Results 1 to 25 of 36
    Jun 2021
    OR
    Default Cluster Update 50.1 available.
    Just got my Buds software and found that there is a version 50.1 firmware available for the dash cluster. I loaded it but not sure what was updated and can't find any information on it. Just thought I'd let you know in the event anyone wants to update their dash cluster. I have a 21 RTL so I am not sure if it will also be for the 2020.
    2021 Spyder RT Limited
    Apr 2020
    Edgerton,WI
    Quote Originally Posted by shardt View Post
    Just got my Buds software and found that there is a version 50.1 firmware available for the dash cluster. I loaded it but not sure what was updated and can't find any information on it. Just thought I'd let you know in the event anyone wants to update their dash cluster. I have a 21 RTL so I assume this is for 20-21 RTs.
    Thanks for letting us know.
    2019 F3L , Covid Blue
    Feb 2016
    Downloading it now. I'd like to see it add the day/night dash colors.
    2020 RT Limited , Marsala Red
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    I'd be interested to know what gets upgraded as well.
    2021 RT Base - Petrol Blue
    Jun 2014
    Schenevus NY
    I thought you couldn't download bike software updates unless you were an actual dealer with an actual dealer account?
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Mar 2020
    West Bend, Wisconsin
    How do you download an update on the bike and install it? and how do you know what version of you have?
    I did find out how to see what you have - The version of the display firmware installed on your vehicle can easily be found under the “settings” (long press on the center of the controller located on the left handlebar, last menu at the bottom). Choose the second-to-last menu titled “About.” The firmware version is at the top of the screen.
    But it does not tell how to update if needed.
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by Speedy88 View Post
    you can see what the version is by looking thru your bike menu
    FOR 2018 & UP
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by Trbayth View Post
    you have to buy the diagnostic software called "BUDS" or "BUDS2", not cheap, but will allow you fix all those things a dealer can do.
    Jun 2021
    OR
    For the 21 Spyder RTL you also need a USB A male To USB A male cable also that does not come with the kit. Not sure about other years.
    Jun 2015
    Hampton Roads, VA
    Where can one download it? Thanks!
    Jun 2014
    Schenevus NY
    Quote Originally Posted by Woodaddict View Post
    Yeah I know you have to buy the software but I thought only real dealers were able to log into the BRP dealer website to download firmware updates.
    Trb-- (Roger)
    Nov 2016
    Upstate NY
    It depends where you get your BUDS license. If you get it from ebay, your out of luck for updates. If you get it from powersports-diag.com, they have access to the BRP updates and forward them to you upon request.
    Jun 2021
    OR
    I got mine powersports-diag.com and it worked out of the box, I did not have to contact them.
    I did notice that they may have fixed the sensor for the day/night auto switching. It appears to be working much better, still have to do some more testing.
    Jun 2014
    Schenevus NY
    Quote Originally Posted by Joel The Biker View Post
    Thanks Joel. I didn't realize there was a difference.
    Trb-- (Roger)
    Aug 2013
    SF Bay Area
    I think the update is to improve/fix the light sensor for day/night screen. Only the 2021 and newer models have it.
    I don't think the earlier models will have an update. so the 2018/19 should have 20.8 - the 2020 should have 30.7 & the 2021/newer should have 50.1 updated from 40.6
    2021 F3 Ltd , Magna Red
    Feb 2016
    I can confirm that my 2020 RTL has the 30.7 software and does not want to upgrade to the 50.1. I haven't yet tried this update on our 2021 F3...
    Dec 2020
    Hartwell, Ga
    Thanks for this info. Mine also has the 30.7 and I was wondering if it needed updating.
    Mar 2021
    Arizona high country
    If you only need an update and don't want to get 'Buds' the dealers charge $70 (at least that is what it cost me in Phx) to do the update
    Aug 2013
    SF Bay Area
    The 2018/19's should have 20.8 - the 2020's have 30.7 & the 2021 and newer have 40.6 and seems to be only models getting the 50.1 update.
    If you have any works done they will update as part of the work. To just have the dash updated can cost $$.
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    Interesting that the 2020 MY will not get this update. My understanding is that there were no differences in the 20/21 units so we would expect the digital console is likely the same on both.
    2020 RT Limited - Chalk Metallic Dark
    Aug 2013
    SF Bay Area
    Quote Originally Posted by kroache View Post
    Do you have the ability to change the dash from dark to light? The 2021 and newer models have a sensor that will change the dash depending on light conditions. Don’t work too well and this update is a possible fix.
    Mar 2021
    Caledon, Ontario
    My Spyder is still in storage waiting for spring to arrive lol. I don't recall seeing that setting and see no mention in the owner's manual for 2020. I checked the 2021 manual as well and can't find it there either. For "Display" they only mention adjusting the brightness but I would expect if available it would be under the "Display" setting. Thanks for the clarification....will take a peek when I go get my machine out of hibernation.
    Cheers
    Kevin
    Mar 2018
    Ontario ,way up north
    FOR 2018 & UP
    How do i know what version i should be running on my 2018 RT ?
    2018 RTL , dark blue
    Apr 2013
    Hartsville, S.C.
    Quote Originally Posted by stmike 1800 View Post
    It should be 20.8.
    I'm pretty sure 20.8 added the "distance to empty" display option DTE. Predicts how much further you can drive by calculating using your average mpg.
    2021 RT Limited Asphalt Gray
    Halo Skid
    Driver's backrest
    2" riser w/ F3 standard handlebars
    F4 vented 25" windshield
    Jan 2021
    Oklahoma City
    From 2021 RT Owners Manual
    2021 Spyder RT Limited (Sea-To-Sky)
    2022 Ryker Rally
