seat that came with the bike.
Sport Windshield
GPS Holder
07-23-2023, 08:49 PM
#398
Originally Posted by greer
...Taking tight fast curves with bumps and dips in the road can be a little unnerving though, it that where an upgraded sway bar and end links might be a benefit?
Sarah
Have you already upgraded to 400 mm shocks? Sorry if you already posted, but I now only lurk occasionally.
Not only longer, with increased ground clearance, but the full length springs are so much better.
https://www.amazon.com/GZYF-Motorcyc...00XVH4NVG?th=1
For my 2020, 400 mm was the max travel of the front suspension.
See post 13
https://www.spyderlovers.com/forums/...00#post1545853
09-02-2023, 03:59 PM
#399
Put the Can-Am Sport windshield on the other day.
WOW what a difference. On the Ryker I felt like I was going faster than I was, not now.
First ride I noticed a lot less wind buffeting, Looked down and found I was 30kph over the speed limit.
09-03-2023, 05:52 AM
#400
Originally Posted by SportsterDoc
Sorry I missed this SportsterDoc. Yes, I went with the 400 mm shocks first thing. Thanks again for posting the details, ordering was a piece of cake. We just returned from a 10,000 mile trip up through the Yukon and I am pleased as can be with the Ryker. And thanks again for the advice and suggestions early on.
Sarah
Sarah
Reason: forst
