Results 1 to 18 of 18
    Sep 2022
    Central Florida
    Default Where are your GPS and Water Cup Holders mounted up front? 2022 RTL
    Am new to the Spyder world.
    Have a 2022 RTL.
    I don't see many rigs with GPS's or cup holders up front.
    Can ya post a picture of where yours is mounted and/or how it is mounted?
    I want both a GPS (prob an XT wired thru the Spyder) and a water cup holder.
    I am thinking the center of the handlebar for the GPS, but not sure if I want to be looking down all the time. If on the handlebar, then where does cup holder go? Am thinking I want to keep all of it off the right side (throttle side) but am not sure.
    Some ideas and your thoughts would be helpful.
    TIA.
    Last edited by Peter Aawen; 04-30-2023 at 07:18 AM. Reason: Expanded title to briefly ask the question... ;-)
    May 2013
    Apex, N.C.
    I have my phone holder mounted on a ram ball mounted to one of my 4 center handle bar bolts. My cup holder is mounted to another ram ball located on a spyder cuff located on the left side. I suggest getting a thermos that fits the holder and is sweat resistant so condensation doesn’t collect and drip on the spyder.
    Mar 2013
    I have my cup holder attached from my left handlebar controls and my GPS mounted on the top of the dash so I don't have to take my eyes off the road ahead to see it
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Nov 2015
    Chardon, OH
    Thought this might help.
    Doug
    ”Freedom is not a loophole”
    Sep 2020
    Middletown, NJ
    Lamont has these for mounting a ram ball on the left handlebar cuff that you can hang a drink holder on.
    https://www.lamonstergarage.com/can-...uff-cuff-only/
    FYI, re: mounting the GPS on top of dashboard. I found that at higher speeds, the GPS (or radar detector) causes some extra buffeting due to wind flow disruption. Center of handlebars seems to be the preferred location. Just use a long ram arm to raise the GPS up higher.
    2020 RT base , Chalk White
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    I have a Spyder Top Cuff with Drink Holder, from Lamonster and a Tackform phone holder on the left handlebar. I mounted my Garmin Zumo XT on the center handle bar bolts with Lamonster's dual power plate and GPS swivel mount.
    Screenshot 2023-04-30 at 10.30.24 AM.jpg Screenshot 2023-04-30 at 10.30.24 AM.jpg
    I thought I had the picture orientation thing figured out, I guess not. Sorry
    Last edited by Peter Aawen; 04-30-2023 at 10:58 AM. Reason: Fixed(?) attach display ;-)
    2022 Spyder RT Limited Sea to Sky Mystery Blue
    Mar 2021
    Ontario
    My Zumo XT is mounted on right handlebar with the mount that comes with it. I also installed a lock pin. I like it up higher than mounted in centre.
    2022 Spyder RTL- dark trim
    1969 Plymouth Barracuda 340-S Fastback
    1969 Barracuda, 6.1 Hemi restomod, convertible
    1970 Plymouth Superbird, 440-6bbl
    Active Member TCBoone's Avatar
    Dec 2022
    CA
    Quote Originally Posted by george123 View Post
    Hi George, What does the cable attached to the top cuff power?
    Nice Turn Signal Button!
    2022 RT Limited Deep Marsala Chrome
    May 2017
    Oh. Hi TC. I didn't recognize the name at first. Yes, I love the blinker button and the pad on the shifter. This is a 2022 RTL Sea to Sky that I just traded my 2016 RTL in for, a week ago. That USB cable was already on the bike when I got it and I haven't traced the wiring down yet to see exactly how that one's wired. But what I usually use is the USB plug on the left side of the dual power port from Lamonster. The right side has the cigarette lighter plug where I can attach a radar detector, or at home I use it to plug in my battery maintainer.
    Active Member PJveetwin's Avatar
    Oct 2022
    Peoples Republic of Calif. Upper Mojave Desert
    I'm using the Ram phone mount from Amazon, with the cuff and top tree bracket from Lamonster.
    Last edited by Peter Aawen; 05-01-2023 at 10:00 AM. Reason: Fixed attach display ;-)
    2021 RT LT
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    This is how I did mine
    Aug 2018
    Piperton, TN
    I like my Zumo XT mounted between the handlebars. It seems more protected there.
    Aug 2012
    Cold Lake Alberta
    Here is my setup on my 22 RTL. Garmin 590LM (from my previous 2015) secured with Kradlelock, mounted on Slingmods docking station. I also mounted my phone xgrip on the handlebar on the left side and I have my Butler cup on the other side. I prefer using a stand alone GPS. The docking station also has 2 3.0 USB ports and a 12 Volt socket.
    Last edited by Peter Aawen; 05-05-2023 at 12:42 AM. Reason: Fixed attach display ;-)
    Feb 2022
    New Zealand
    Hell yes.
    And SNAP!
    Sucker mount on mine too and in that spot.
    Plugs into that USB in the glove box to keep it topped up.
    That way I can swap it to another ride.
    Mar 2013
    Maumelle, AR
    I have a BRP mount for my Garmin XT. I also have Lamonsters Spyder Cuffs for my water bottle holder and phone mount.
    2020 RT Limited , Chalk
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I no longer have that setup since I got the bar clamp yesterday where I can mount my phone/GPS in the middle of the bars and not on them. I also have the Hydration bag so no longer need a cup holder on the handlebars.
    2021 RT Base - Petrol Blue
    Active Member slhanks004's Avatar
    Nov 2022
    Gilbert, AZ
    I have a Garmin Zumo XT with the handlebar clamp mount (Lamonster's Garage) and 2 Top Cuff mounts with RAM mount balls (also Lamonster) I mount my cell phone on the left side and mount a drink holder when needed on the right.
    Here's a picture showing the gps and left side mounts.
    Scott (slhanks004)
    Gilbert, AZ USA
    2022 Spyder RT Limited - Carbon Black
    • Pedal commander
    • Baja Ron sway bar
    • TricLED tail lights
    • TricLED driving lights
    • Corbin seat
    • BRP rider backrest
    • Lamonster topcuff (2) w/ RAM mounts
    • 12v/USB docking station
    • Garmin Zumo XT
    • RLS cat delete pipe
    • IPS highway pegs
    • IPS belt tensioner
    2022 RT-L , Carbon black
    Jun 2015
    Ritzville, Wa
    I have both my bottle holder and my GPS mounted to the Spyder Cuff I picked up from Lamonster Garage. The cup holder was part of the Spyder Cuff and can be mounted to the inside or outside of the handle bars. I have my GPS mounted to the TrackForm mount I picked up from SpyderDave on this forum.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
