Results 1 to 25 of 42
    Jul 2013
    Central, NY
    Default Where to purchase Kenda Kanine rear tire?
    Greetings all,
    Long time since I've been on here.
    I'm trying to order a Kenda Canine rear tire for my 2018 RTL but it seems to be backordered everywhere I look.
    Dose anyone have a source where I may purchase one?
    Thank you in advance
    Sincerely
    Lewis Seifried
    Quote Originally Posted by Lou View Post
    Greetings all,
    Sincerely
    Lewis Seifried
    Well this interesting .... Kenda tires for Spyders are ONLY sold through the Dealer network ( this was confirmed by a member here who has a tire dealership and KENDA wouldn't sell Him Spyder tires ) ..... So this makes me think the Kanine's arn't CERTIFIED by BRP for Spyder use .......... Does anyone here who owns the Kanine's know if " FOR SPECIAL MTC. USE ONLY " IS EMBOSSED ON THE SIDEWALL like the regular Kenda Spyder tires are ????? ..... thinks .... Mike
    Aug 2013
    SF Bay Area
    Well this interesting .... Kenda tires for Spyders are ONLY sold through the Dealer network ( this was confirmed by a member here who has a tire dealership and KERNDA wouldn't sell Him Spyder tires ) ..... So this makes me think the Kanine's arn't CERTIFIED by BRP for Spyder use .......... Does anyone here who owns the Kanine's know if " FOR SPRCIAL MTC. USE ONLY " IS EMBOSSED ON THE SIDEWALL like the regular Kenda Spyder tires are ????? ..... thinks .... Mike
    Look it up. This is what I found when I did. https://powersports.kendatire.com/en...street/kanine/
    So far I can’t find anyplace that has them in stock. I’ve been told early summer.
    2021 F3 Ltd , Magna Red
    Feb 2019
    Portland, Oregon
    Why would you want a Kenda when the are far superior car tires out there for way less $$?
    Nov 2018
    Waynesboro, PA
    link was to the wrong tire
    My Spyder
    2012 RTL , Brown
    Look it up - .... maybe " Lou " should look it up, I would never buy either tire ..... Mike
    INDIANA, USA
    Default Kenda Kanine
    Well this interesting .... Kenda tires for Spyders are ONLY sold through the Dealer network ( this was confirmed by a member here who has a tire dealership and KERNDA wouldn't sell Him Spyder tires ) ..... So this makes me think the Kanine's arn't CERTIFIED by BRP for Spyder use .......... Does anyone here who owns the Kanine's know if " FOR SPECIAL MTC. USE ONLY " IS EMBOSSED ON THE SIDEWALL like the regular Kenda Spyder tires are ????? ..... thinks .... Mike
    My Kenda Kanine has it embossed on the sidewall.
    'For Special Motorcycle Use Only'. I got the tire last May. I purchased it from the Spyder Dealer and they installed it.
    They will not install anything else. .....
    ENJOY YOUR LIFE WITH A SPYDER
    Try Lamonster Garage
    Quote Originally Posted by Little Blue View Post
    Thanks for the info .......... Mike
    Jul 2013
    Central, NY
    Lou did look it up, They are 4 ply not the crap 2 ply of stock and they also state that it is the ONLY aftermarket tire approved by Can Am....What did you look up?
    I checked the specs for the " Kanine tire " right after it was introduced. .... It didn't have " 4 " plys at that time, the specs were the same as the Reg. Kenda's. So if it has " 4 " plys Now, they changed the carcass specs. ..... Mike
    INDIANA, USA
    Default Kenda Kanine K20
    ...I have looked at My Kenda Kanine and it only shows the tread as 3 ply. The sidewall is only a one
    ply. This is a October 2020 made rear tire.
    This is on my Spyder. ......
    Active Member mecsw500's Avatar
    Sep 2021
    UT
    Apparently Kenda tires are distributed in the US by Tucker (tucker.com). Perhaps a call to your local Tucker dealer might help you find, or at least be able to order or transfer, the tires you need.
    Tucker has hundreds of dealers U.S. wide so somebody may have the ability to order them from one of the Tucker distribution points. The tucker.com website has a pretty good dealer locator page and I see there's about 5 or 6 Tucker dealers in the greater bay area, so one of them might be able to help.
    Or things might be as bad as one could fear and nobody has them.
    Can Am Syder RT Limited (2021)
    Triumph Bonneville T120 (2018)
    2021 RT Limited , Silver
    PA
    Lou as a side question where did you take your avatar / Id picture? Cool shot!
    Active Member FlyBoy2121's Avatar
    Aug 2018
    Canada
    I Guys
    I bought mine from an independent seller.
    FlyBoy2121
    2014 RT ltd , original original Cognac
    Mar 2013
    Lamount posted that they are backordered, so he has none.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Oct 2020
    KS
    Greetings all,
    Sincerely
    Lewis Seifried
    Try these folks: https://www.midwesttraction.com/stor...e-street-tire/
    2021 Spyder RT
    Feb 2022
    New Zealand
    Has anybody got a recently removed late model tyre. Perhaps they could cut it with a hacksaw or something and have a look at it end on. Then post the images. Easy enough to see just how many plys are there I reckon. 1 ply or a bunch more. I will cut mine when its stuffed but it will be a while. My new to me 2017 F3 came with new tyres and im far too thrifty to chuck them as so far they seem to be doing the job.
    Feb 2022
    New Zealand
    ...Oh ! please don't wait .... I'm sure everyone here Needs to know this valuable bit of information ..... JMHO .... Mike
    Up to a few days ago you had no idea of how many plys may or may not be in the modern up-specked tyre.
    Been banging on at every opportunity how crap they were. Possibly true the last time you had any correct information.
    They seem to have redesigned them in later times, haven't they??
    Some say 1, some say4 , some have said 3 and 1 on the side I have seen lately.
    Hence my question.
    Nov 2017
    San Francisco Bay area
    Ok time to settle down with the sarcasm and swearing. Discuss the tire don’t make it personal.
    Mods are now watching this thread
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Oct 2021
    Wichita, KS
    The guy just asked where to buy the tire. Not what you thought of said tire. I see that a lot on this forum. The negative comments get old and always seem to come from the same sources but I guess it is what it is.
    I want to know how Blueknight deleted his post? I cannot figure out how to do that.
    Peter Pan has struck again!
    Quote Originally Posted by FrogmanDave View Post
    HE didn't! And you can't! Sorry, but that's just the way it is now!
    That Delete privilege was removed because people were abusing it to the extent that the Forum was rapidly dropping out of the various Search engines results, which meant that the Forum wasn't getting anywhere near as much traffic or views as it had been, and the Owner & our Sponsors were no longer getting value for money from the $$ they put into the Forum! It went on to such an extent that it really threatened the continuing operation of the Forum, and it was only by removing the Originator's Delete facility et al that we were able to turn that around & start getting the views & traffic back enough that the Owner & our Sponsors felt it worth their while to continue supporting the Forum & let it keep operating! And we all want the Forum to keep operating, don't we?!?
    Harrington, Australia
    You can do the next best thing, Dave……. if there's anything more than a minor edit required, simply PM any Mod (look for the Green Usernames) and ask them to help. They can do things that we can't!
    Last edited by Peter Aawen; 04-30-2022 at 08:28 PM. Reason: Revised recommendation. ;-)
    HeliBars Handlebars
    Kenda Kanine rear.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    Since I'm not mechanically inclined, and there's no one local to help me, I'm stuck getting Kendas installed by my dealer.
    As it happens, I'm down to the wear bars on my rear. So I contacted my dealer. None in stock ay the moment. First they said end of April, then they said May. Today, they said June. I asked if, due to this non-availability, would they waive their policy against installing non-OEM tires; they said no.
    Must be one of those "supply chain" issues. Maybe the tires are sitting in a freighter off the west coast.
    So BRP's anal-retentive policy against installing non-OEM tires is going to keep some riders sidelined for the next several months, and apparently they're OK with that.
    Active Member sgerksinwi's Avatar
    Jun 2019
    Wisconsin
    Just got done with a place.
    They told me Manufacturers date is 7/22.
    Ouch.
