Looking for suggestions on where you mounted your Ram ball on 2020+ RT
I want to mount a single 1” Ram ball for my gps somewhere central to the steering column. Was wondering what others may have used.
Looking for suggestions on where you mounted your Ram ball on 2020+ rt
2014 RT-S Pearl White
I have mine mounted on the left side of my handlebars ... actually I moved the bars from my F3L and left the Garmin mount in place.
Love my Spyders
2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
2014 RTS Circuit Yellow purchased 3/2/2018
2020 RTL Petrol Blue purchased 1/27/2023
Girls on Spyders #3195
No more 2 wheels
2020 RTL , Lamonster floor board riser Petrol Blue
SpyderLovers Sponsor
Mounts for your Spyder
I have in stock the TACKFORM ALL METAL "NOT PLASTIC"
You can use the long arm or the short arm type for the
center mount or the bar mount...
Give me a call 209-887-3283 7 days a week 9:00AM to 8:00PM Pacific Time
Don't trust your GPS or PHONE to a PLASTIC MOUNT
Mounted mine on top of dash, did not like looking down. Running the wire was a chore, but it works great now, no vibration that I was afraid of.
Reason: like ;-)
Right smack in the middle of the bars is my preferred option.
https://www.lamonstergarage.com/lamo...er-motorcycle/
Joshua
2016 Spyder F3S
2019 Spyder RT Limited
2022 Ryker Rally
TacForm has one that mounts in the middle where the 4 bolts are. You remove one of them and install it there. Works great for me.
They have changed them a little since I got mine but it is very similar to this. I assume this is the newer version.
https://www.tackform.com/products/ph...pyder-tackform Motorcycle Dave is where I got mine.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
Exactly what I did. Works great & no vibration.I like it a lot. My only issue - which has nothing to do with the Tackform - is that my phone gets really hot and the display goes black, which is a pita as I use it for navigation. I have an idea for a shield using 1/4" white opaque plexiglass. Buy the Tackform from Motorcycle Dave and support a site vendor.
You can use one of these (can also be used for other purposes like a phone mount, water bottle holder, etc): https://www.lamonstergarage.com/can-...uff-cuff-only/
But I like this solution for a central GPS better if using a Zumo (not sure if it fits anything else):
https://www.lamonstergarage.com/can-...unt-lamonster/
