Results 1 to 25 of 26
    Apr 2020
    Edgerton,WI
    Default Fitted a Train Horn from LaMonster!
    Note: I modified the instructions so as to keep the Baker Leg Air Wings.
    Thought a bit more about my install…. Top picture is my latest brain fart.
    2019 F3L , Covid Blue
    Active Member robtdonna's Avatar
    Ellijay, Georgia, United States
    Does your leg rub against it when ryding?
    Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
    BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
    Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
    Apr 2020
    Edgerton,WI
    Red face
    No, plenty of room
    Aug 2019
    Stoughton, WI
    Mine will be here Saturday. It looks like you mounted yours differently from his video. You didn't use both clamps on the frame tube?
    2022 RT Sea To Sky
    Apr 2020
    Edgerton,WI
    Correct…. I moved mine back Due to Baker Leg Airwings…..
    I removed the $45 OEM Trim piece and used the top mounting hole to secure horn. Then I fabricated a trim piece to cover where the OEM cover was . I didn’t want to cut a $45 cover in case I want to revert back to stock.
    It’s loud! I think you’ll have fun scaring the wife!
    Aug 2019
    Stoughton, WI
    Yup ... It's L O U D
    2022 RT Sea To Sky
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    Will it fit anywhere on an RTS
    Apr 2020
    Edgerton,WI
    LaMonster is working on a solution for the RT.
    Quote Originally Posted by bikerchris1270 View Post
    I hope it'll fit a 2013 RT too!
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Let's hear a sound link if you can get it.
    2014 RTL bought in 3/20 with only 6,000 mi.
    Came with Garmin 660
    Car tires in 5/20; Elka stage 2 front shocks in 10/21
    Mar 2021
    Maryland
    Quote Originally Posted by redrazor View Post
    Here you go from his video of it, go to 8:30 to hear the horns...
    2020 F3 SE6
    2020 F3 , Black
    Mar 2013
    Marion, Arkansas
    I ordered mine last week and should have mine the first of next week.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by CloverHillCrawler View Post
    Yeah .. And as Lamonster stated, the video does not do the volume justice. It is funny loud
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    Saw this fitment from an individual on FB. Clean look tucked inside the frame tube. I wonder how much sound gets blocked out ?
    2022 RT Sea To Sky
    Aug 2019
    Stoughton, WI
    Hellz yeah .. This is the way to go with the F3 horn mounting. Pretty much inconspicuous and clear shot to the front. I told the originator to forward this idea to Lamonster..
    2022 RT Sea To Sky
    Default Lamonster's Train Horn
    Anyone install one yet? Looks like it could rub on your leg while ryding. Comments?
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by robtdonna View Post
    No rubbing at all in either configuration. The inner mount is far less conspicuous.
    2022 RT Sea To Sky
    Well tried to order one, out of stock...already. In black that is, he does have the chrome .
    Aug 2019
    Stoughton, WI
    Second time they were out of stock in black. Betting they have them by end of the week.
    2022 RT Sea To Sky
    That'd be nice. I'll keep checking.
    Mar 2021
    Maryland
    I ran into the same thing, I just went to the MotoHorn site and ordered the kit from them in order to get the black one.
    https://motohorn.com/usa/
    They have the kit at the same price as lamonster. It is an introductory price for this new line. Use the code THANKYOU for 20% off. I also found a video on their site with a better sounding video of the horn.
    https://storage.googleapis.com/motoh...ideoMainB2.mp4
    also another pic of a mounting solution...
    More pics here... https://motohorn.com/gallery/can-am-spyder/
    2020 F3 SE6
    2020 F3 , Black
    Aug 2019
    Stoughton, WI
    Hopefully it comes with the same cut to length wiring harness/connections that Lamonster supplies. No guesswork on the install. I like the way the horn is mounted in that photo. Doesn't appear to use any clamps, albeit using a side cover screw and drilling a rear mounting hole. I like my horn hidden.. Stealthy
    2022 RT Sea To Sky
    Springfield, MO
    We are out of stock on Black right now but should get a shipment in tomorrow and another large shipment in next week. I built the plug and play kits already so they will be ready when the horns get here. I love showing customers how loud they are.
    I added the black version WITH your wiring kit to my wish list on your site! Will that generate a notification when they are in stock?
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    thinking of getting 3 horns
    2019 f3t , titanium
