Results 1 to 21 of 21
    Apr 2017
    Queensbury, NY
    Default Smart Phone as GPS for Spyder?
    Does anyone use their Smart iPhone (iPhone in my case) as a GPS when ryding? If so, how do you make the screen readable in bright sunshine?
    Thanks!
    Bert
    Bert
    Dec 2020
    Hartwell, Ga
    I know nothing about a iphone but I put one of these on my android and it work's "Much" better. I have a case for my phone and I removed the clear plastic then added this. No glare at all for me. I'm sure they have one for your phone also.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Dec 2015
    Oakley Utah
    Quote Originally Posted by newbert View Post
    Does anyone use their Smart iPhone (iPhone in my case) as a GPS when ryding? If so, how do you make the screen readable in bright sunshine Thanks! Bert
    There's a fairly recent thread that discusses this and other phone GPS issues. Suggest you do a search.
    Here's one https://www.spyderlovers.com/forums/...-on-cell-phone
    2014 RTL Platinum
    Mar 2021
    Haven, Ks
    I have used my IPhone for gps on my 2019 RTL and other bike for the past year because I got tired of the difficult to read display on my Garmin and because it was not as accurate as the gps on the phone. I never have difficulty seeing the display. I just set the display to it's brightest setting and disable auto brightness and it is crystal clear to see. I also use my phone for XM radio without any problem. I connect the phone to the Spyder with blue tooth. I don't even consider going back to Garmin.
    Aug 2013
    SF Bay Area
    Whether on top of the dash or in it, using the smartphone as a GPS works really great as it has a faster processor.
    Play with the display settings and find out what works. There are visor shades that can attach to the phone case.
    2021 F3 Ltd , Magna Red
    Aug 2012
    Central Coast, CA
    Yes. There are several different cell phone that are known to have an especially bright screen that can be well seen in daylight. Several of those phones are older phones that can be purchased on the used market for very little money. You don't have to hook up the cell phone per se. Most Android phones come with the Google PlayStore app pre loaded, so you can download whichever mapping app you choose for free and it maps through the GPS antenna with no cell data used.
    2020 RTL SE6
    Linden, CA
    me too
    Apr 2017
    Queensbury, NY
    Good info here, guys. Thanks!
    Bert
    I use a Samsung 8 inch tablet with the Sygic app. An anti glare screen protector helps to keep reflections at bay. The screen is fairly easy to see except when the sun is directly behind me.
    Apr 2017
    Queensbury, NY
    Hey Guys, I have an Otterbox case for my iPhone 6s, so I'm not sure whether a matte (solid) screen would work for me. Does anyone know any links for matte (flexible) film that perhaps could be cut to size?
    Bert
    Dec 2020
    Hartwell, Ga
    You must remove the clear plastic even if you have to trim it with a razor knife. If you do not do this then do not waste your money on the anti glare screen.
    Just scroll through these and pick the one you want. Make sure it is the anti-glare type.
    https://www.amazon.com/s?k=Anti-Glar...04&ref=sr_pg_1
    Active Member ES44AC's Avatar
    Sep 2015
    Mocksville,NC
    It should work well, as long as you have cell data service. In the mountains where I go a lot my Google Maps are useless sometimes. I'm not an iPhone user ,so that part I'm not sure about.
    2021 RTL Marsala Dark Edition 4.13.2021
    Lamonster Riser
    Spyder Extras Docking station
    Zumo XT (my own Plug & Play cable)
    WrapMySpyder Carbon fiber partial kit.
    Baja Ron ultra performance sway bar and end links
    2015 RTS SM6 Intense Red
    born on date 3/2015 (mine on 9/12/15)
    Sold on 4.13.2021 33k of fun.
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    I have a Zumo 660 that came with my RT-L, yes I agree with you guys that it's really hard to see in bright daylight. Using your phone as GPS is excellent idea and it would make it easier if your phone has OLED screen instead of LCD. All you have to do is preload your destination at home - I use google Maps on my iPhone 12 - or wherever you have wifi then your phone will work even if you don't have cell signal.
    Ryde Safe and Cheers.
    ‘21 Honda Rebel 1100 DTC Burgundy
    ‘13 Spyder RT-L Pearl White
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    They actually make shields for phones. I have one of these for the screen on a drone I have. A lot of fiddling around trying to get it right but it does work. Here is just a sample of one on Amazon (just search iphone sun shade.)
    https://smile.amazon.com/Sunshade-Co...xpY2s9dHJ1ZQ==
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Quote Originally Posted by MonPaul View Post
    I like this product. Thanks for sharing. Will have to get one soon.
    Harrington, Australia
    Quote Originally Posted by ES44AC View Post
    …you can pony up for one of the GPS apps on your mobile for $70 or so, ES. They run off satellite so you don’t have to worry about phone reception
    HeliBars Handlebars
    Kenda Kanine rear.
    Aug 2013
    SF Bay Area
    The GPS in smartphones IS GPS not cell service. Unlike iPods, iPads and Tablets with cell service that use "Passive GPS", smartphones have the same GPS as a Garmin.
    Apr 2017
    Queensbury, NY
    That looks like a genuinely great idea under most circumstances, but unfortunately won't work for me because:
    a) my phone is in an Otterbox case, and
    b) the mount for it on my Spyder works best in vertical orientation (not horizontal).
    Thanks for the suggestion though!
    Bert
    Bert
    Active Member Big Juice's Avatar
    Jul 2017
    Hot Springs Village, AR
    Yep, that is what my wife and I both use for our iPhones, when using them as GPS.
    O. J.
    Ridin' "Lucille", the MusicMaker
    a 2017 F3 Limited (Pure Magnesium Metallic)
    Wife, Jan, riding "Ruby Jane"
    a 2016 F3-T (Intense Red Pearl)
    2017 F3-Limited , Magnesium (light grey)
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    The bad thing about using your iPhone if you have direct sunlight hitting in the summer on a hot day it will get darker and darker till it shuts off. It happened to me on Saturday. I was going to North Carolina from New Jersey and had my IPhone and my Garmi 396 ,I was using both gps views because I did not like the Garmiin route. It must have been about high 90s and my screen on the phone went black and turned off. The Garmin still worked but the reflection on the screen from my high vis shirt made it hard to see BUT I still had a way to go from my Garmin. I know where I was going had limited cell service. Just a thought.
    Active Member Schreckftw's Avatar
    Oct 2020
    OH
    I have no issues seeing my iPhone 12. The big issue for me in my area is cell reception. If I am using Waze I and have to load map data that can be a problem. To combat that I have Sync GPS as well. With that, much like a GPS only device you download offline maps so not having data is no longer a problem. If I have to switch to that app its fine as I run them both at the same time. With Sync I can also have that display on my Spyders dash display. Although I will say it locks up from time to time but I think that is a BRP issue.
    2021 RT Limited , Deep Marsala Red Metallic (Dark)
