Anyone installed Phone Charger USB Port....in Toggle switch area???
Has anyone ever installed a USB phone charger/USB port in the centre position of the Toggle switch area where your toggles for the lights, heated grips setting, etc. are located? I have a 2015 CanAm Spyder RTS.
Can't speak for all providers of Spyder stuff, but Pierre at canamspyderaccessories.com sells what you're asking about and has a nice installation video as well.
2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
I installed a dual USB port and voltmeter in my 2021 RTL. The problem with the 2021 RTL is that the hole in the dash is longer than "normal" plugins for autos. I think the hole size changed in the 2020+ models. I did find an adapter for $8 on eBay.
2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Magic Mirrors, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug, Lamonster belt tensioner, Baja Ron sway bar, NBV highway pegs, BRP arm rests M2 suspension.
