Page 1 of 8 12345 ... LastLast
Results 1 to 25 of 182
    Active Member TCBoone's Avatar
    Dec 2022
    CA
    Default UPDATED Post! New Installation Instructions - A small Safety Mod to our 2022 RTL
    UPDATED See Below
    Riding two up in traffic on multi lane streets is a regular routine at least for part of our rides. Of course, there is the lane change that requires a turn signal and then a manual cancel. Doing this while focusing on the traffic around us made it less than ideal to have to monitor the dash signal to see if the cancel was successful. Which all too often would revert to the opposite direction. Causing me to divert my attention toward the “blinker button” so I could stop the back and forth signaling and end the confusing signals traffic to our rear were seeing. (Yes, I know, I was that guy …)
    Ok, maybe you have been riding for years and have never had this problem, I never have either while riding a number of two wheelers. The design of the stock BRP blinker button has a small flat spot and angled sides making it an issue for a large, gloved hand like mine to execute a straight-in push. Maybe some have better muscle memory and get the job done without a second thought, great!
    I found a perfect solution for me, replace the stock part with a better design. One that allows a push that does not deflect to one side or another when all you want to do is cancel the turn signal. This is a very small and seemingly insignificant upgrade but for my wife and I who really enjoy our time riding, having fewer distractions provides a safer experience and is for us a worthwhile upgrade.
    The first photo shows the original part with a small area required for a straight-in push to cancel; any contact with this button that is slightly off-center triggers the turn signal, usually in the opposite direction, instead of turning it off.
    The second photo is of the replacement blinker button with a larger flat spot that is easy to find without taking my eyes off the road and cancels correctly every time.
    I suspect there are some who consider this trivial, but when your attention is diverted it needs to be for a good reason and only briefly, not for a design flaw. Let us know have you ever experienced this problem?
    For more information please send me a PM, Thanks
    Update - Shifter Pad
    Installed the shifter pad and went for a ride on one of our favorite routes here in northern California. You know the kind that has a mix of tight and long sweeping turns along with lots of frequent elevation change. The kind of road that encourages spirited riding, requiring one to shift up and down the gears to keep the Spyder in its peak power band.
    During the ride I noticed my left hand was in a more relaxed position. The added thickness of the up-shifter pad allows the thumb to reach the control to upshift from a less extended reach. Anytime we engage in a repeat motion, designing better ergonomics makes a difference, especially over time.
    BRP builds beautiful machines, that has been improved upon over the years, some of those improvements most likely have come from owners. While the mods we are trying out are only slight changes, they are definite improvements and something that Can Am On Road should consider for their new production models.
    Thank you to everyone who has provided feedback about these mods. Appreciate this forum to be able to share these ideas along with each comment and kind words.
    Thank you for reading and posting,
    TC
    Important Update! – new Turn Signal Button Installation Instructions
    As the weather has started to warm up there is a possibility that the Turn Signal Button may become loose.
    It is strongly recommended as a precaution to apply a small amount of E6000 adhesive.
    It is a permanent adhesive that can be removed should the need arise in the future.
    This should solve any issues from prolonged sun exposure during the summer.
    The redesigned Turn Signal Knob does not fit the 2024 models,
    because the stalk the knob attaches to has been redesigned.
    The Shifter Pad will fit all models.
    Last edited by TCBoone; 05-13-2024 at 05:44 PM. Reason: Updated Post New Installation Instructions
    2022 RT Limited Deep Marsala Chrome
    Sep 2020
    Middletown, NJ
    Where did you get the replacement cap?
    2020 RT base , Chalk White
    Active Member GFrog's Avatar
    Jan 2022
    Bedford, Nova Scotia
    This happens to me all the time. I would also like to know where you got it from.
    2022 Spyder Sea to Sky Mystery Blue
    2009 Suzuki Boulevard M50 SE
    Apr 2020
    Edgerton,WI
    Brilliant! Where did you find the knob?
    2019 F3L , Covid Blue
    Feb 2020
    Minnesota,USA
    I also want ONE! Start mass production...
    If in Doubt, Don't Do It!
    Harrington, Australia
    Yep, even though I can work it well “most” of the time, with winter gloves it is a bit trickier. This option would suit me, too, TC. Great idea
    HeliBars Handlebars
    Kenda Kanine rear.
    Sep 2021
    PA
    Certainly needed.
    2018 RT Limited
    Active Member SkipH's Avatar
    Nov 2021
    Nevada
    I want one too!
    Adj removable backrest, KOTT radiator screens
    Double horn (118db), Lamonster mirror fix
    FOBO 2, Trunk rack, Afterburnerz taillights
    Drinks2go cup holder, replaced the seat strut
    Garmin Drive Smart 71 GPS, Large brake pedal
    White pulley, Pedal Commander, Trunk Strut
    Laminar Lip wind deflector, side windshield wind deflectors
    Home made belt guard, Shorty antenna
    Show chrome wide windshield, Belt dampener
    Top cuffs and Mirrors
    7x12 enclosed trailer
    2021 RTL Dark Chalk Metallic
    Skip H.
    May 2021
    Daytona Beach FL
    Can I get one that looks like a die? As in one cube from a set of dice.
    2020 Spyder RTL Chalk/Black
    2020 RTL , Chalk / Black
    Aug 2013
    SF Bay Area
    The more you ride the more practice you get and you get used to it. I don't even look down when touching any of the control buttons. I learn where they are.
    2021 F3 Ltd , Magna Red
    Oct 2015
    Lynden, WA
    Great idea. I need this fix for my byke. Did you 3D print this new button?
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2011
    Pence, wi.
    I want one asap!! Should come that way stock!
    2022 Spyder RTL- Chrome , Larger brake pedal Deep Marsala Red
    Bossier LoUiSiAna
    BLINKERS?
    Oct 2020
    Vinton, IA
    I'm on board! Where'd you get it?
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Dec 2020
    North Germany
    very nice, would need one even with winter-gloves
    modified 2020 F3-S for paraplegics including handbrake, wheelchairmount etc.
    2020 F3-S , pedalbox black
    INDIANA, USA
    ....Well this is a interesting read. I think it is a really good part. Sooooooo is the knob available anywhere?
    Did you make it or have it made?
    I didn't see it on Amazon.
    Please let us know more details about the part.
    Thanks and have a Blessed Day.
    ENJOY YOUR LIFE WITH A SPYDER
    Sebring, FL
    Now this is one 'good' post, and I thought I was the only one that had this problem.
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    I'm in
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by bikerchris1270 View Post
    I asked for one through him….. we’ll see.
    Very Active Member pidjones's Avatar
    Mar 2021
    East TN
    One more example of BRP designing something with flaws and refusing to correct.
    1976 RD400c
    Oct 2021
    TX
    I have the same blinker issue as do many others and would like to try the improved button.
    2019 RTL
    2019 RTL , Blue
    Apr 2012
    Florida
    I wish he would come back and post. Where we can get one, cost, install? Tom
    2020 Petrol Blue Metallic RTL
    Mar 2022
    Virgil, Ontario
    I’ve had the same issue.
    Where can I get one?
    2021 Spyder RT Limited Chalk White
    Feb 2020
    illinois
    I would think that all of us that ride our bikes a lot and use the turn signals often when passing has this issue with not finding the cancelling sweet spot every time and then engage the other direction signal. I am having a quiet moment now thinking Lamonster will be reading and come to the rescue with a new product.....
    Northern Kalifornia
    "I suspect there are some who consider this trivial, but when your attention is diverted it needs to be for a good reason and only briefly, not for a design flaw. Let us know have you ever experienced this problem?"
    Nope, never experienced this problem. Multitasking comes to mind. Some have it and some don't. I have the rectangle shaped stick on blind spot mirrors attached to my left and right rearview mirrors for obvious reasons. When I change lanes I first check my mirrors and then do a quick head turn look see to confirm I have the room to safely merge into the next lane. When I engage my turn signal I don't remove my thumb from the turn signal button until the lane change is complete, then I push it to cancel the signal. Walla, all done and no problem.
