Results 1 to 25 of 30
    Jan 2017
    New York
    Default New to me Spyder RT - what would you folks consider comfort/safety upgrades?
    I’m buying a 2018 spyder rt with 450 miles. The paint and trim have been neglected but not trashed, I believe some elbow grease will bring it back. I purchased a two year warranty as the original expired. This is my first spyder and expect I’ll need to get used to riding on three wheels instead of two! I’ve read the “do’s and don’t’s” on this site. I don’t plan to add a lot of bling (��) but I’m wondering what you folks would consider comfort/safety upgrades?
    Nov 2016
    Franklin North Carolina
    I don't know if it would be considered a safety item but the Baja Ron's sway bar certainly made my rtl handle better.
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Deaconmike View Post
    Comfort - a better saddle, or modify with gel insert AND Triaxial handlebars
    Safety; all the led accessory lighting you can afford
    2014 RTL Platinum
    Jan 2017
    New York
    I’ve got to get used to riding it so I can tell if it’s me or the bike! How does the sway help?
    Durham,Maine
    Car tires, sway bar, front shocks, you'll be styling in my book!!
    2012 RTL , Pearl
    Jan 2017
    New York
    I agree with you on all the lights! I want to be seen!
    Jan 2017
    New York
    I had a car tire on the rear of my Vulcan nomad. I liked it, it didn’t wear out but it did develop cupping on the edges. I wouldn’t think that would ba a problem for the spyders.
    You can never go wrong with more lights. I always prefer an upline seat...if it does not have that already. I would ride it at least 1000 miles before doing any mechanical mods. Get to know your machine and go from there.
    Active Member crossbowme's Avatar
    Jun 2012
    South China, Maine
    You need to define your type of riding before you buy add on's. If you do long trips of thousands of miles at a time you might want a Russell Day Long seat ($$$) and custom Helibars. If you're a weekend warrior putting a couple of thousand of miles year on your machine don't bother with the above. Some want to add on bling and the appearance of their machine is more important than anything. None of the above is wrong but don't waste your money on items that might be important to others and not to you.
    2021 Can Am Spyder Sea-to-Sky
    Active Member Drwerner's Avatar
    Apr 2021
    NY
    Convex mirrors, drivers backrest, inView - wireless helmet-mounted brake and turn signal light, louder horn, Grip Puppies (And, of course, like everyone else has said, more lights)
    2021 RT Limited , Marsala Red/Black
    May 2013
    Apex, N.C.
    For me, number one item was a drivers backrest and cup holder. Pretty much the other items could wait. Especially the swaybar. BRP did a pretty good job designing these things, and it will be totally different from 2 wheels no matter what you do. After logging in over 35k miles on 3 different spyders, I finally put a swaybar on my 2016 F3T. Did it help? Yes, but it was not earth moving. Before the swaybar, I had ridden with many spyder riders in the NC/Tenn mountains that bragged about the swaybar, tires, and expensive shocks. 99% of them were left behind or struggling to keep up. As with most cars, bikes, and spyders today, they are above the capabilities of most of the average riders/drivers. So I say enjoy it and learn the vehicle first and then decide what you need.
    It looks like you're not really attempting to compare your Vulcan experience with a car tire to the Spyder. It's really, apples and oranges. Putting a car tire on a vehicle designed for a motorcycle tire (Your Vulcan) cannot be compared to putting a car tire on a vehicle designed for a car tire (The Spyder). Obviously, your Vulcan is designed to lean, and a car tire is not designed to ride on the outer edge. Whereas, a motorcycle tire is specifically designed to do just that. Still, cupping has more to do with balance and worn suspension components than it does with the vehicle it is fitted to.
    Your Vulcan was designed to lean. And while the Spyder body does lean. The suspension keeps the tires level (or attempts to).
    The next issue you run into with a car tire on a motorcycle rim is the rim bead/seat area matching the tire bead/seat area. It doesn't. Of course, since the Spyder has a car rim/wheel, fitting a car tire to a Spyder wheel is a perfect match.
    If the Spyder has not been aligned using the Rolo laser system have it done. Choose your laser capable shop from this list: http://www.spydercomfort.com/dealersny.htm. Netzley Tire LLC comes highly recommended and can be found at this site: https://b-m.facebook.com/NETZLEYTIRELLC/?__tn__=HH-R. Sorry, I know nothing about Facebook.
    Aug 2018
    north wis
    The very first,and to me most important thing,I did to my 18 RTL was to put in LED fog and headlights. I live in the country and driving the stock lights at night was scary they were so bad.I also eventually added fender strut mounted LED driving lights. These were the first and best mods I did to that bike.
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    Don't forget the missing belt guard to keep the pebbles and rocks out of the drive belt.
    I also second the LED headlights and fog lights. Wow what a difference they make.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Feb 2012
    Spring City,Utah
    I waited several months before I added a lot of stuff to my Spyder. You might want to consider doing that also. Then YOU will know what you need. I added a BajaRon sway bar, LED headlights, Car tires, EBC brake pads and rotors for safety and for comfort I added a gel pad,driver's back rest, floorboards, and grip puppies. I like bling also so have added that too,lots.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Active Member SpyderBears's Avatar
    May 2016
    Chesterfield, MA
    Absolutely get a third brake light LED and LED's to replace the reflectors on the rear saddlebags and front fenders. You'll need all that to really increase your chances of being seen. Be safe out there and enjoy!!
    Nate and Lori
    2021 Spyder RT Limited--Deep Marsala Red--Chrome Edition
    [/B]​Nelson-Rigg half cover, Hopnel side bags and trunk liner bags, , Driver's Backrest, BRP Trailer hitch and control module, 131 DB horn from TricLED, "Shadow" trailer from Mini Trailer USA,
    Durham,Maine
    The next issue you run into with a car tire on a motorcycle rim is the rim bead/seat area matching the tire bead/seat area. It doesn't. Of course, since the Spyer has a car rim/wheel, fitting a car tire to a Spyder wheel is a perfect match.
    Ron, could you take this explanation to the president of Can am and tell him to untie the dealers hands and there liability bla,bla, bla from putting car tires on these machines!! It would make life so much nicer!!
    2012 RTL , Pearl
    I am sure you are joking. BRP isn't going to listen to anything I have to say. And they already know all of this, probably better than I do. It's not about the facts or safety. It's about selling product. When you are selling an inferior product at a high price, like their Kenda's, you have to twist some arms to make the sale. And that isn't going to change.
    There are usually work-a-rounds. Maybe not easy ones depending on where you live. And that is a shame. But dealerships are not the only people installing tires. It depends on how badly you want it. I am fortunate. Here in East Tennessee, just about any tire shop will mount the tire of your choice on a Spyder.
    Jan 2017
    New York
    Thanks, I saved the info
    It's not an issue of BRP tying dealers' hands, nor an issue of liability. See my explanation here: https://www.spyderlovers.com/forums/...=1#post1545171
    Jan 2017
    New York
    I did add Baja on sway bar. Worth every penny! Also replaced headlights with LED, Father’s Day gift from my son ��. Also adding a back rest. I would like to change the auxiliary lightbulb to LED’s, any suggestions? I’m referring to the small lights on the front fenders. I would like to just replace the bulb if that’s possible. I really appreciate this forum, it’s been very helpful!!
    Jun 2012
    South China, Maine
    Yesterday I happened on a car accident. The victims were still in the car and the bystanders had called 911. A nurse was on the seen and was frantically searching for a first aid kit. I gave her mine. In retrospect you might want to add a small first aid kit to your Spyder.
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Quote Originally Posted by crossbowme View Post
    ........In retrospect you might want to add a small first aid kit to your Spyder.
    Of all the add-ons, this is definitely one of the BEST!
    2014 RTS Pearl White
    2014 RTS , Pearl White
    Aug 2019
    southwest oHIo
    Those lights are already LEDs.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
