Results 1 to 12 of 12
    Jan 2015
    southern WI
    Default Have you come up with Additional turn signals for '21 RT?
    Has anyone come up with their own add-on turn signals for the front of the 20+ RT? The fender tip ones just don't seem like enough. I know there are the kits that go on the back (front side) of the mirrors... just curious if anyone has figured anything else out yet.??
    2016 RTS , Pearl White
    We use the mirror and vent lights in addition to the regular turn signals. Both Spyderpops and Lamonster Garage have the versions. Spyderpops did my 2019 and Lamonster did my 2020. They are highly visible both night and day.
    Oct 2021
    Wichita, KS
    Here is what I installed on my Spyder https://www.slingmods.com/canam-spyd...9-up?vehicle=1
    You won't believe how much light they add to the front end. And the blinkers are very, very noticeable.
    Peter Pan has struck again!
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by FrogmanDave View Post
    I did something similar. Very noticeable.
    Feb 2016
    Here's what I've done to a few bikes now. Mine, and friends'.
    https://www.spyderlovers.com/forums/...sings-2020-RTL
    2020 RT Limited , Marsala Red
    Mar 2015
    Fritch, Tx
    Here's what I did at very low cost from Oznium.com. These are tapped into the signals on the mirrors.
    Those who say " I can't" will always be right.
    Jun 2021
    Bossier City, LA
    The kits are worth the cost unless you're REALLY good with electrical things.
    It appears that SpyderPops is now selling the plug-and-play power supply for their lights separately
    They didn't do so previously. It makes tapping into the running and turn signal circuits easy.
    --Exco
    2021 RT-L only has a few cosmetic mods
    Danbury Connecticut
    I installed these:
    https://www.lamonstergarage.com/ambe...pyder-rt-2020/
    I like them because they are up high on the mirrors. I believe that makes them more visible.
    I suppose you could save some money by coming up with your own. Jetfixer's solution is exceptional.
    For me, it depends on your goal.
    If you want to HAVE additional lights, go for the kit.
    If you want to MAKE additional lights, have at it on your own and see what you can do.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Sep 2016
    Chillicothe, Oh.
    I have these and get comments all the time about seeing me coming. When you turn the signals on they change to yellow. A very bright yellow.
    2015 RT , Black
    Sep 2021
    Fredericksburg, VA
    I installed these:
    I put the same lights on my F3T and love them. My goal was to get turn signals up higher to be seen from taller vehicles..
    I power ALL my lights from a fuse block https://www.lamonstergarage.com/elec...ent-lamonster/
    I put it under my rear seat where the connection harness is so I can easily access, it if there is a need to, out on the road
    I don't have to splice into any factory wires.. It makes connections very easy.
    Side note: This fuse block also works on the F3T and F3L as they have the same connection harness under the seat as the RT...
    I consider this as cheap insurance for lighting add on
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
    Harrington, Australia
    Wow…….they look pretty special, Jet. Luckily, I’m in Oz, so I don’t have to worry about it.
    Just a past experience for those looking at adding turn lights to the mirrors…….I added a strip of led to the top/side of my mirrors on my ‘16 F3-L, thinking they would also help in seeing if I had turned my indicators off, as the console light is hard to see. It worked a treat, UNTIL I went for a night ride…….couldn’t see a thing once I turned my indicator on.. I had to disconnect them before continuing …….don’t be like Pete
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2022
    TN
    I used the mirror back turn signals from Lamonster as well as the LED reflectors front and rear on the fenders. Got those from Lamonster as well.
    Last edited by Peter Aawen; 01-20-2023 at 04:58 PM. Reason: Fixed attach display ;-)
