Results 1 to 6 of 6
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Saddlebag lid stuck.
    I sold my high mileage 2014 Spyder RT-S to my brother. Now we can't get the right side saddlebag lid to come off. The left side works fine but when the release is pulled you feel nothing. Is the cable broken? I know the adjusters are under the rear plastic, but you can't get to the screws, they're under the lid that's locked.
    Chuck
    Apr 2020
    Lebanon ohio
    I don't know on a 14 but on a 2020 you remove the filler panel under the passengers hand grips and reach down and trip the locking lever
    Bossier LoUiSiAna
    No different pushing in on door when latch is pulled or trying all doors at same time
    Quote Originally Posted by Buckeye Chuck 54 View Post
    Chuck
    Chuck, I also have a 14 and the left side was problematic after a few months of use .... a hard rap on the lid would help it release ... now the right side needs a rap .... I have seen posts on this site about adjusting the cables .... do a SEARCH ..... Mike
    Jun 2015
    Zanesville Ohio
    We tried a light rap with the ball of your hand to a rubber mallet. You pull the release on the left side and it opens as it should. But you pull the other side and there's no resistance, like the cable isn't attached. We tried pulling both sides at once and that same thing. I hate taking it to the dealer, but I don't know any other way.
    I'll look at Longtimer's post, that may work. I know the 2014 is way different from a 2020, but it's worth a look.
    Thanks to all.
    Chuck
    Jun 2015
    Zanesville Ohio
    Default Re: High mileage Spyder questions, answers.
    You nailed it Longtimer! Problem solved. Brother Ken thanks you! As do I.
    Now, how to adjust and lube cables? Is that from the back or each saddlebag?
    Chuck
