Results 1 to 25 of 28
    Active Member deer30084's Avatar
    Tallahassee, FL
    Default My Spyder F3 broke down on the road today
    2015 Spyder F3 SE6 with 18,700 miles. Was doing 45-50 MPH in 6th gear. Seemed to slip out of gear, pulled over, tried reverse it tried to go, check engine light came on. Sounded like gears grinding. Engine starts. "E" on display. Won't shift gears. Had tow truck take it to dealer. Dealer "backed up" and won't get to it for about a week. Will keep you posted.
    John F.
    Tallahassee, FL
    2015 Spyder F3 SE6, black
    BRP Driver/passenger Footboards
    BRP Adjustable Passenger Backrest
    Blue Ridge Windshield
    MRA X-Creen Tour, clear, clamp-on
    H4 LED Headlights
    F3 LED Fog Light Kit, LED Amber Halo Ring Kit, LED Tail Lights, F3 Rear run/brake/turn LEDs
    Easy Brackets
    Leatherworks, Inc. 120 Special Slight Angle Saddlebags
    Custom Dynamics Front Mud Flap LED lights, Street Magic Front Fender Tips, Double Feature Lens
    2-up rear shock
    Idler pulley kit
    Active Member AZCanAm's Avatar
    Mar 2021
    AZ
    Well that really sucks. Best of luck. Hopefully it does not set you back too much.
    Feb 2019
    Portland, Oregon
    If the front belt pulley has been ignored, you mileage is at that point where many have had the splines in the pulley fail. If I'm right, make certain a white pulley is installed. That's the newly revised one. Do not allow them to install one that is not white.
    Changing the pulley is not brain surgery. If you know which end of the screwdriver is the handle, you can do it - or maybe a friend would do it for you? I know I'd do it.
    Tallahassee, FL
    Well I kinda hope you are right. That doesn't sound too costly. Hopefully it's not the entire transmission. Thanks!
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
    It's not likely to be 'the entire transmission' from what you describe - and given the problems others have had & reported here, I'd guess that it's more likely to be that front pulley RICZ mentioned; possibly a stripped/dislodged Selector Sector Arm; or maybe just a dodgy Gear Position Sensor.... all of which many with little 'motorcycle mechanical aptitude &/or experience' have been successfully able to 'repair' themselves once their particular problem was identified. Again as RICZ suggested, if you know which end of a screwdriver is the handle, if you're physically able to get close enough to do things, you should be able to sort any of those yourself fairly readily!
    Have you checked it out from underneath or taken any of the tupperware off to have a look??
    Ps: that 'Check Engine Light' might have a few important & specific reasons for coming on, but it doesn't sound like any of those, so it's probably on because of its 'other' function.... which is illuminating when/if the computers detect that the vehicle isn't working or moving as it should but there's no data from any of the sensors to tell them why!? In other words, if something feels wrong & the computers don't know WTF it might be, they'll turn on the 'Check Engine Light'!! Apart from it's specific functions, it's just a 'catch all fob off'....
    Tallahassee, FL
    Well, being the dummy that I am, I didn't even think of the front pulley or to take a look myself. I immediately thought "internal engine/transmission problem." I do my own oil changes, but didn't know to look at the pulley today. So off to the dealer it went. Thanks for responding though. It kinda eases my mind that this might not break the bank after all. I will post on here what the dealer did and how much it cost me. Thanks Peter!
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
    Apr 2015
    Lodi WI
    Quote Originally Posted by deer30084 View Post
    BRP refused my pulley under warranty. Called it wear and tear item. I'd budget about $250.
    Dec 2009
    West Oz
    Quote Originally Posted by Dennis in Lodi View Post
    Another customer that didn't get what he paid for.
    Feb 2019
    Portland, Oregon
    $250?!? That must be if a shop does it. DIY might be about $115 for the pulley and bolt.
    Nov 2020
    Lincoln, Nebraska
    Rather interesting. My experience has always been that if you’re broken down on the road, i.e. vacation, you went to the front of the line. I always tell the dealer that if somebody comes in off the road to bump me and fix them. Times have changed.
    Tallahassee, FL
    Quote Originally Posted by Plarimer View Post
    Yeah. When I told the dealer, owner and service manager, I broke down on the road, that didn't seem to matter. I wasn't on vacation and I was only a few miles from home. Maybe if I was from out of town, they may have given me preference. Owner of dealership asked me if I had an extended warranty. I don't. And here's another thing. I didn't have roadside service with my Progressive Insurance or AAA. I do now. Roadside with Progressive was much cheaper than AAA. Only adds $20 to the policy. The tow cost me $150. I'm putting this out there for anyone else that doesn't think they need roadside service, get it!
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
    Mar 2021
    AZ
    Yeah. When I told the dealer, owner and service manager, I broke down on the road, that didn't seem to matter. I wasn't on vacation and I was only a few miles from home. Maybe if I was from out of town, they may have given me preference. Owner asked me if I had an extended warranty. I don't. And here's another thing. I didn't have roadside service with my Progressive Insurance or AAA. I do now. Roadside with Progressive was much cheaper than AAA. Only adds $20 to the policy. The tow cost me $150. I'm putting this out there for anyone else that doesn't think they need roadside service, get it!
    In my opinion, the towing added to your insurance is a must. Money well spent.
    May 2013
    Apex, N.C.
    I do have AAA, but I have heard that it doesn't work with motorcycles (or trikes). That is something that I need to check into with my policy. Thanks for the reminder. Have anyone here, with AAA been denied compensation because you ride a bike or trike?
    Nov 2019
    Kansas
    I have AAA and added motorcycle coverage.
    Mar 2019
    Fla/NJ
    AAA works also AMA works also "Good Neighbor Sam" will tow to the nearest servicing dealer regardless of distance
    Mar 2017
    Good to have towing on your insurance. It will pay for itself for years even if you only use it once.
    Another insurance hint told to me by my lawyer. Buy as much underinsured/uninsured coverage you can buy. It's only about $40 a year for $250K! I had to sue my own insurance company to get the payout of 27K on my head-on with my gold Wing. Lawyer says "They would have just written a check for you if you had better coverage on that part." The very next day I called them and added a quarter million. Depends on your state though.
    Nov 2018
    Waynesboro, PA
    AAA works if you add it; it comes with the RV coverage.
    My Spyder
    2012 RTL , Brown
    Dec 2012
    Murphy, NC
    AAA does offer motorcycle towing but only if you have the Premier/RV coverage.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Jul 2008
    Los-Angeles
    AAA Plus Rv
    Active Member Rednaxs60's Avatar
    Mar 2021
    British Columbia
    Roadside assistance from a Canadian perspective, it's a must have; however, BCAA standard coverage includes motorcycle towing in British Columbia. 2018, riding to Los Angeles on my '85 Honda Goldwing Limited Edition with an external alt mod. Redding California, alternator failed. Towed to local dealer but had to pay for towing. Contacted the US equivalent, my BCAA standard coverage did not include towing in CA. Called BCAA and upgraded to the Premium package. BCAA reimbursed me for the tow costs.
    If you are travelling out of your usual riding area, or internationally, recommend contacting your roadside assistance provider for information on where you are going. Good to have contact phone numbers for where you are going, and knowing your roadside assistance package is valid.
    "When Writing the Story of Your Life, Don’t Let Anyone Else Hold the Pen"
    "Too many of us are not living our dreams because we are living our fears.” – Les Brown
    2014 Can-Am Spyder RT LE
    1985 Honda GL1200 Goldwing Limited Edition
    Ernest
    Mar 2019
    Ruidoso Downs, New Mexico
    I get roadside for ALL my vehicles through AMA. And as Life Member with auto renew, it is free. Have used it a number of times, most recently when I locked myself out of my truck at a motel in Lubbock at 4:00 am! The only caveat is that you can only use it once in a 30 day period.
    2020 F3L; gone but not forgotten are all the good miles!
    May 2013
    Sacrament0, CA
    Any updates deer30084 ?
    Nov 2020
    Lincoln, Nebraska
    I was towed 200 miles back to Memphis on my AAA membership and I didn’t have to pay a dime.
    Jun 2015
    Ritzville, Wa
    I've had AAA Premier since 1986 and thought I was covered. Imagine my surprise to learn it covered everything except RV's, motorcycles and the Space Shuttle. Among other things it provides me with a free 200 mile tow should I need it. Anything in excess of that is on my dime.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Tallahassee, FL
    56 days later (today, July 2, 2021) I got my F3 back from the dealer. I had called over the past several weeks and was told they were waiting for the part. I was told early on that they had to drain the oil and get into the transmission because the transmission filter was never changed. I told them not to do that because I found out FROM THIS FORUM that the front pulley was known to go bad. Dealer called me back a couple hours later and said I was right. Since the bike was in the shop, I asked the dealer to change the anti-refreeze too. So here's the dollar amount: $109.99 for the "POULIE 28 DENTS*SPROCKET 28TH," $9.99 x 3 for Coolant extended life premixed QT, 3 hours labor for all at $90.00/hr. Tax $24.00. Total: $343.96. Thank you to RICZ, others and this forum for making the front pulley information available!
    John F.
    Tallahassee, FL
    H4 LED Headlights
    Easy Brackets
    2-up rear shock
    Idler pulley kit
