Results 1 to 9 of 9
    Active Member msgoodwrench's Avatar
    Aug 2021
    Ohio
    Default Any ideas on where to get an SE5 2008 paddle shifter?
    Hello all! I am asking if anyone has or knows where I can get a paddle shifter lever for my 2008 SE5. I don't know what years have the same parts. I do not need the whole entire assembly like everyone wants to sell, just the paddle shifter which has the paddle part snapped off. Please let me know! Thank you for any information.
    Last edited by Peter Aawen; 04-16-2023 at 08:29 PM. Reason: Expanded title to briefly ask the question... ;-)
    2008 GS SE5 , silver/black
    Nov 2015
    Chardon, OH
    Doug
    ”Freedom is not a loophole”
    Aug 2021
    Ohio
    absolutely!!! You are a godsend!! Thank you so much!! Okay, I have purchased this part. I see that it is 3D printed. I have a 3D printer, but the design of this piece is beyond me, I am afraid. I thought about making the part, but I would like to have a piece and ride my Spyder in the next coming months, not pulling my hair out over a design to print it.
    Thank you again for finding this!
    Last edited by msgoodwrench; 04-16-2023 at 04:45 PM. Reason: additional information
    Feb 2022
    New Zealand
    AWESOME.
    I guess you did see this. But just in case.
    Just make sure not to lose the ORIGINAL spring and button that fall out when you replace the original switch lever and use some lubricant that is safe for plastics.
    Aug 2021
    Ohio
    yes, thank you Isopedella. I have carefully placed those pieces in a cup with the screws from the cover so I don't lose anything. I thought about lube, I have some clear silicone grease, is that good to use? Thanks for your information!
    Feb 2022
    New Zealand
    Depends on the make up of the grease I guess. Some will eat the plastic.
    I would google up and see if its plastic compatible.
    FWIW I use this on that stuff.
    Aug 2021
    Ohio
    yes, thanks! I have some I had used for some o-rings. Good information!
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    It has been your lucky day !
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Aug 2021
    Ohio
    well, it started not lucky when the paddle shifter broke! I looked and looked trying to find a part without having to buy that whole apparatus. Thought I was just going to have to buy one and use it for parts. Then I couldn't even find a used apparatus! I wasn't feeling too lucky by then. I thought, well, by chance, I will just ask on the forum and see if anyone knows of a Spyder boneyard, there has to be people that part them out. It wasn't even that long then until my luck changed! I am so thankful too. Mighty thankful for this forum and its wonderful helpful friends! Now, yes, I am feeling it was my lucky day!
Tags for this Thread
