Results 1 to 25 of 30
    Jul 2021
    IL
    Default Phone mount recommendations
    I'm finding that BRP connect is not all that I thought it would be, and may just use my phone and the WAZE navigation program. I'm looking for recommendations for a specific phone mount that works well on the handlebar of the Spyder RT. I'm assuming that I could keep the phone charging by connecting to the USB port in the "glove box" even if not using BRP connect.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Active Member duke50's Avatar
    May 2014
    IL
    I have a Tackform mount that I purchased from Motorcycle Dave. Its a very good mount, works well with my large phone, highly recommended
    Mar 2016
    north dakota
    I also have the Tackform mount from Motorcycle Dave. Works very well with iPhone. It is mounted through one of the 4 bolts on the center handle bar mount on 2021 RT. Very solid. I connect my iPhone with the USB from the glove box for charging. I use the Maps app for navigation.
    Jul 2021
    IL
    Did you get a handlebar mounted model or the center mounted model? I'm not anxious to unbolt the center bolts and I guess I would lean toward the handlebar mounted one.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    Nov 2013
    Central Texas
    Not a problem to remove one bolt, as you would be replacing it with one supplied with the Tackform mount. by far the best phone mount out there, well made, solid and fits a wide variety of phone sizes. You will not be disappointed.
    Mar 2016
    north dakota
    I used the center mounted model. As mentioned above a replacement bolt is supplied with the mount it is slightly longer for mounting the Tack form center mount.
    Jul 2021
    IL
    Does the phone holder get in the way of the glove box, or block the screen at all? And I notice on the website that no prices are shown. What would that phone mount cost me?
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    May 2014
    IL
    call Dave he will answer all your questions
    Linden, CA
    Default Tackform
    Check out this video
    https://www.facebook.com/TackForm/vi...83358072459218
    For the best BAR NONE strongest safest phone mount call me
    209-887-3283
    9:00AM to 8:00PM Daily Pacific Time
    Active Member kroache's Avatar
    Mar 2021
    Caledon, Ontario
    Another vote for Tackform here. Really solid design. Very pleased with this mount
    Cheers
    Kevin
    2020 RT Limited - Chalk Metallic Dark
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    I have tried the 1. X mount, 2. Track form and 3. The new Quad mount. My favorite to date is the Quad mount.
    2021 900 Ace , Black & Gold
    Very Active Member campermac's Avatar
    May 2015
    Etters PA
    I'm with the rest of them Tackform from Motorcycle Dave, or get yourself a Garmin which is waterproof.
    2022 RT Limited , Silver w/ Black and Purple accents
    Mar 2016
    north dakota
    No, it does not get in the way of the glove box. There is a long stem and short stem I used the short stem. You have many ways to position it on the center handle bar mount. As mentioned above Motorcycle Dave will fill you in on your options.
    Aug 2020
    NM
    I use a quad lock with wireless charging pad and vibration dampener on my F3. You can see a video of it here: https://youtu.be/vypZqlDRa0s
    Active Member pieman9155's Avatar
    Aug 2019
    upstate NY
    i got mind from trackfrom wed site
    2019 f3t , titanium
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by vito1943 View Post
    I found the best way is getting the Top Cuffs from Lamonster Garage. This way you can add additional things (water bottle, power direct to battery, etc.) as you need them.
    2020 RT Limited , Chalk
    May 2020
    Walker, LA
    For my plus size iPhone Pro Max and the suit of armor (Otterbox Defender case) it wears, the RAM mount large X-grip is the phone mount of choice for me. Mounted using a U-bolt, I love the versatility in positioning. The tether adds a little extra peace of mind.
    Jun 2017
    Rapid City, SD
    Quote Originally Posted by Copperman View Post
    Exactly the arrangement I use. The cuff and a tackform mount.
    HE>I
    2017 RT , Asphalt Grey
    Active Member Valkrocket's Avatar
    May 2018
    Murrells Inlet, SC
    Another vote for the Lamonster Top Cuff here. Very versatile, as it can be used to hold multiple items (phone, cup/bottle holder, dash cam, GPS, etc.) That combined with the Ram X-mount has served me well for over 3 years without incident holding my plus sized Iphone.
    GLIDE-ON>>>>>>>>>>>>>>
    2021 RTL Chrome , Petrol Blue
    Jul 2021
    IL
    Quote Originally Posted by sfcarn View Post
    I just ordered the short stem version. Thanks for the recommendation.
    2021 Spyder RT
    Retired U.S. Army
    Life Member, NRA
    Mar 2021
    Arizona high country
    Installed the Lamonster top cuff and the phone phang. I previously ran a USB double port directly from the battery for charging, as I use the phone for music on trips.
    Nov 2020
    Sugarland TX
    I used the Lamonster ram mount on the center with a wireless charging capable mount from Amazon. The charging and the fact that the mount grips the phone by the 4 corners leaving the buttons accessible was the only reason I didn’t go with the tach form mount from motorcycle Dave..
    http://www.amazon.com/dp/B088FNVGWP/...ing=UTF8&psc=1
    2020 Spyder RT base
    2020 RT , Chalk White
    Active Member Schreckftw's Avatar
    Oct 2020
    OH
    Not sure what year you RT is but on a newer one I use this $20 mount. I have tried a few and I like this one. One of the issues with some of the others is that they cover or hit the buttons on the side of the iPhone. I can have my phone attached and locked in in seconds with this.
    https://www.amazon.com/dp/B08R8MZYMH...ing=UTF8&psc=1
    2021 RT Limited , Deep Marsala Red Metallic (Dark)
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by Texas Al View Post
    2+ for the quad mount. check it out prior to purchasing the track mount. Not trying to discourage business from a forum sponsor but take a look at the quad mount system prior to making your purchase decision.
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Member frocco's Avatar
    Sep 2021
    NY
    What about vibration damage to camera from using top cuff or trackform?
    I see Quad Lock addresses that.
