Recommendations wanted - Best cover for 22 RT?
I need a cover that will cover the complete machine. Can anyone recommend a vendor that sells them that cover wind screen, fenders, frunk, and trunk. It's a 22 RT.
Thanks all.
Reason: Expanded title to briefly ask the question... ;-)
I have the same one. It works very well, and is quite durable. I have found it's much easier to put on in daylight. It's hard to sort out in the dark.
My Spyder is stored inside .... I just use a King size sheet ..... Mike
I have the factory cover for mine but I use golf cart covers from Formosa Covers. They are in expensive like $25.00 in expensive and very durable. I also use them to cover my outdoor kitchen sections
The problem i have is with daughters cat. It loves to get into every thing including laying on spyder seat. Sheet wont work for me as he will just go under it lol . My rig is garage kept but the cat gets in when door is opened lol. Thinking maybe a tight cover can keep him off of from going under cover.
Ozzie Ozzie Ozzie
I agree with the above statement. A tight cover will not keep the cat out. My spyders stay in the garage with my office cat, but she doesn't bother it. I did have to relocate my convertible to the attached garage, as that would be quite an expensive lesson if she decided to claw into my top. I only use my spyder cover when traveling to keep the instument panel and seats dry. I bought a travel cover for my 2014 RT. Since then I have used it on my 2012 RSS, 2016 F3T, f3 Limited, and now for my 2021 RTL. It works to do the job on all of them.
A friend had the same problem with cats... was told to spray the ground and bottom of bike cover with regular vinegar as the advisor said cats hate the smell of vinegar. He said it seemed to work for the 3 nights he tried it as his trail cam caught the cats coming to the bike and passing it by. Then he moved the bike inside his toy hauler garage due to unstable weather so hasn't had a chance to further try out the vinegar hypothesis.
2021 RT Ltd, Marsala Red/Black, Dark
New course heading Mr Sulu: 2nd star to the right and straight on til morning...
Peter Pan has struck again!
How about covering the seat with aluminum foil when you are storing it? Cats get freaked out when they jump up and land on it. Another idea is to cover the seat with a really large garbage can bag. The plastic will likely not be very comfy for a cat and if they still jump onto it, it should be a bit more protected.
I can't speak for All cats .... however my cat Loooooooooooooooooooooooooooooves plastic, He is constantly finding and chewing on it. ..... JMHO .... Mike
I have an old 1985 Oldsmobile Toronado (last of the big ones) cover. I put Bounce softener sheets/tissues inside and and around. RTL is inside, so loose over-size is not an issue.
2022 RT Ltd, Deep & Dark Marsala
