Page 51 of 80 FirstFirst ... 4147484950515253545561 ... LastLast
Results 1,251 to 1,275 of 1993
  1. #1251
    Member vulkus's Avatar
    Dec 2022
    QLD, Australia
    Put 20 psi in the front tyres, they were both out, left was 21 and right was 23 psi.
    Also, lubed the frunk latch as it was a tad sticky.
    2015 Spyder RT Special series Se6
    Really a mutant cross between a special series and a Limited.
  2. #1252
    Quote Originally Posted by vulkus View Post
    Sent you a PM Vulkus
  3. #1253
    Dec 2022
    QLD, Australia
    Listened to some sage advice and changed my tyre pressures.
    Bought a headlight restoration kit to bring my fuzzy old lens' back.
  4. #1254
    Nov 2022
    North Carolina
    Installed a plug n play brake light flasher kit purchased from Sling Mods. Easy peasy, extra vis plus the top case light makes me feel a little safer.
    2018 F3 Limited
  5. #1255
    Oct 2015
    Lynden, WA
    F3T, tinkered with the fit and function of the left side accessory cover
    after I installed a DIN connector for my heated gear and a push button switch
    for my garage door opener.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  6. #1256
    Aug 2020
    Niagara Falls NY
    I gotta check this out!
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
  7. #1257
    Aug 2020
    Niagara Falls NY
    Default BR swaybar and hardware
    Finished the Baja Ron bar today in my '22 F3 Special after waiting a few days for the specific hardware to finish the job, here's the long story;
    I owned a '20 Ryker rally that had jittery steering above 50mph, I had read about it and sure enough it was true. I didn't jump in to the whole bar and link change but did just the links first, a set of spyder extras links, nice enough and easy enough to swap out. What I learned however was how sloppy the original hardware was when I removed it and the original links were not simply plastic but nylon reinforced. I did the complete replacement and boom, just like that, 90% of the jitters were gone, great but the hardware was bothering me. When I had time I went back and swapped everything back to original and took a ride, yeah, jitters returned. I then carefully measured everything and planned and ordered everything that would fit snug. Frame attachment was 1/4in as was the bar end but the balls in the links were closer to 6mm and so was the hardware. To make that matter worse the shoulders didn't pass completely through the frame or bar. The first thing I did was to get the 6mm bolts with the correct shoulder and I installed them with the original links and boom, 90% jitter reduction but I wasn't satisfied. I ordered 1/4in heim joints with an adjuster and the proper shoulder length and the steering/tracking was now rock solid.
    Fast forward, I now own a spyder and while the tracking had only a fraction of the jitters the ryker had, it was still there so when I decided to do the bar upgrade I knew what to do. I got the hardware and did that too but I kept the original 8mm in the upper frame but actually wrapped the bolt with aluminum tape to snug them up (yeah, there was that much play in them) and slid a thin fiber washer in there to take up some slack. Down below I got a pair of 8mm stainless 30mm shoulder bolts and used 2 thin stainless washers, this bolt takes a 6mm nylon insert nut to finish, tightened up to torque specs and took a short winter ride and wow, what a difference, awesome.
  8. #1258
    Dec 2022
    QLD, Australia
    Gave it a good wash.
    Those black rims look clean even when dirty.... except the rear, it is dirty as, and I'm not grubbing around on the ground to clean it!
  9. #1259
    Active Member GRHorst's Avatar
    Mar 2022
    PA
    _________________________________
    GR Horst - Reading, Pennsylvania, U.S.A.
  10. #1260
    Mar 2022
    Virgil, Ontario
    I ordered and installed a Power Box from Can Am Spyder Accessories.
    Need a decent day to try it out, too cold and snowy here presently.
    Installed front fender and rear fender lights, wow way more lighting than I expected.
    Also installed the Eastern Beaver 4Cs auxiliary fuse for my heated gear.
    2021 Spyder RT Limited Chalk White
  11. #1261
    Vermont
    Nothing.
    It is still in hibernation.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  12. #1262
    Nov 2022
    North Carolina
    Rode it both days this weekend!
    2018 F3 Limited
  13. #1263
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    I carefully stroked it like I would a loyal Labrador Retriever and said, "Good Spyder" ....
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  14. #1264
    Dec 2022
    QLD, Australia
    Got my Missing Belt Guard from Lamonster Garage and fitted it today. What a pain in the..... No strange noises and doesn't appear to be rubbing so hopefully, a good fit.
  15. #1265
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I bought mine last summer but haven't been brave enough to put it on. I know it's gonna be a nightmare and I'm sure my wife will hear Italian swear words that would make an Italian person blush.
    2021 RT Base - Petrol Blue
  16. #1266
    Dec 2022
    QLD, Australia
    Wasted my time...
    I decided to rejuvenate my headlights today, turns out all the haze is on the inside of the lens. Thankfully it doesn't look to bad and doesn't appear to be down near the beam area.
  17. #1267
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    I installed my F-3 Cannonball Seat ...I've been debating on buying one for awhile...and I finally decided to purchase it...it's a really nice comfortable seat..
  18. #1268
    Jan 2023
    Michigan, USA
    Took delivery of it and rode it a total of one mile before I started shivering from the cold.
    Chuck
    2022 F3-S Special , Manta Green
  19. #1269
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Impster View Post
    Chuck
    On your 1st post and your New Mean Green Machine! Bill
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
  20. #1270
    Oct 2015
    Lynden, WA
    Rebuilt the mount for my heated gear controller.
    Installed my new signal cancel button - Thanks to TCBoone And Frogman Dave
    David C
    2016 F3T
    Rear IPS Pack Rack
  21. #1271
    Dec 2022
    QLD, Australia
    Being a relative noob, I finally got it out of Eco mode. And I've almost reached my first 1000km
  22. #1272
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    put on XKglow lights
    20230208_052538[1].jpg running
    20230208_052601[1].jpg turn
    20230208_052534[1].jpg brake
    still got more to do
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
  23. #1273
    Wa.
    Pulled both spyders out of their sheds. Checked air in the tires. Wife rode her F3L an I rode my RTL. Took freeway to Prosser and ate BBQ. Came back home on the old hiway to Yakima. Nice 120 mile ride.
  24. #1274
    Oct 2015
    Lynden, WA
    Working on a wireless charging phone mount for the F3 handle bars.
    Phone will be used for music and backup maps.
    Should be able to install and test on Saturday provided the weather cooperates.
    David C
    2016 F3T
    Rear IPS Pack Rack
  25. #1275
    Mar 2015
    Fritch, Tx
    Installed Lamonster belt tensioner. It doesn't go nearly as smoothly as the video I watched would have you believe. Knowing there was more than ample amounts of yellow lock-tite on the OEM bolts would have helped because I would have broken out the mini torch a lot sooner.
    Those who say " I can't" will always be right.
