Page 57 of 78 FirstFirst ... 74753545556575859606167 ... LastLast
Results 1,401 to 1,425 of 1927
  1. #1401
    Aug 2018
    Piperton, TN
    I am so sorry
  2. #1402
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I installed the new Pedal Box Pro from lamonstergarage but it got too late for me to try it out. Hopefully Friday since tomorrow is supposed to rain. I'm curious to see how much of a difference it makes.
    2021 RT Base - Petrol Blue
  3. #1403
    Aug 2020
    Niagara Falls NY
    Phone fast charger and volt meter working good. The blue display is hard to read in the sunlight but it's readable at a stop if needed.
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
  4. #1404
    Dec 2020
    Hartwell, Ga
    Ordered a NoCo NLP 20 battery as mine has bitten the dust.
  5. #1405
    Active Member Jesster72's Avatar
    Oct 2021
    IL
    Heading to my dealer tomorrow (5-19) for the brake switch recall, oil change and check up for the PA and SD trips this year. 80 degrees and sunny today at work - forecast tomorrow for the 85 mile ride to the shop -- 70 degrees and rain all day. If you're going to ride, sooner or later you're going to get wet.
    2022 Sea to Sky
  6. #1406
    Mar 2015
    forrest above Reno, Nv
    Removed foam grip covers I installed at the end of the last ryding season. Caused cramped hands. Made the grips to big I guess, stock grips are good now.
    2014 RTS , Circuit Yellow
  7. #1407
    Oct 2015
    Lynden, WA
    Picked my Spyder up from the dealer.
    Pulley recall completed.
    Finished fabricating my Handlebar mirrors.
    Installed the GPS and XM radio.
    I'm ready to ryde...
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  8. #1408
    Mar 2015
    Well then we should. I just did an oil and filter service on my , I'm ready to rock .
  9. #1409
    May 2023
    AZ
    ordered a few mods which will make me and it happy, lol
  10. #1410
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    I finished installing my lit painted panels
    Last edited by Peter Aawen; 05-19-2023 at 05:35 AM. Reason: Fixed attach display ;-)
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
  11. #1411
    Active Member RodO's Avatar
    Jul 2009
    Montréal, Canada
    Put on a Quad Lock for an iPhone using a 1" Ball Head + Double Socket Arm + 1” Ball Adaptor Mount + Motorcycle Vibration Dampener.
    It's bolted on the lower left of the OEM Garmin mount, so I've got the option of using either for navigation.
    Have used Garmin's and a SPOT tracker for many years but my preferred nav app might become Detecht.
    Ryde safe,
    Rod.
    '08 GS SM5 Full Moon -- after 15,000km sold May'11
    '10 RT A+C SE5 Full Moon -- after 30,700km traded in 2014
    '17 RTL Pearl White -- new-to-me in 2023
    "I guess its better to bend a valve in Missoula than to lose your mind in Bozeman", my wife said, patting my hand as if to console me. I winced and wondered if Phaedrus ever took the bus." -Peter Egan, Leanings
    CanAm Highway goes from Texas along U.S. Route 85 and Interstate 25 into Saskatchewan, Canada.<http://en.wikipedia.org/wiki/CanAm_Highway>
  12. #1412
    Oct 2015
    Lynden, WA
    Installed a LaMonster rear rack.
    Battled with the installation of a Cat Delete w/baffle.
    The three springs are a bugger. but yielded to my unrelenting determination to complete the job.
    Hey Lew and Crew, Once again I'm ready to Roll...
    David C
    2016 F3T
    Rear IPS Pack Rack
  13. #1413
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Installed the new M2 shocks
    Did a coolant change while I had the front off.
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
  14. #1414
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    Put New EBC brake pads on front and rear.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
  15. #1415
    Active Member mark4Jesus's Avatar
    Sale Creek, Tennessee
    Quote Originally Posted by Quickdraw View Post
    I installed mine 2 weeks ago. When you put it in Sport +, hang on, it will throw you back!
    2013 RT Limited.
    BajaRon Sway Bar.
    Refined Cycle's BPE2 brake pedal extension.
    Pedal Box
    2013 RT Limited , Refined Cycle BPE2 White
  16. #1416
    Oct 2015
    Lynden, WA
    Installed a Keyless Gas Cap.
    Fabricated a cane holder for the rear rack.
    Mounted a new License plate frame.
    David C
    2016 F3T
    Rear IPS Pack Rack
  17. #1417
    Feb 2020
    CT and ME
    Spring refresh. In the last week, I've tightened the front shock springs a bit, replaced the rear tire with another Vredestein Quatrac, and while I had it apart installed new brake pads, serviced the front sprocket. Also did an oil change.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
  18. #1418
    Joined the Voltage Gauge Brotherhood today! Not sure how I got the picture 90 degrees out. The gauge is level!
    2013 RT Limited.
    BajaRon Sway Bar.
    Pedal Box
  19. #1419
    Sep 2015
    Chilliwack, BC. Canada
    Quote Originally Posted by mark4Jesus View Post
    I believe there are quite a few members of this club. I joined approximately 2 years ago.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
  20. #1420
    It's like that most likely because you took the pic on your phone or camera with it in Portrait Mode, so the image has its Upper Right Corner designated as the Anchor Point in its EXIF data. only the Forum uses the default Upper LEFT Corner as its default Anchor Point, so when you loaded your image onto the Forum, it flipped it 90° CCW to put the designated Anchor Point where the Forum expects & requires all Anchor Points to be!
    We can't change the Forum default without a lot of effort & significant expense, but you could edit your image to change the Anchor Point; or an even easier solution is to simply flip your camera or Phone 90° CCW to put it into Landscape Mode whenever you're taking pics to upload here, (ie, drop the top of the phone/camera LEFT ) then once uploaded, all your images will always appear the right way up!
    Cheers
  21. #1421
    Apr 2023
    Seattle Washington
    Got the Megatech License last night and disabled the DESS today. wow that was super easy. Installed the USB charger with voltmeter. Tomorrow I will continue installing the remaining LEDs and tank protector. Oh did I mention I ordered the NOCO jumper today???
    2020 BLACK SPYDER F3S
    BMW EXHAUST TIP
    PUIG WINDSHIELD
    TUFSKINZ TANK PROTECTOR CARBON FIBER
    DISABLED DESS
    LED LIGHTS
    RAM MOUNT
    INSTA 360 X3
    SENA 10C PRO BLUETOOTH
    ALPINESTARS JACKET
    SCORPION EXO ST 1400 CARBON HELMET
  22. #1422
    Aug 2018
    Piperton, TN
    Dropped my Spyder at the dealer for 5 warranty issues and squeaky front brakes. I hope that they can complete all the work before the end of the summer.
  23. #1423
    Apr 2023
    TX
    New phone holder and drink holder for the Queen's throne:
    Last edited by Peter Aawen; 05-24-2023 at 03:33 PM. Reason: Fixed attach display ;-)
  24. #1424
    Apr 2023
    TX
    Oh, and the Queen's new fur coat came in:
  25. #1425
    Quote Originally Posted by javajaws View Post
    I see that you treat HRH quite well! I have a '13 RTL and I only know of a drink holder that mounts to the handles. Those are nice!
    2013 RT Limited.
    BajaRon Sway Bar.
    Pedal Box
