Results 1 to 13 of 13
    Very Active Member DriftersWay's Avatar
    Jun 2013
    Uniontown, Pa
    Default Installation of Garmin XT - which acc circuit for key on hot?
    Just got my 2022 F3-L and want to install my Garmin XT. I want the GPS
    to come on with the key. I found 3 customer accessory circuits, 1 in the
    trunk 1 under the left access panel and 1 under the passenger seat.
    Question is does anyone know if they are always hot or
    do they come on when the key is turned on? Or is there a different way
    to connect it? Thanks for any help.
    2022 F3 Limited , Monolith Black / Dark
    Mar 2021
    Arizona high country
    in my 2018 F3 Limited the one under the left panel was on with the key only. Don't know if that has changed or not.
    Oct 2015
    Lynden, WA
    On my F3T all three ACC circuits are tied together and share a common fuse.
    All are keyed to be on with the engine running.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Active Member RickWB's Avatar
    Jul 2019
    Duncan, British Columbia
    I connected my Zumo XT on the accessory circuit under the left panel. Works great.
    Rick
    2019 F3 base
    Shad saddlebags with Admore led light kit
    BajaRon swaybar
    Hopnel mini bra
    BRP driver's backrest
    Madstad windshield
    Ultimate floorboards
    CanAm Spyder accessories rear shelf with LinQ adapter
    Mar 2020
    Prior Lake, MN.
    The are hot with the engine running only, not with the key on. I just installed my Zumo XT using the one under the left side panel. Good Luck!
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Quote Originally Posted by WillieB View Post
    Yep same wire used here, its a bit annoying that it only works when the engine is running rather than just having the ignition on but at least the XT has a reasonable battery. The one on my 590 used only last a couple of minutes.
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    In my 2018 I found the customer accessory in the frunk have power only whit the engine running.
    So I used the one in the left panel under the seat. It has power whit the key on.
    2018 Spyder F3 Ltd
    2018 F3 Ltd. , Black/Dark
    Mar 2021
    WillieB is correct my 2018 F3 limited only has power when the engine is running using the one under the left panel. I originally thought it worked with the key on, because the I always started the engine.
    Sep 2021
    Fredericksburg, VA
    If I did this correctly the below picture is where the GPS power connector is on the F3.
    I purchased the connectors on Amazon. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    RiderDuke
    My Ride
    2021 Glacial Blue Metallic F3-T
    Mar 2020
    Prior Lake, MN.
    All three connections are hot only when the engine is running.
    Sep 2021
    Fredericksburg, VA
    The GPS connector I mentioned above is hot with key on. The bike does not need to be running. You are correct for the other circuits
    RiderDuke
    My Ride
    Nov 2016
    Not in mine. The one in the frunk is hot whenn the engine is running but the one on the left side under panel is hot with key on. I'm sorry but i didn't test the third.
    2018 Spyder F3 Ltd
    Nov 2016
    Quote Originally Posted by RiderDuke View Post
    I agree. 2018 f3 LTD it is so.
    In fact I used this wire to give a positive signal to a relay controlling a fuse box when I put the key "ON"
    2018 Spyder F3 Ltd
