Results 1 to 9 of 9
    Jul 2011
    Mitchell, Ontario, Canada
    Default New Garmin NA map available.
    For those of you with a Garmin GPS with lifetime North American maps. A new version (2023.1) was released on Feb 2.
    Happy downloading.
    Oct 2015
    Lynden, WA
    Thank You.
    Just did an update on my Zumo 396.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Dec 2015
    Oakley Utah
    Thanks for the heads up
    2014 RTL Platinum
    INDIANA, USA
    Default GPS Software Update
    YES, Thank You for the heads up on the new software. ......
    ENJOY YOUR LIFE WITH A SPYDER
    RT-S SE PE#0192
    Sep 2007
    Topeka, KS
    So it sounds like most of you are using Garmin GPS. We have a new to us 2016 RTL. The previous owner kept the original gps, he did leave the mount on the Spyder. I thought I'd just get a new Garmin XT to replace the original. It looks like the new XT won't work, I was watching a U Tube video on it doesn't use the same mount. Anybody know anything about this or if it won't work what should I use?
    Thanks,
    Dwight
    Sep 2020
    Middletown, NJ
    Quote Originally Posted by Dwight View Post
    Thanks,
    Dwight
    Can't answer your question without knowing what model the mount is for (or a picture of the mount).
    Re: XT, If you buy one, make sure the battery stays charged. A friend and I just returned brand new XTs. Came dead and after 24 hr charge and no use for 2 days after, dead again. I stayed with 595.
    2020 RT base , Chalk White
    Feb 2012
    Spring City,Utah
    I think your Spyder came with a 660 Garmin Zumo. There are plenty used and refurbished out there so you should be able to find one in the 200-300 dollar range.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Quote Originally Posted by RayBJ View Post
    ...Re: XT, If you buy one, make sure the battery stays charged. A friend and I just returned brand new XTs. Came dead and after 24 hr charge and no use for 2 days after, dead again. I stayed with 595.
    The battery in the Zumo 590 I purchased in 2015 for my Spyder lasted about 3/4 of a year and then wouldn't charge more than about 75%. Garmin replaced the battery under warranty.
    The only Zumo cradles I know of that are compatible with each other are the 590/595. IMO, one should remember that Garmin, like a number of other manufacturers, designs their Zumo GPSs from the ground up for at least one and probably a number of reasons that involve more than just the cradle and, therefore, if a later model GPS doesn't fit a previous design cradle one just has to pull on the big boy britches and deal with it.
    Active Member GFrog's Avatar
    Jan 2022
    Bedford, Nova Scotia
    I just bought a Zumo XT from Bestbuy yesterday. I charged it and installed all the updates. I will let it rest for a few days and check later to make sure that the battery stayed charged.
    Thanks for the tip.
    2022 Spyder Sea to Sky Mystery Blue
    2009 Suzuki Boulevard M50 SE
