Results 1 to 2 of 2
    May 2021
    NC
    Default Will ST Limited OEM saddle bags fit on my 2015 STS?
    I know it is probably impossible to find OEM bags for an ST Limited, but if I can find them does anyone know if they will fit on my STS?
    Yes, if it's an ST of any designation & you've got the brackets that come with them, they'll fit.
    In fact, if you can find saddle bags that'll fit an RS, an RSS, or even a GS & you can get the appropriate brackets that hold those saddle bags onto those machines, you should be able to fit them! . The blunt end of all those GS/RS/RSS/ST Spyders is effectively the same & so will take the same saddle bags!
    Good Luck in your search!
