Rear tire change needed in Wisconsin - any recommendations?
Hello,
I am looking for someplace in Wisconsin/northern Illinois that will put a car tire on the rear of my Syders?
My Spyder History
2013 ST Limited - 16,000 miles
2015 F3s - 48,500 miles
2016 F3t - TBD
Go to this link, insert your Zip code and start calling: https://can-am.brp.com/on-road/us/en....html#/search/.
Been there, done that, got the tee-shirt. Found one that said they would (Englhardt's in Madison WI). When I got there this morning for my appointment they said no they only would put a car tire on a Slingshot. I am not happy with them right now!
My Spyder History
2016 F3t - TBD
Originally Posted by bboley
Hello,
I live in Edgerton, I had the truck and body shop @ 2500 Morse St . in Janesville do mine last fall. I brought in the wheel assembly off my F3L
Thanks, but I'm not able/willing to try to do the removal and installation of the rear tire assembly.
My Spyder History
2016 F3t - TBD
Mad City Powersports will do it. I worked at Engelhart's for a few years. They tow the MFR line on service.
2022 RT Sea To Sky
When I bought mine at Engleharts, they said they would put any tire on I brought in. I brought it in last fall and they didn't like the veredstien tire because the size was so different. I had to singe a paper taking full responsibility if it messed with the VSS. They mounted it though.
Hello,
You may wanna consider asking the dealer if they would install the (newer) Kenda Kanine rear tire.
Nope, I called madcity they said no.
My Spyder History
2016 F3t - TBD
Mounting CTs on GL1800s got to be dificult to find around here. Went to - Walmart - and spoke to the techs. They have a tech that rides sport bikes and another that mounts tires for him. They said bring it in early on days they are working and no problem! I had three mounted there - they appreciated that I warned them of balancing beads in the tires (they can be dangerous on slick concrete!) Cost~ $12. Haven't tried Spyder mounting, but when the time comes I'll ask. BTW, they never chipped the powder coat on my rims, but a "bike shop" mangled a front rim and tried to charge $85!
1976 RD400c
The problem is genuine motorcycle wheels / rims do NOT have " J " type beads .... so they will never completely seal an Auto tire .... at least without a TUBE .... I had a GW and considered it but decided not to because of this issue .... some folks here go into Panic mode when told Auto tires fit Spyder wheels / rims ..... BRP feels the need to have Auto tires with the " special motorcycle tire " embossed on Kenda AUTO tire bead wheels .... HD doesn't give a Cr*p and uses Dunlops on their Trikes ..... go figure ..... Mike
Try Loves Park Motorsport in Roscoe, il , Not that far from you
they put front and Back om mine, last year
815-636-7636
815-636-7636
They put 3 kanine's on my a few weeks ago. nice people.
815-636-7636
They put 3 kanine's on mine a few weeks ago. nice people.
If you don't mind me asking, what did they charge you? They want $300 each to change the rears.
My Spyder History
2016 F3t - TBD
SpyderLovers Ambassador
I just had my local dealer replace my rear tire (5/15/21) for $220, this included the Kenda K9.
Like you I was not able to remove and replace the rear tire.
Dealer wasn't going to do the (Car Tire) bring in any tire thing.
Also the job was done in about 30 minutes.
I hope this is helpful information. . .....
ENJOY YOUR LIFE WITH A SPYDER
You might want to check with Donahue Super Sports in Wisconsin Rapids. The service writer may want you to talk with Troy who does a great job servicing my Spyder.
2020 Spyder RT Limited in Deep Marsala Dark
My Spyder History
2016 F3t - TBD
They have me scheduled to do the tires! Thanks for the suggestion PACKERFAN
My Spyder History
2016 F3t - TBD
Did you have to supply the tire or did they stock the Kanines?
Did you check Rob's Performance in Johnson Creek, WI?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
I supplied the tire. I don't know if they have the Kanines.
My Spyder History
2016 F3t - TBD
Yes, they do my oil changes but not the car tire mounting.
My Spyder History
2016 F3t - TBD
