Results 1 to 22 of 22
    Aug 2022
    Tucson AZ
    Default Checking for rear speakers.
    2010 Spyder RS new to me, and I can use the fader control for front/back volume, but I have no volume from the rear speakers. How can I check if I even HAVE rear speakers? Don't want to go ripping panels off willy-nilly. Any tips?
    Oct 2021
    Wichita, KS
    Pretty simple. Just look for speaker grills.
    Peter Pan has struck again!
    Dec 2015
    Oakley Utah
    If you do have speaker grills, you can remove them easily by carefully prying up along the edges.
    2014 RTL Platinum
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    They should be in the front lower corners of the trunk.
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    2019 Spyder RT Limited - Asphalt Gray/Chrome
    1991 H-D Sturgis FXDB -- #684 of 1600 Limited Edition
    Gone but not forgotten:
    2014 Spyder ST SE5
    Steel Black Metallic
    2019 RT Limited , Asphalt Gray/Chrome
    Dec 2015
    Oakley Utah
    Speaker grills should look something like this (but I don't know about your particular bike, so taking a pic would be helpful)
    2014 RTL Platinum
    Quote Originally Posted by utahpete View Post
    2010 rs ???????
    Dec 2015
    Oakley Utah
    2010 rs ???????
    No, just illustrative of speaker grills at the back.
    2014 RTL Platinum
    Aug 2022
    Tucson AZ
    Looks like mine. They pry right off, huh? Then the question is: why aint they working? I love tinkering with the Spyder.
    I will find a way, or I will make one.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Tucsonspyder View Post
    That's a different issue. Now we know your bike was wired for speakers and where they're located. There is most likely a disconnected wire somewhere between the power amp, the fader switch (or is it electronic?) and the speakers themselves.
    2014 RTL Platinum
    Quote Originally Posted by FrogmanDave View Post
    ... what RT did NOT have speaker grills ?????? ........... Mike
    Dec 2015
    Oakley Utah
    "2010 Spyder RS new to me"
    2014 RTL Platinum
    In your OP you say you have a 2010 RS. Did you mean RT? The RS did not have a trunk.
    Bossier LoUiSiAna
    That Rt speakers OP said 2010RS ; any & all GS,RS,ST did not offer rear speakers *that I know of*. Aftermarket sure 57294C25-C18E-4E9F-A3E9-A6DE01B27488.jpg reall not sure what had sound systems at all -limiteds should have kept mixing up options & offers.
    Dec 2015
    Oakley Utah
    RS https://www.cycletrader.com/listing/...SE5-5022253993
    RT https://www.cycletrader.com/listing/...nce-5022307656
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    Confusing. He does have this thread in the RT category...
    2014 RTL Platinum
    Nov 2015
    Chardon, OH
    His profile says RT, and there's picture of a blue RT. Thinking RS was a typo.
    Tuscon, Looking back through this forum, the 2010 RT A/C model had an AM/FM radio but only had front speakers. However, it DID have the rear grills since those body parts were common to all models. And it follows that the Fader control would have shown up in the Preferences, also, as the software would have been common.
    So, it goes back to a little detective work. A bright light and a sharp look though those little holes will enable you to see if there are any speakers in there. Or, pull off one of the rear speaker pods.
    Doug
    ”Freedom is not a loophole”
    New poster. Sometimes, little details get missed.
    Pete an " RT " and an " RS " are totally different machines ..... Mike
    Dec 2015
    Oakley Utah
    Yes, i know Mike but the OP doesn't seem to.
    2014 RTL Platinum
    Aug 2022
    Tucson AZ
    You are correct.
    Dec 2015
    Oakley Utah
    You are correct.
    Who? What?
    2014 RTL Platinum
    Aug 2022
    Tucson AZ
    Navigational issues, my apologies.
Tags for this Thread
