Results 1 to 23 of 23
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    Default Do I really need to replace the DESS & ignition for key replacement.- 2014 RT-S?
    I received one key with my 2014 RT-S. I've been meaning to get a replacement for a while (four years now).
    I was at the dealer Saturday to pick up a few things, and figured I'd ask about a replacement key. They tell me that for 2014 (and 2015 the think) that they can't program in new keys - you have to replace the DESS module AND the ignition. About $250 and comes with two keys. That's just the parts, I didn't bother to ask what they'd charge to install as I'm sure I'd need BUDS to do this myself.
    Does this sound right? A search of the internet has proven inconclusive.
    Last edited by Peter Aawen; 05-15-2023 at 08:16 AM. Reason: Expanded title to briefly ask the question... ;-)
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
    2014 RT-S , Orange
    Sep 2015
    Chilliwack, BC. Canada
    No, it doesn’t sound right. Have had a new key cut and programmed by my dealer. Same bike as yours. Go to another dealer! Good luck.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    That pile of you-know-what that he just dumped smells all the way to Idaho! Beginning in 2014 ll you need is to buy is a new OEM key, have it cut by a locksmith, and the dealer can then add it to the DESS. Search for program OEM key here in the forum. There are lots of posts about what you need to do. Good luck. Key is about $50. Programming by the dealer is anywhere from $0 to $150 depending on much the dealer likes to gouge their customers.
    with posters 2 & 3, bunch of Hooey .... However, if you have the opportunity to get the DESS canceled I highly recommend doing it .... Blank keys are like $ 5.00 each, and the DESS problem will be gone ..... Good luck .... Mike
    Mar 2019
    Central SC
    It sounded kinda fishy, and I'm not overly fond of this dealer, but they're the only one close by. Otherwise it's an hour ride to the next one that I know. But if that's what I gotta do.
    I've never had the DESS issue in four years now, but I wouldn't mind getting it disabled if there was someone around here that could do it. Though with my impending retirement, I'm considering getting a copy of BUDS myself and going into a side business...
    2014 RT-S , Orange
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Wahrsuul View Post
    If you do get it that's good but, get it knowing that you can be able to use it on your bike and that if there's any side work then that's great but don't get it planning on doing a lot of work to pay for it as that may never materialize.
    Me I like doing things myself.
    Not knowing where central SC is exactly, I will say that there's already a couple of SL members that have them in SC.
    Mar 2019
    Central SC
    Thanks, I wasn't expecting to make my money back or anything. I'm retiring (again) shortly and if I did anything like that it would be more of a hobby side business to keep me amused and occupied. So far I've done all the work on mine.
    Central SC - I m in Columbia, almost the center of the state. I've been on the SC message group here, but not many people admitting to being around here. There was a Midlands chapter of US Spyder Ryders, but it seems it's gone.
    2014 RT-S , Orange
    Mar 2008
    Hesston, PA
    I "THINK" I remember reading a previous post sometime ago, about someone in SC that has the Mega Buds System, that they can turn your DESS off??? Several SL members have posted about starting a list of members with the Mega license, but to the best of my knowledge its never happened...Turning this flawed DESS off is a plus in my book...larryd
    Dec 2020
    Hartwell, Ga
    I know of two in SC, one in Gaffney and the other is in Lake Wylie
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by larryd View Post
    A list would be very helpful.
    Mar 2019
    Central SC
    It was either COG (Concours group) or the STOC (ST owners) site that had a section with a list of people and their locations and what kind of help they could offer. Some people could offer tools and assistance, some had trailers or trucks for towing if needed and some would provide food or a place to stay.
    2014 RT-S , Orange
    Mar 2022
    Florida
    Default Yes you can clone a replacement key
    My 2021 came with only 1 key . I knew I would lose it because you can't put it in a key ring. So I found a locksmith that ordered keys with a key ring hole that could be cloned! I put my original in a safe place!
    Quote Originally Posted by Dougr View Post
    Are you sure it works to start the Spyder? From 2014 on no one has been able to clone a chip key that will start the Spyder. Or did things change in 2020 or later? Or was the DESS turned off on your bike. If it was turned off then you don't need a chip key.
    Jul 2023
    Chesterfield SC
    I got a blank key from Ebay for $25.00. Talked to Redline at Myrtle Beach and said they could program it for $60.00 - $80.00. Most any Hardware store can cut the key. So it appears it will cost me $100.00 +/- plus a ride to the beach. Good luck. I have one key and if I keep putting this off, i will be screwed. I see you are from Central SC. I'm from Chesterfield SC. Maybe if you get blank key we could meet up and ride to Redline.
    Sep 2015
    Q
    Quote Originally Posted by Leaping1 View Post
    and what is your bike? If it’s a Spyder and not a Ryker (don’t know about Rykers) and it’s 2014 to 2019, it CANNOT be cloned. It must be a chipped key. Ir it is 2020 on up, I don’t know what key they use.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Vermont
    Wahrshuul,
    Check this thread:https://www.spyderlovers.com/forums/...Key-code-again!!!!!!!!!!!!!!!!!!!!!!! it has a lot of excellent info.
    I had a 2014 RTS-SE6 ( Sold) the dealership was giving you , when I had my 2014 RTS-SE 6 I got 2 keys. When I had the D.E.S.S issue they programmed the keys, changed the antenna and the switch , and changed the D.E.S.S. modules plus they gave me a trailer barrel.
    No, that does not sound right.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Vermont
    My 2012 RTS-SE5,( Sold/ Traded) 2014RTS-SE6, ( sold/traded) 2023 F3 LTD Special Series (Current) came with 2 keys.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jul 2023
    Chesterfield SC
    Quote Originally Posted by bigbadbrucie View Post
    Q
    Mine is a 2011 Can Am RT-S
    Sep 2015
    I believe that the Spyders prior to 2014 CAN be cloned.
    Sena SM10 BT Dongle
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    Yes they can. Different key security system than 2014 & later.
    Feb 2016
    PM sent
    2020 RT Limited , Marsala Red
    Nov 2013
    Central Texas
    My 2017 RTS came with two keys (and a trailer barrel). Last year I lost one of the keys. Ordered a blank from Can-Am (it was $72.00) and had it cut ($10.00) to match my remaining key. When I bought a Kuhmo rear tire at Coyote Powersports in Boerne, Texas and had them install it, I lucked out and they programmed the key free of charge. When I got home that afternoon, I of course promptly found the missing key. So I'm out $82.00 but now have three keys.
    Quote Originally Posted by oldguyinTX View Post
    .... I lucked out and they programmed the key free of charge. When I got home that afternoon, I of course promptly found the missing key. So I'm out $82.00 but now have three keys.
    Yup, that'll do it!
    Always the way, innit?!
