Results 1 to 6 of 6
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    Default Would Like Ultimate Floorboards Measurements
    Searched on a few Spyder forums and Google but couldn’t locate Ultimate Floorboards Measurements. Going to make a set.
    Would somebody do a favor and measure theirs. Prefer #3 position board measurements.
    Length of front angled section.
    Length of lower rear section.
    Height from lower section to rear mounting bolt hole.
    Percentage in degrees of the bend between the front and rear sections.
    Width of the floorboard.
    Thanks in advance for your help.
    2015 F3S SE6
    Active Member RobDekker's Avatar
    May 2021
    New Brunswick, CANADA
    You want us to help you copy a superior product?
    2021 Spyder F3-S Special Series
    Monster Fuel Injection Stage II
    K&N Air Filter
    Lamonster Cat Delete Pipe with Baffle
    Akrapovic Sinister Exhaust
    Baja Ron’s Anti-Sway Bar Kit
    Elka Shocks Stage 3 Front, Stage 4 Rear
    F4 Customs 32” Windshield
    Pedal Commander
    Lamonster F3 Brake Rod
    Shad SH36 Side Cases
    Crampbuster
    Jul 2022
    North Carolina
    Hi Rob. If you feel uncomfortable then that is fine. I have the capability to make a set and the measurements would make it a bit easier. They will not be an exact copy and will only be for me. I want them lower and probably shorter.
    2015 F3S SE6
    Jul 2022
    North Carolina
    Any responses? The reason I am asking is that after my back operation ended up with nerve damage and a drop foot. So my left leg starts to hurt and has to be repositioned and have some height change.
    Been to a couple of dealers and check out Spyders I see, but none have had the boards.
    2015 F3S SE6
    Quote Originally Posted by Tourer View Post
    Not everyone checks the Forum every day, Tourer; it often takes a week or more for a thread asking about a specific product to start getting read by those who have that product. So to actually have 154 views in just a few days isn't bad, but it might take a while for someone with those boards to come on the Forum, see your thread, & respond... at least a week, maybe even 2 or more
    Hang in there tho, it might not happen over-night, but it will happen!
    Netherlands
    Let me revive this question since I would like to have the measurements also.
    The reason is very trivial:
    1. Buying them for The Netherlands is very expensive ($560 USD + shipping + customs, customs again is calculated over price & shipping costs).
    Total costs would be nearly $750 USD which makes it over the top.
    2. I can make it myself, having measurements makes that a bit easier.
    As said above, it will not be an exact copy, will be tailored to my wishes.
    2020 F3S , Matte black
