Results 1 to 16 of 16
    Nov 2019
    Kansas
    Default Oil filters - are these rubber pieces usually there?
    I am looking to buy this specific filter. Looks like it will work in the Spyder
    https://www.amazon.com/Hoypeyfiy-Mot...6388025&sr=8-3
    My question is this. I do not recall my old oil filter having those rubber pieces on them. Or are they typically already on the oil filter?
    Last edited by Peter Aawen; 02-14-2023 at 02:26 PM. Reason: Expanded title to briefly Ask the question... ;-)
    2018 F3 Limited
    Northern Kalifornia
    Doesn't say it's for a BRP 1330 spyder. go with BAJA Ron to be safe.
    https://www.ads.spyderlovers.com/ads....php?zoneid=13
    indpls in
    no way no thanks click on the seller
    Vermont
    Quote Originally Posted by acdcking12 View Post
    Or go with Lamonster Garage to be safe also. Or Baja Ron
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Mar 2019
    Fla/NJ
    search amazon for can am spyder 1330 oil filter
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by honsfun View Post
    NOT !!! Lamonster & BajaRon both have all the filters required. They ship FREE and supply all gaskets and O-rings in each kit. They started and sponsor the forum we are on! I will continue to get my filter supplies from them.
    End of subject, MHO Bill
    If in Doubt, Don't Do It!
    Sep 2018
    Australia
    Yes.
    Without a teardown and close look at aftermarket filters it's a guessing game as to the quality. Same goes for genuine filters.I've used both and haven't had problems with any. A manufacturing fault can render any filter useless regardless of brand, country of origin or supplier. Support the forum guys if possible if not don't feel guilty it's your choice.
    Feb 2016
    Count me in as a supporter of our site sponsor Lamonster Garage. His oil filter kits include everything you need and are excellent quality.
    2020 RT Limited , Marsala Red
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Those filters do not fit your bike. OEM part number is 420956744.
    I also recommend either Lamonster or BajaRon.
    2015 F3S SE6
    Quote Originally Posted by Tourer View Post
    Actually they will. One of the interchange numbers is HF556 which is the number on the Hi Flo filter Baja Ron sells.
    Durham,Maine
    You can play around with your oil to a point, but I would not play around with your filters! But it's your bike, your choice!
    2012 RTL , Pearl
    Interesting. The description states;
    The Hoypeyfiy oil filters trap harmful contaminants before they reach the carburetor, maintain the life of your machine engine.
    A meaningless oversite, I'm sure. But amusing all the same. Especially considering that the Spyder doesn't have a carburetor. Even if the oil filter did have anything to do with the fuel system.
    Vermont
    Lamonster Garage usually ships quickly.
    I have bought several of the oil filter kits from Lamonster Garage.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Sep 2018
    Australia
    Default Woooaah there, stick by the oil thread rules!
    Now that we've established where we buy them from (which isn't what the op asked). Anyone have specs on any filters we use regarding microns,number of pleats,material thickness,dimensions,etc and the reasoning behind those specs we could look into?
    Nov 2019
    Kansas
    I bought these and they fit fine. Sorry for the trouble of asking a question.
    2018 F3 Limited
    Yes, they will fit fine. As will the HF-556, the KN-556, etc.
