Results 1 to 15 of 15
    Locust Grove, GA
    Default Do you ever use high RPM's?
    Do any of you ever rev your RT up to to high rpm's when going thru the gears just for the heck of it?
    Quote Originally Posted by inspectsir View Post
    No ..... However to maximize " passing power ", I have taken it up to 7000 or so ...... Mike
    Why bother, there's a rev limiter on the engine.
    Two numbers to keep in mind.
    The 990/998 twin engines like 5500 ballpark rpms for the "sweet spot" operation.
    The 1330's like 3500 ballpark rpms for the "sweet spot" operation.
    I have NEVER tested the rev limiter. Sweet-spot has always been my shift spot going up. I let do it's own thing on downshifts 98% of the time.
    Feb 2019
    Portland, Oregon
    YUP....and it's a helluva lot of fun!
    Nov 2020
    Lincoln, Nebraska
    I go visit my buddies a couple days a week for a nice beverage and talk. The route takes me down a not very uncrowded four-lane divided highway for about 6 blocks. It makes a safe place to go through the gears and blow the carbon out. Nothing like 87 miles an hour in third gear
    Mar 2015
    forrest above Reno, Nv
    Of course I do "let her breath "
    With the ECU up grades, pulling to 7k is just fine. And fun also. Did I say my other bike is an old,slow V-Max. The V-boost works--- just be pointed straight.
    Lew L
    2014 RTS , Circuit Yellow
    SoFlo
    Ours has been spun up a few times...Kinda cool seeing the statistic numbers in BUDS. That onboard computer catches and stores everything.
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Well I have pulled out to the 4 lane and ran the revs up to merge with traffic. Why just today I looked down and was at 6000 RPM at 69 MPH after 15 miles down the "slab" and then remembered that I needed to shift up to 6th..... (palm slap to forehead)
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Sep 2016
    Chillicothe, Oh.
    You betcha.
    2015 RT , Black
    Mar 2017
    Salisbury,NC
    of course, if from time to time you like spirited rides!!! get that wind in your face with windshield down. a few times i have forgot that 6th gear. shoot,1st gear @ 7,000 rpm gets up there in MPH!!
    Northern Kalifornia
    Yep.....and me too! But only on lots of empty straight flat pavement.
    Feb 2012
    Spring City,Utah
    998 VTwin. I love to run it up to the rev line. It is still pulling hard and I hate it when it goes soft. I don't do it very often, just often enough to remember what it feels like. I usually shift at 6000 and cruize at 5000. It just purrs there but when I run her up you can hear her roar. No pain, no fear, just a jewel of an engine yelling "I am free let me run."
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Of course, it goes with the machine!!!!!!!!!
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    Yep, when I am alone on the byke, we have alotta farmroads overhere, mostly twolane, with no intersections, no police, no radar, no critters that could jump on the road,,, the spyder likes it, and the owner too.
    With the wife, 2up, I get a dent in the back of my helmet, when I rev (read drive) hard.....
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
