Question on a Battery Tender pigtail
Hello Spyder riders. I am coming back to the herd as of tomorrow. I previously owned a 2014 RT Limited and kept my battery charged with the old swap the fuse method with the pigtail connection plugged into the cigarette lighter socket in the rear trunk,
Tomorrow I will be picking up a new to me 2020 RT Limited and I want to set up the fuse swap maintenance for the battery on it. I do not know what connections are in the rear trunk of the 2020 at this point.
Do any of you do this on your 2020 or newer Spyder? It seems that I read somewhere that BRP quit putting the cigarette lighter connector in the newer version of Spyders. If so, how do you establish a pigtail connection through the rear trunk.
Any information that you could share would be appreciated.
Bill
Safest way to attach the charger is directly to the battery using an SAE (2-pin flat) connector in the frunk.
probably already there mine was
The dealer added a connector for my battery charger directly from the Frunk mounted battery in my 2020 RT LTD. After I got it home, I added a similar connector for a "cigar lighter" plug. I use the Cigar plug for my TomTom GPS and the battery charger plug for the charger.
Reason: fronk = frunk ;-)
Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
Proud member of AA, PGR, and a Navy Shellback!
SpyderLovers Ambassador
Battery Tender
All good Tips. Pig tail to the battery posts is my #1 choice.
Make sure what ever you decide, use a fuse link. ......... : )
ENJOY YOUR LIFE WITH A SPYDER
I dont know about the later models but on my 17rtl I picked up my positive, always hot lead right at the alternator. It is easy to access and within 15 inches of the left side grill which is where I put my own homemade pair of relays and fuse box. My relays run my very loud horn and my wifes heated clothing and also bring power in from a battery tender.
Reason: . spaces...
: 2017 RTL ORBITAL BLUE
fuse link built into the 2 pigtails from the manufacturers of the pigs
Hi Bill,
I decided to mount a charge plug (still need to find an inconspicuous space on my 2 RTL) - see here: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2021 Spyder RT-L in Deep Marsala Red/Black - BRP Comfort Seat, Adj Handlebar Riser, Running Board Lights, Driver Backrest, Passenger Armrests. Fobo TPMS, Grip Covers, UltraGard Full & Half Cover, Passenger & Driver Drink Holders, Wide-Vu Side Mirrors, Show Chrome Luggage Rack, SpyderExtras Aluminum Belt Tensioner, Show Chrome Accessory Fuse Block, SpyderExtras Adj Highway Pegs, Carbon Fibre Grills, Full Repair and Maintenance Manual, Kapplock Garmin Nuvo XT Lock & Ram Mount Lock, LidLox Handlebar Helmet Lock, Hopnel Dashboard Storage Pouch/Trunk Organizer/Side Cases, Garmin Nuvo XT GPS, Signal Dynamics Heads Up Voltage Monitor, M1 Motorsports F/R Dash Cam, inView Helmet-Mounted Brake and Turn Signal Light, Pedal Commander w/ Silicone Cover & RAM mount, Spyder Extras Driving Light Bar, Denali D3 Driving Lights, SpyderExtras Light Bar, TAC Designs Side Mirror Stabilizer Kit, Carbon Fibre Trim, Hi-Gain Short Antenna, Headlight Skins, Mirror Turn Signal Lights.
I Guys
On directly on the battery is the best
FlyBoy2121
