Results 1 to 25 of 46
    Danbury Connecticut
    Default ***** What Tires are on YOUR Spyder - Details Please *****
    There's been a lot of talk about a sticky for tires. The purpose of this thread is to create a place for you to share your information.
    I'll start:
    Spyder: 2020 RTL
    Type of Riding: Mostly touring. Not terribly aggressive.
    Suspension: RonBar, Laser Alignment
    Front Tires: Kumho Solus KH16 175/55/15, set to 17 PSI
    Rear Tire: Cooper Mastercraft LSR Grand Touring 215/60/15, set to 26 PSI
    Current Mileage: About 12,000 miles. They still look brand new.
    Comments: Bought the tires for my previous Spyder and put about 6,000 miles on them. I liked them so much I had them transferred to my 2020 RTL before delivery.
    The tires, alignment and RonBar were all installed by Netzley Tire in Accord New York. I'm very pleased with the tires and Remarkably Pleased with Netzley Tire.
    Moderator Edit:
    THREAD RULES
    This thread is for providing the above information ONLY! Any other discussion will be removed. If you have any questions or comments, see one of the many other tire threads (search is your friend) or PM the Member who posted the info you wish to question/discuss.
    Last edited by Peter Aawen; 02-11-2022 at 06:37 PM. Reason: Created Sticky & added caveat/Rules
    IBA #47122
    2020 RT Limited Asphalt Grey
    Spyder: 2013 RT-L
    Type of Riding: Spirited Twisty ryding; long/hot distance touring; occasional track/test work
    Suspension: RonBar; Laser Alignment; ECU Upgrade with inlet & exhaust mods
    Front Tires: Oz spec Kumho Solus 175/55/15, set to 15 PSI
    Rear Tire: Oz spec Michelin (tba) 205/65/15, set to 17 PSI
    Current Mileage: Fronts - 30,000 ish miles; Rear - 20,000 ish miles. They still look very good with even wear & no heel/toe
    Comments: I do adjust my tire pressures on a daily basis to suit any changes in load, ambient temps, road surface or conditions; &/or what I'm doing, and I occasionally swap these tires out to test/evaluate others. This combination of tires particularly suits my need for Sport/Touring All Season/All Weather tires & the long/hot distances I frequently cover here in Oz.
    Northern Kalifornia
    2014 RTS Se6
    Front tires Federal Formoza 165/R55 75V
    Rear tire General Altimax RT43 215/60R 15
    Clinton, MS
    Spyder: 2019 RTL
    Type of riding: Mixed. Country backroads, 50 to 500 miles at a time. Interstate 75++ cause if you see me on one I'm in a hurry.
    Suspension: BajaRon swaybar and shock preload adjusters. Laser alignment.
    Front tires: 175/55R-15 Vredestein Q5's 18 PSI 23,000 miles
    Rear tire: 205/65R-15 Vredestein Q5 18 PSI 25,500 miles
    Current mileage: Front 23,000 miles Rear 25,500 miles Still in good condition
    Comments: Rear tire corrected speedometer to 1/2 MPH low at 70 MPH.
    Found the hard way that 175/65R-15 are too big for the front.
    Tires have been excellent in rain. Very smooth. Good dry traction.
    Sep 2012
    Stetson, Maine
    On my 2011 RTS I have General Alitmax on all 3 wheels. I like them.
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Dec 2012
    Murphy, NC
    SPYDER: 2015 F-3S
    SUSPENSION: Ronbar and laser alignment
    FRONT: Hankook Ventus V4 ES. 175/55/R15
    REAR: Hankook Kinergy PT H737 215/60/R15
    I have almost 36,000 on the front tires with 18 lbs psi. Should be able to get 40,000 or more. The rear tire is brand new at 20lbs psi.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Aug 2019
    Stoughton, WI
    2019 Spyder F3-S
    Type of riding: 100% solo - 80% spirited/20% touring
    Suspension:
    Front: Fox Podium 1.5 shocks with uprated Ohlin springs
    Rear: Wilber 640 HPA
    Laser aligned
    Tires:
    Front: Vredestein Q5's on PPA wheels 17.5#
    Rear: Goodyear winter ultra grip 215/60R15 20#
    10k miles on the front/like new. Gonna try the rear Goodyear after, literally, 200k+ miles of using them on my trooper cruiser. Loved them. We shall see on the Spyder...
    2022 RT Sea To Sky
    Mar 2015
    forrest above Reno, Nv
    . Vredesteins in front and General Ultimax on the back. Just ordered a new General Ultimax 43 also. Lots of mountains here and some long trips planned.
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2015
    Chilliwack, BC. Canada
    Same as Lew L....Vredesteins on front and General Altimax 43 on rear. Just putting the Altimax on the rear this week. The fronts are at 16 psi and the rear I’ll start out at 19 psi and see how that is.
    Tri-Axis Chrome Handlebars
    Sena SM10 BT Dongle
    Double USB Port/Volt meter
    LaMonster Magic Mirrors
    BajaRon Swaybar
    HALO Skid Plate
    Shorty Antenna
    LaMonster Cat Delete
    Akrapovic Muffler
    FOBO2 TPMS
    Rear Trunk Rack
    Bruce Erickson
    Chilliwack, BC
    Canada
    2014 RTS-SE6 - Cognac
    Active Member ButterSmooth's Avatar
    Sep 2020
    Central Oregon
    Spyder: 2020 RT
    Type of Riding: Solo, brisk
    Suspension: stock
    Front Tires: Vredestein 165/60R15 20psi
    Rear Tire: Yokohama Avid S 215/60R15 24psi
    Current Mileage: About 4,000 miles rear, 13,000 front. Many miles to go.
    I increased tire pressures (from 17psi front) when I felt the fronts rolling under on hard steering inputs.
    Head in the game, eyes down the road... 2020RT
    Spyder Tryke Pylot
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Spyder: 2013 RT-L
    Type of Riding: Touring; Local transportation
    Suspension: Stock
    Front Tires: Vee Rubber 175/55/15, set to 18 PSI Came on Yike (Y-Bike vs Trike)
    Rear Tire: Kumho KU25, 91H, 225/50/R15, set to 22 PSI
    Current Mileage: Fronts - look newish 1K miles; Rear - Brand new
    Can Am 2013 RTL SE5
    Mar 2021
    Haven, Ks
    Spyder: 2019 RTL
    Type of Riding: 40% touring and 60% very spirited curvy roads. Ride apx. 7,500 miles per year. ECU flashed to Stage two by Monster. Riding style would be considered as very aggressive.
    Suspension: BajaRon sway bar, lazer alignment by Lamonster Garage
    Front Tires: Kenda Kanine KR20 165/55R15 55H - Pressure 18 lbs. Handles much better than 20lbs or more.
    Rear Tires: Kenda Kanine 225/50R15 76H - Pressure 28 lbs.
    Current Mileage: About 5000 miles. They still look brand new.
    Comments: I replaced the OEM tires with the Kanine K20 and am pleasantly surprised by their performance to date, much better than OEM tires. I would consider replacing at next tire change with car tires especially if K20's are not available, probably leaning toward Vredestein Quatrac tires but unsure about size. It appears to me that the Quatrac rear tire is not available in factory size but close. My concern with car tires is that some of them seem to have better wet traction than others. Since I will ride in rain or any condition I would not want tires that didn't handle wet pavement well. I am interested in receiving input on suggested car tires and size. Dealer will install any tire I bring in to be installed.
    Bartender
    2022 Spyder Sea to Sky
    Feb 2020
    Minnesota,USA
    Spyder: 2020RTL
    Type of Riding: 70% 2-Up touring, 30% most anything goes! Aprox 9000 miles last season,
    Suspension: Still stock (sway bar near future)
    Rear Spool: Kumho KU-22, 205/55R15 (non-directional) 20 psi.
    Front: Spools: Kumho KH-16, 175/55R15 (non-directional) 17 psi.
    Old rear Kenda wore out (wires sticking out) at 10,649 miles, Front Kenda developed cupping at about 14,000 miles.
    Love the ride of my New car tires, Added the Centramatic wheel balancers on all 3 wheels, Nice Smooth Ride Now!
    ........Bill
    Last edited by Peter Aawen; 07-31-2022 at 01:52 AM. Reason: Fixed tire size/spec ;-)
    10W40 Amsoil Synthetic Motorcycle oil
    If in Doubt, Don't Do It!
    Feb 2012
    Spring City,Utah
    Spyder: 2012 RT-L
    Type of Riding: spirited Twisty riding; long distance touring varied Spring, Summer(hot), Fall touring mostly single but occasionally two up with trailer. About 12,000 miles/year.
    Suspension: Baja Ron Bar; Laser Alignment
    Front Tires: Cooper tires
    Rear Tire: Pirelli no longer made
    Current Mileage: Fronts - ?; Rear - 20,000 ish miles. The fronts still look very good with even wear. The rear is wearing even across and has maybe 1500 miles left.
    Comments: I have my tires mounted at my local tire shop here in rural Utah and they have never balked at me bringing my own tires. The first time I did buy a Mastercraft from them which I liked very much and it lasted 40,000 miles. I also bought my current Coopers there. I let them remove the fronts but I bring the rear wheel in for them to mount and then remount the wheel on the Spyder myself. I run 15 to 18 lbs front and 18 to 20 in the rear. Tires are as close to stock as possible given the brand being used.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Nov 2016
    Upstate NY
    2014 RTS
    Front- Federal EVO 165/55-15
    Rear- General Altimax RT43 215/60-15
    2021 S2S RT
    Front- Federal Formoza AZ01 165/55-15
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Spyder: 2017 RTL
    Type of Riding: touring, mainly 2 up, some with Freedom trailer, back county roads, and some Interstate when needed
    Front Tires: Federal Formoza AZ01 165/55R15 @ 17#
    Rear Tire: General Altimax RT43 215/60R15 @ 18#
    Current mileage: around 9000 miles on front & back - put on at same time
    I love these tires, they have all I need for the way I ryde. Would put same tires back on when needed if available.
    Last edited by Peter Aawen; 07-31-2022 at 01:54 AM. Reason: Fixed tire size/spec ;-)
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Jan 2019
    Hunter Valley NSW Australia
    Spyder: 2017 RTL
    Type of Riding: Day to day running, touring (solo - two-up - two-up+622 trailer), some sport touring, the occassional hot run. Will ride in any weather except hail
    Suspension: (Fr) Wilbers 630 Front (Rr) 640 with remote adjuster, adjust dampening depending on ride (freeway vs country road vs MotoX track disguised as country road).
    Front Tires: Nankang XR611 165/65R15 20 psi dry, 18 psi wet
    Rear Tire: Nankang XR611 225/50 R15 26 psi dry, 24 psi wet
    Current Mileage: Fronts 40,000kms, rears about 20,000 per tyre (I don't let them wear all the way) Spyder has 68???kms on clock
    Comments: Switched from OEM Kenda to Arachnid saw improvement ditched it, and tried the Nankangs. Decided to give aftermarket shocks a try + sway bar, but aftermarket shocks have addressed the issues sufficiently. Not one to be too concerned about mileage, prefer grip and handling. Alignment done by my very competent dealership mechanic. I was ready to abandon Spyders until this combo resulted in a very tidy ride and convinced me to stay with the product.
    PSOP excellent idea
    2017 RTL
    2017 RTL , White
    Linden, CA
    I am using Michelin Tires all around I got them from our local Costco they mounted & balanced them
    the rear was tricky I had to remove the brake and pulley from the wheel
    Please see the reminder below from the opening post of this sticky - if you want to keep the sticky here &/or going, please post accordingly.
    Moderator Edit:
    THREAD RULES
    Feb 2022
    very southern tip of Texas
    Recently bought the 2015 F3-S. Has factory original Kendas in front, and selling m/c dealer installed a brand new Kumho Ecsta AST rear, size 225/50R15. Know nothing about it so far. Will try to remember to revisit this thread once we get some miles on it. Looks like 20-22psi should be about right on the rear. Spyder has right at 6K miles on it.
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
    Jul 2017
    Woodbine, Iowa
    2014 RTS Se6
    This is the same as I run on my 2019 RT. I have about 20,000 miles on my rear now and just received an other General to replace it. I have used these tires on my 2015 RT and now my 2019.
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Active Member sledge's Avatar
    Aug 2021
    Limestone Tn.
    Tomorrow ... putting them On... 225/50R15 Kumho ESCTA & 165/65R14 Sincera
    2011 RTS Spyder
    Oct 2017
    N.E. Ohio, USA
    I just ordered 165/60/15 Vredestein tires for my 2018 Spyder Lt.
    Last edited by Peter Aawen; 04-26-2022 at 11:42 AM. Reason: Removed questions/additional discussion & following discussion posts as per thread rules!
    Ride safe!
    2018 Spyder RT Limited
    I'll start:
    Spyder: 2020 RTL
    Moderator Edit:
    THREAD RULES
    Active Member SpyderGoldwingOwner's Avatar
    Jul 2021
    Texas
    Oem tires
    2020 Can-Am Spyder RT
    2018 Honda Goldwing DCT
