Page 49 of 80 FirstFirst ... 3945464748495051525359 ... LastLast
Results 1,201 to 1,225 of 1993
  1. #1201
    Mar 2021
    Maryland
    Took it for a drive on Skyline Drive, enjoying the warm weather and fall colors.
    Oh we also got to talk to a Va. State trooper on the way home. He was a nice guy and let me off with a warning for acting not so smart.
    2020 F3 SE6
    2020 F3 , Black
  2. #1202
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by CloverHillCrawler View Post
    State Troopers are swell
    2022 RT Sea To Sky
  3. #1203
    Jan 2015
    southern WI
    Nothing today...I put em both to bed last week after the fall storage ritual I do. 50's today, 30's for the forseeable future. Time to think snow and trail grooming instead.
    2016 RTS , Pearl White
  4. #1204
    Vermont
    Nothing my spyder is on a battery maintainer until April 2023.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  5. #1205
    Vermont
    Quote Originally Posted by Mazo EMS2 View Post
    I agree with you.
    Yesterday I bought a VT TMA for the sled season( I hope we get a sled season, The future weather forecast doesn't look good). The sled is on a battery maintainer.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  6. #1206
    Aug 2019
    Stoughton, WI
    70* Thursday. Good day to head to Illinois to pick up my new little toy
    2022 RT Sea To Sky
  7. #1207
    Active Member GFrog's Avatar
    Jan 2022
    Bedford, Nova Scotia
    This morning I installed some black panel protection from "Wrap My Spyder". I used their Textured Carbon Fibre application. Peter's excellent installation videos really helped a lot. Some areas are a little tricky and I also had to trim a pattern in the Switch Panel kit for the Sea to Sky badge.
    I think it turned-out pretty good. No more scratchy black panels.
    Next will be Fobo 2 for trikes.
    2022 Spyder Sea to Sky Mystery Blue
    2009 Suzuki Boulevard M50 SE
  8. #1208
    Oct 2021
    Wichita, KS
    Quote Originally Posted by GFrog View Post
    Lookin' good GFrog!
    Peter Pan has struck again!
  9. #1209
    Active Member Realtor's Avatar
    Nov 2018
    Pensacola
    rode it for about 30 minutes....
    Jim Summers - Pensacola FL
    www.PensacolaHouseHunters.com
    2018 RT , Blue
  10. #1210
    Oct 2015
    Lynden, WA
    Rode in a snowstorm in northern Nevada. Very slippy and slidey.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  11. #1211
    SoFlo
    Did not do anything.
    On the to do list, recharge the trunk gas spring, and make chassis adjustments to optimize the front suspension roll center. Gas Spring is easy, Roll center change will take some test riding along with having to get out the ROLO Laser Alignment tools and dial in the wheel alignment since changes to the front suspension will alter wheel alignment.
    The last big change, relocating the ambient temp and pressure sensor along with intake air heat reduction is proving to be one of the best changes made to our Spyder.
    Recently while on a night out dinner date, one Sena battery went dead. So while at dinner, I utilized the previously installed, for this exact reason, the Providence Spyder Accessories very cool, high quality switched USB charge port. Came out from dinner and had two Sena 20 setups charged.
  12. #1212
    Aug 2019
    Stoughton, WI
    Oil/Filter: check
    91 ethanol free/Stabilizer: check
    Battery Tender: check
    Cleaned/waxed: check
    Tire pressures: check
    Exhaust plugged: check
    Dryer sheets strategically placed: check
    Covered up: check
    Winter Hibernation has begun.
    Will ride my two wheeler tomorrow for the 70* anomaly day in southern WI
    2022 RT Sea To Sky
  13. #1213
    Oct 2015
    Lynden, WA
    Fixed the power port for my heated gear.
    Checked the air pressure in the tires and air bag.
    Installed my new F4 windshield.
    Inspected the front sprocket for Red Dust - None found!!!
    Planning a group ryde on Sunday - weather permitting.
    David C
    2016 F3T
    Rear IPS Pack Rack
  14. #1214
    Mar 2021
    Arizona high country
    As I have stated before; finding red dust is a sign of a possible bad sprocket. Not finding any IS NOT necessarily a sign of a good sprocket. Mine failed the inspection and had zero red dust. I know this has drawn out a long time with BRP but do not assume because you have no red dust that all is well. Might not be the case.
  15. #1215
    Nov 2016
    Colorado Springs
    First ride since getting my Spyder back from warranty repair. Last week the avg temperature was in the 70s. This week is in the 40s, but I've been without the bike for 3 months and just can't wait for warmer weather.
  16. #1216
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    I installed A Givi Trunk. Turns out my Spyder had, I guess the factory accessory removable back rest and also a luggage rack. I mounted the Givi Bracket on to the luggage rack/plate, following the Video put out by "Ask DIY Dad" back when he had a 2013. I could not figure out at first what the Plastic tail piece was for. But I guess that was the factory rear piece, that was removed to install the locking mechanism for the the accessories
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
  17. #1217
    Member ImaCaMan's Avatar
    Jun 2020
    Salt Lake City, Utah
    Added some chrome trim from Wrap My Spyder to the rear top case of my F3L Special Series and went to the beach for a ride down the coast in SoCal.
    2022 Spyder F3L Special Series, Red (Oceanside, CA)
    2018 Spyder RT Limited, Pearl White (SLC, Utah)
  18. #1218
    Jan 2022
    North Dakota
    Mine is sleeping for the winter
    2021 RTL , Asphalt Gray
  19. #1219
    Nov 2022
    North Carolina
    Installed a battery maintainer.
  20. #1220
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Unfortunately, both the Spyder and Ryker have settled down for a long winter's nap.
    2021 RT Base - Petrol Blue
  21. #1221
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    I just installed my Baja Ron Bar. It will be in the high 50's the day before Thanksgiving and Thanksgiving. Taking a ride to test it out.
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
  22. #1222
    Mar 2022
    Virgil, Ontario
    Last week I installed the short reach bars that I bought from one our forum members.
    Over the weekend we had a snowfall of just over 15” which has disappeared this morning.
    Today I went for a ride on our local country roads including the Niagara Parkway.
    The bars have made a major difference for me in seating position as it moved me further back in the saddle.
    I can now use the backrest and my knees are now in a better position.
    Just for reference, I’m 5’-6” about 150#
    Very satisfied. Cheers all and an early Happy Thanksgiving
    2021 Spyder RT Limited Chalk White
  23. #1223
    Faribault, MN
    Though I just yesterday put my Gold and Black Anniversary Edition RTL in it's winter storage
    I ordered several new farkles for the future, Got several Cyber Monday (or Black Friday continued) sale prices on
    Spyder Accessories RT Front Grills 2 RT Logos - Carbon Fibre Black
    Spyder Accessories RT Series - The Floating Pegs - Black with Black Edge
    Spyder Accessories RT Series - Black Carbon Polyurethane Windshield Blackout
    TRICLED’s Wide-Vu Convex Side View Mirrors
    How's that song go??? "Anticipation......"
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
  24. #1224
    Mar 2015
    Fritch, Tx
    Not actually today but did finish repairing the parking brake mechanism on Saturday after I botched the job of putting things back together properly on the last tire change a few weeks ago. I had failed to get the base plate of the brake caliper properly seated over the pin in the frame and the first time I hit the brakes, it flipped around and destroyed the cable and pulley as well knackered up the micro switch. I managed to unfold the little metal arm on the switch without breaking it but had to purchase new cable and pulley. The process required removal of most of the right-side body panels and some very tight working conditions to reach everything. Took a few hours, but I gotterdone! Also installed new rear brake pads while I had it all apart again.
    Those who say " I can't" will always be right.
  25. #1225
    Jun 2020
    I installed a Lamonster Garage replacement brake rod on my 2022 F3L Special Series. The original is ridiculous and unsafe. I almost ran the first stop light I came to on my way home from the dealers with it. What a difference Lamont's made. Easy 10 minute install.
