Results 1 to 8 of 8
    Nov 2017
    Western Australia
    Default Front pulley change - Wow, what a job!
    Wow, what a job. Hardest part is probably removing the lower belt guard. Why didn't they use captive nuts!
    Removing the pulley nut was ...difficult. I tried using long leverage bars with heat, no joy. Using a jack under the pry bar (if you can imagine it), No joy. Finally used the engine running and reverse gear method, simple !
    Removing the pulley, very difficult. Finally using my cheap puller and plenty of heat, it came off.
    I check my front pulley regularly and have never noticed rust. Once the pulley nut was removed, I couldn't believe the amount of bright red rust.
    The pulley appears to be not too bad, could probably use it again Ok, but I had a new one so I fitted it.
    I removed side panels and muffler to improve access. As an aside, I checked the BRP belt tensioner fitted 2 years ago, still Ok.
    Now todays job is to put it all back together and adjust.
    Feb 2019
    Portland, Oregon
    BazF....You must have an RT, because it wasn't that difficult a job on my F3L. For the benefit of those reading this, that have never removed the belt guard, the nuts on the back side are 10mm and not fixed in place by welding or whatever. I finessed a box wrench onto the nuts, using the Braille method, and removed the bolt with an impact driver. A socket wrench will do, but I'm lazy.
    I bought a couple 6mm extended U-nuts at my Ace Hardware and slipped those on. Now, no more loose nut syndrome. Strangely, the front bolt - there are three - goes into a female fixed insert. I have no idea why BRP didn't do that with the other two.
    Nov 2017
    Western Australia
    Spyder is an F3T 2016. Same situation with the 10mm nuts and front screw has captive nut.
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by BazF View Post
    It would have helped if you had mentioned the model in the first place.
    Active Member deer30084's Avatar
    Tallahassee, FL
    Glad to hear you did that yourself instead of having it break down on the road because of the worn front pulley like mine did at !8,700 miles in May 2021
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Jun 2021
    tn
    Haven't looked at my pully yet @ 2000 miles. Just wondering can you not use an impact to remove the bolt?
    Sep 2009
    La Valle, WI
    I used an air impact. Bolt came out slower because of lock tight but fairly easy. Take bolt out before removing belt.
    2018 F3 Limited , Oxford Blue
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by chokeslam View Post
    At 2K your pulley should still be in excellent condition. Anytime time is good for a first time to pull it, clean both splines and apply a veneer of Moly Paste - not Moly lube. I have my concerns that what BRP uses is not Moly Paste or similar.
