Page 5 of 5 FirstFirst 12345
Results 101 to 105 of 105
  1. #101
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Stopped at Autozone today and picked one up. $26.00.. but I’m glad to have it just in case.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
  2. #102
    You fella's should look at the start date of these threads, and the date of the last few posts prior to posting up; I think this one's a bit of thread (& problem) archeology - ancient history...
    I don't recall reading/hearing/seeing anything too much about relays being an issue on more than the odd occasion since I've been on the Forum.... the odd occurrence, sure, but I wouldna thunk enough to worry about going out & buying spares to carry all the time - at least, not unless maybe you were planning a long distance remote trip that should probably warrant you worrying more about where to get gas &/or how to carry 5 or so gallons for when you ran low miles from anywhere?!?
    But I guess they are your Spyders....
  3. #103
    May 2021
    NC
    Is it the same relay for all spiders? I have a 2015 STS
  4. #104
    Quote Originally Posted by fuelie60 View Post
    If you read back thru the ffirst couple of pages of this thread, there were some 2008/09 RS's that had loose & failing relay problems that prompted this thread & the discussion about alternatives to the OEM relays...
    So unless your 2015 STS is having similar problems, you probably won't need to carry any spare relays! Are you having any start/run problems that might be relay related??
  5. #105
    Jun 2017
    Texas
    Is the same relay used in more recent models ..?
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
