Will this Yellow low beam headlight bulb work?
Hello, for years I've always put a low beam yellow bulb in one of my lights on my Goldwing. I don't care as much about brightness as I do about being seen. When I have one yellow bulb it attracts immediate attention to the bike. I want to do the same thing with my 2017 RTS. According to my book the bulb needed is an HHB3 60 watt. All I can find online is an HB3 65 watt bulb. Does anyone know if this bulb will work?
Thank you.
Al
Reason: Expanded title to briefly ask the question... ;-)
Hi Thunder !
I just replaced the low beam bulbs on my 2012 RTS, the right hand side had gone dark so I replaced both. They are HB3 60 watt bulbs. (Mine are white)
Brgds Martin
Just plug this into your search engine, plenty to choose from.
HB3 60 watt bulbs amber
Just for your information a 9005 is the same bulb.
Thank you.
Al
If you live in the USA,( I think you do ) your Spyder doesn't actually have a " LOW " beam headlight ...... or a High beam headlight ..... it has a SHUTTER device that produces a HI / LO beam effect .... I don't think an HHB3 bulb will work in a Spyder the way you want it to .... JMHO .... Mike
