18 Spyder RT will not turn on
18 Spyder RT will not turn on. I turned the key and the display turned on for a second. I tried to boost it and couldn't start it.
Even boosting it with the battery still installed the display did not want to come on.
I took the battery out and it reads 12.7 volts. I boosted the bike with a car and got it home.
Tried to boost the bike with a battery boost and the dash does not light up.
I'm thinking it's a relay.
Any ideas
Could it be the key switch?
Replace the battery
Original battery? If so you have two choices:
1. Replace the battery (search for recommendations).
2. Spend days/weeks fooling around with relays and then replace the battery.
![Quote](images/misc/quote_icon.png) Originally Posted by ahh-cool
Any ideas
If the spyder started with the car battery - I don't think the relay is an issue .... as others have said .... look to the battery as the problem ..... Mike
I now don't think it's the key switch because the flashers didn't work. I know I was able to jump the bike and it started and I drove it home. I was getting ready to purchase a battery and I was trying to jump start it with a battery box and a car jump but I had nothing, no lights on the dash. I had it towed, free towing and he said it's the battery. I told him to put in a battery and check it a few time throughout the next few days to make sure. He said they are having a hard time getting batteries.
I read this post a few times and frankly I'm confused about what going on ..... Mike
If you have changed the battery and keep starting it to make sure it's starting without riding it and charging the battery with the bike by riding it, IT WILL KILL THE NEW BATTERY! If it's straightened out and starting ride the thing and forget you ever had a problem!! good luck
The bike is in the shop for the battery and the sprocket service bulletin. I am working 12 hour shifts right now and I don't have another vehicle to find a battery. I'm in a small town of 200 people.
Not to mention you've recently had a near miss from IAN. Hope they've found the fix, will charge your new battery to full and get that new sprocket on in time for your riding.
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
![](https://www.spyderlovers.com/forums/maps/map.png?states=AZ.MN.ND.SD.IA.NE.WI.MI.MO.IL.IN.OH.KY.AR.TN.MS.AL.FL.GA.NC.KS) |
![Quote](images/misc/quote_icon.png) Originally Posted by DGoebel
I'm in Minnesota, right now working the Sugar Beet harvest. Should be leaving here in about 2 weeks
