Results 1 to 25 of 29
    Apr 2018
    Texas
    Default Yuasa battery out of stock
    I have been calling all over to get a factory Yuasa 24hl-bs battery and everyone I have contacted is out of stock. Several dealers have told me that there is a nationwide back order with no estimated delivery date in the future. I know there are alternatives but I would like to stick with the Yuasa brand since I have have had limited issues with them but with a nationwide back order I might have to switch brands.
    Would like to hear what others are using and issues if possible. My experience in the past is that my battery tender JR might not have been compatable with certain brands of batteries and that I had to incur an additional expense of a different battery tender.
    Thank you
    John
    Dec 2015
    Oakley Utah
    There have been several very lively discussions lately on this topic. There is no consensus on alternatives. I recently decided to invest in a lithium battery, which does require a different type of battery tender, but if you stay with AGM batteries your existing tenders will be fine.
    2014 RTL Platinum
    Active Member Tourer's Avatar
    Jul 2022
    North Carolina
    I buy batteries for the bikes in all brands. Just always making sure they meet or exceed the manufacturers requirements. Always buy a very good quality AGM battery. Also make sure the cable hookups are in the same position as the Yuasa.
    The Yuasa 24hl-bs is 22.1 Amp hours, 350 Cold Cranking Amps, and is Bottle Supplied (bs) where you add the acid and perform the initial activation charge. Do not buy a FA (factory activated) battery. Who knows how long they have been sitting on the manufacturer’s and the final retailers shelves.
    2015 F3S SE6
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Tourer View Post
    I believe AGM batteries are sealed, not bottle supplied.
    2014 RTL Platinum
    Northern Kalifornia
    Interstate Batteries
    Jul 2022
    North Carolina
    2015 F3S SE6
    Mar 2019
    Fla/NJ
    https://www.summitracing.com/search?keyword=Yuasa They seem too have many in stock. See if it works for you.
    Vermont
    I am using the YUASA battery ( part # YUAM7250H) Part/Description 5813103 YTX24HL YUASA battery.
    I installed the above battery on 4/28/20, I have a 2014 RTS-SE6 spyder and I have not had any issues with this battery. The spyder starts fine, I also run heated gear ( in the fall ) and other accessories on the bike.
    Hope the above info helps.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Northern Kalifornia
    May 2014
    Benson, NY
    I have a YTX24HL-BS sitting on a shelf that I've had for a couple years. When needed I will have to fill it, then seal it and charge it
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Bensonoid View Post
    That's a new one on me. Thanks for correcting me.
    2014 RTL Platinum
    The YTX24HL battery Deanna speaks of is factory filled and comes with a tag in the box that tells when it was manufactured and how long to charge and what rate to charge at.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Mar 2013
    Marion, Arkansas
    Go to Ebay and do a search. They have plenty of them. Thats what I did recently.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Northern Kalifornia
    I used to do the same thing years ago. Always had a battery standing by ready to go. Now there's a battery dealer almost on every corner so no real reason to hoard a battery anymore.
    May 2014
    Benson, NY
    Here's one of the many reasons why I'm glad I hoarded a battery. I got it for almost 1/2 price what they cost now.
    Sena 20s
    Northern Kalifornia
    That's an excellent point and a smart move. I did the exact same thing with a rear tire. One other reason I did it was the availability issue.
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    @2dogs, tires have an expiry date, they go bad when stored too long... Tires you don't use that often, like on a trailer that gets used only two or three times a year, are more likely to break as tires, than tires that are used reguraly.
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    May 2014
    Benson, NY
    Yep, nowadays it doesn't hurt to have a couple items on hand that you know you're going to need.
    Sena 20s
    Dec 2015
    Oakley Utah
    Yeah but how are you going to know which 'items' you're going to need? Maybe keep a spare Spyder handy for parts?
    2014 RTL Platinum
    May 2017
    Cedar Rapids, IA
    I just discovered a week ago that I was in dire need of a replacement battery for my 2019 Spyder RT Ltd. I started calling dealers, who were primarily hoping to receive batteries soon (fingers crossed). We happened to be planning a weekend visit to our children in the Twin Cities (250 miles North from our home). I called Leo's South (1635 Kenrick Ave, Lakeville, MN 55044, tel 952/435-5371), and they said they had 16 direct replacements (Yuasa 24HL-BS) in stock and would prepare one for me to pick up the next morning as we passed the dealership. We stopped, the battery was ready, and I installed it (with a bit of bitching) in the Spyder as soon as we got home. GREAT SERVICE!!!
    Northern Kalifornia
    I tried that one with my wife but it didn't fly.
    Northern Kalifornia
    Quote Originally Posted by Piratezz View Post
    A good friend of mine spent his vacation stranded on the Alcan hwy for that very reason. A trailer tire shredded and caused lots of damage rendering the trailer untowable. A bush piolet landed on the hwy and took his wife to the airport and got her home in time so she didn't lose her job. Finally he found a tow company to haul his trailer away on a flatbed. Throughout all this, he ended up buying a new truck and trailer. An F550 and its transmission failed on him twice before he got home. The vacation from hell was caused by a shredded trailer tire.
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Value Accessories has a battery for the Spyder on their website .Shows to be in stock.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    I just purchased this (MMG-6) for our shop F3. A bit spendy. But I've found a lot to like about these batteries. I was looking for a low maintenance solution that would last longer than the Yuasa AGM's I had been purchasing.
    420 CCA as compared to the ODM battery's 350 CCA.
    3 lbs. as opposed to over 17 lbs.
    Lithium should last longer than AGM. Especially in a less than daily used machine.
    Quad terminals make it a universal fit.
    I put one in my GS, 5 years ago and it is still going strong. It doesn't run down when I let it sit like the AGM batteries I've had before. It really turns the engine over with authority. And I've experienced none of the issues that some say accompany a lithium Ion battery. Since I don't plan on riding at over 26,000 feet. I should be good for a long time.
    I'm always looking for a better mouse trap. This one is a little expensive. But my wish to buy it, install it and forget about it has been worth the expense. Just another option.
